LibreDrive error
killakel77
LibreDrive error
Post by killakel77 » Sat Mar 11, 2023 8:14 pm
I'm trying to use SDFTool and I use the bin file for Wh14NS40. Once I run the tool I get this error message "Command produced error code 0x82052400". Am I doing something wrong?
Screenshot 2023-03-11 150933.png (2.87 KiB) Viewed 9232 times
Re: LibreDrive error
Post by Coopervid » Sun Mar 12, 2023 11:09 am
You need to post more information. AnyDVD status with which firmware is on the drive and what you would like to flash.
asmcom
Post by asmcom » Sun Mar 12, 2023 12:14 pm
killakel77 wrote: Sat Mar 11, 2023 8:14 pm I'm trying to use SDFTool and I use the bin file for Wh14NS40. Once I run the tool I get this error message "Command produced error code 0x82052400". Am I doing something wrong?
Have you left the optical drive tray open?
Is there a disc in the drive?
Tray must be closed and the drive must have no disc?
Asmcom :mrgreen:
Taqyon
Post by Taqyon » Sun Mar 12, 2023 5:43 pm
I've got the same issue when using the SDFtool Flasher or command line: Command produced error code [some digits, changes every time]
This is my device:
Product: BD-RE BP60NB10
Revision: 1.02
Serial number: SIM03L33E1545
Firmware date: 2120-05-07 09:35
I've been trying to load this file:
HL-DT-ST-BD-RE_BP60NB10-1.02-NM00800-212005070935
Let me know if that's not the correct one but any help regarding the error would be great!!
BTW The drive is closed and no disk loaded.
Taqyon
Post by Taqyon » Sun Mar 12, 2023 7:34 pm
Sorted! I just opened the drive and closed it again and restarted the tool and now it worked!
Post by Coopervid » Sun Mar 12, 2023 9:16 pm
How is the drive connected to the computer? Anything else looks good.
asmcom
Post by asmcom » Mon Mar 13, 2023 2:46 am
Taqyon wrote: Sun Mar 12, 2023 7:34 pm Sorted! I just opened the drive and closed it again and restarted the tool and now it worked!
Must have been a bad connection on the microswitch for the drive tray.
Asmcom :mrgreen:
