LibreDrive error
killakel77
LibreDrive error
#1 Post by killakel77 » Sat Mar 11, 2023 8:14 pm
I'm trying to use SDFTool and I use the bin file for Wh14NS40. Once I run the tool I get this error message "Command produced error code 0x82052400". Am I doing something wrong?
Re: LibreDrive error
#2 Post by Coopervid » Sun Mar 12, 2023 11:09 am
You need to post more information. AnyDVD status with which firmware is on the drive and what you would like to flash.
asmcom
#3 Post by asmcom » Sun Mar 12, 2023 12:14 pm
killakel77 wrote: Sat Mar 11, 2023 8:14 pm I'm trying to use SDFTool and I use the bin file for Wh14NS40. Once I run the tool I get this error message "Command produced error code 0x82052400". Am I doing something wrong?
Have you left the optical drive tray open?
Is there a disc in the drive?
Tray must be closed and the drive must have no disc?
Asmcom :mrgreen:
Taqyon
#4 Post by Taqyon » Sun Mar 12, 2023 5:43 pm
I've got the same issue when using the SDFtool Flasher or command line: Command produced error code [some digits, changes every time]
This is my device:
Product: BD-RE BP60NB10
Revision: 1.02
Serial number: SIM03L33E1545
Firmware date: 2120-05-07 09:35
I've been trying to load this file:
HL-DT-ST-BD-RE_BP60NB10-1.02-NM00800-212005070935
Let me know if that's not the correct one but any help regarding the error would be great!!
BTW The drive is closed and no disk loaded.
Taqyon
#5 Post by Taqyon » Sun Mar 12, 2023 7:34 pm
Sorted! I just opened the drive and closed it again and restarted the tool and now it worked!
#6 Post by Coopervid » Sun Mar 12, 2023 9:16 pm
How is the drive connected to the computer? Anything else looks good.
asmcom
#7 Post by asmcom » Mon Mar 13, 2023 2:46 am
Taqyon wrote: Sun Mar 12, 2023 7:34 pm Sorted! I just opened the drive and closed it again and restarted the tool and now it worked!
Must have been a bad connection on the microswitch for the drive tray.
Asmcom :mrgreen:
