jt5298
Post by jt5298 »
Billycar11 wrote: Fri Mar 10, 2023 2:27 am
jt5298 wrote: Thu Mar 09, 2023 10:55 pm
Billycar11 wrote: Thu Mar 09, 2023 10:26 pm
Follow the guide it does not say to flash that firmware
Not sure I understand. My firmware is 1.04, I need to downgrade to 1.02 to make it UHD friendly. When I use the flasher tool I get this pop-up DRAM NG 5/26/03. Why am I getting this pop-up? How can I get it to downgrade successfully?
you can get it to downgrade successfully by reading the guide not skimming and glancing at it you are reading the wrong model name you are seeing WH16NS40 1.02 but the guide says WH16NS60 1.02 the use the all you need firmware pack it will simplify things for you
Got it to work flashing to WH16NS60 1.02. Yes I was skimming and glancing, sorry. One thing, do I need to flash to the WH16NS40 1.02 now, or just leave as is? I am ripping a movie now and the drive is slowing and starting quite often. Making a grinding noise if you will. Is this normal? I have never had it do this so often ripping a movie with a different software. I don't think this is the "sleep bug" I am ripping a Blu-ray disc not UHD. The door is not opening and closing. It's just making grinding noises as it rips the disc. Do I need to downgrade again to 1.00, or 1.01?
D3F3ND3R16
Post by D3F3ND3R16 »
does drives available in the EU also work? like this one?
BDR-XD07TUHD
none of the mentioned drives are available her to buy :(
Guitrdone
Post by Guitrdone »
The following output was received to downgrade from 1.02 for my LG drive:
C:\Program Files (x86)\MakeMKV>makemkvcon64.exe f --all-yes -d D: rawflash -i c:\temp\DE_LG_BP60NB10_1.00_MK_HBD.bin
Reading input file c:\temp\DE_LG_BP60NB10_1.00_MK_HBD.bin
Current Drive ID: HL-DT-ST_BD-RE_BP60NB10_1.02_212005070935_SIKB3K7DA3436
Using USB chipset workaround for Desktop drive handshake
100% Operation finished
Done successfully
However, MakeMKV still reports firmware 1.02, and I get:
Saved AACS dump file as C:\Users\bcook/.MakeMKV/MKB20_v68_The_Dark_Knight_2247.tgz
Subsequent attempts result in the following output:
C:\Program Files (x86)\MakeMKV>makemkvcon64.exe f --all-yes -d D: rawflash enc -i c:\temp\DE_LG_BP60NB10_1.00_MK_HBD.bin
98% .................................................
Write DRAM NG 05/26/03
Command produced error code 0x82052603
Write DRAM NG 05/24/00
Command produced error code 0x82052400
Is there any hope?
You must first flash 1.02 MK before you can flash 1.00. And why don't you use the SDFFlasherTool?
asmcom
Post by asmcom »
dorrisdormouse wrote: Fri Mar 10, 2023 11:19 am Hi, I've got an LG-BP55EB40 that has previously been flashed with BP60NB10 v1.00mk. I've been trying to update the firmware using the flasher tool, but always get an error 0xff056103. Not sure what im doing / not doing that is wrong?
Dave
Hello Dave,
Firmware 1.00mk is very good with this drive.
Asmcom :mrgreen:
Guitrdone
Post by Guitrdone »
Coopervid wrote: Fri Mar 10, 2023 8:53 pm You must first flash 1.02 MK before you can flash 1.00. And why don't you use the SDFFlasherTool?
I'm not sure how I can obtain the 1.02 MK. Can you send a link? Thanks!
The first post of this thread contains everything you need.
asmcom
Post by asmcom »
Guitrdone wrote: Fri Mar 10, 2023 11:40 pm
Hello Guitrdone,
Use Marty's SDFflasher to flash your drive. Use this file in the folder labelled HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936 to flash your drive to 1-02mk. If you then want to flash to WH16NS60 1-00DE then use the file in the other folder labelled DE_LG WH16NS60_1.00. You must flash with 1-02mk first then 1-00DE
Please use this link below to use Marty's SDF Flasher to flash your drive.
https://www.mediafire.com/file/rak1mk0p ... 9.zip/file
https://tinyurl.com/yxbeptj4
jt5298
Post by jt5298 »
Getting a grinding noise after downgrading LG WH16NS40 1.04 to LG WH16NS60 1.02 when ripping discs. Do I need to downgrade to 1.00 or 1.01?
asmcom
Post by asmcom »
jt5298 wrote: Sat Mar 11, 2023 7:07 pm Getting a grinding noise after downgrading LG WH16NS40 1.04 to LG WH16NS60 1.02 when ripping discs. Do I need to downgrade to 1.00 or 1.01?
Clean the discs you are using.
Asmcom :mrgreen:
Guitrdone
Post by Guitrdone »
Coopervid wrote: Sat Mar 11, 2023 12:14 pm The first post of this thread contains everything you need.
I found it. Thanks!
Guitrdone
Post by Guitrdone »
asmcom wrote: Sat Mar 11, 2023 3:13 pm
Hello Guitrdone,
Amscom-
I did exactly this, and I have The Dark Knight streaming now. Can't tell if the HDR was copied, but it looks pretty good. Does MakeMKV copy the HDR info too?
Thanks a bunch!
asmcom
Post by asmcom »
Guitrdone wrote: Sat Mar 11, 2023 7:47 pm
Hello Guitrdone,
Use Marty's SDFflasher to flash your drive. Use this file in the folder labelled HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936 to flash your drive to 1-02mk. If you then want to flash to WH16NS60 1-00DE, then use the file in the other folder labelled DE_LG WH16NS60_1.00. You must flash with 1-02mk first, then 1-00DE
Amscom-
Thanks a bunch!
You are welcome, and I would, however, encourage you to read the guides in more detail as this is how you will learn. I appreciate you were struggling, so I made it easy for you. MakeMKV does support HDR, but it depends on what you are playing it back on.
Asmcom :mrgreen:
tegid1977
Post by tegid1977 »
I have tried several methods to flash my Archgon MD-8107-U3 so far with no luck. Here is the information I get from MakeMKV:
Product: BD-RE BU40N
Revision: 1.02
Serial number: MO8M2QI0627
Bus encryption flags: 1F
Highest AACS version: 77
Harware support: Yes
Firmware support: No
Firmware version: 1.02
I've tried flashing HL-DT-ST-BD-RE_BU40N-1.02-NM01201-211711301218.bin from the old directory of mk-firmware-pack-20200720 if I run the CLI command
makemkvcon64.exe f --all-yes -d D: rawflash -i "HL-DT-ST-BD-RE_BU40N-1.02-NM01201-211711301218.bin"
I get what appears to be a successful message:
Reading input file HL-DT-ST-BD-RE_BU40N-1.02-NM01201-211711301218.bin
Current Drive ID: HL-DT-ST_BD-RE_BU40N_1.02_212012011716_MO8M2QI0627
Done successfully
But when I restart my computer and run MakeMKV again the drive info is unchanged. I know I am missing something and would appreciate any help that can be given.
As to why I ran the CLI and not a GUI the GUI would fail immediately see attachments for a screenshot.
Screenshot 2023-03-13 184207.png (158.05 KiB) Viewed 28401 times
tegid1977 wrote: Mon Mar 13, 2023 11:44 pm I have tried several methods to flash my Archgon MD-8107-U3 so far with no luck. Here is the information I get from MakeMKV:
Revision: 1.02
Done successfully
Your firmware is encrypted. Add the enc flag to your command.
