Post by Coopervid » Fri Feb 17, 2023 8:38 pm
They are technically the same and you can flash to make it either an ASUS or a LG. Any reason you don't consider a Pioneer?
daave
Post by daave » Fri Feb 17, 2023 8:40 pm
Coopervid wrote: Fri Feb 17, 2023 8:38 pm They are technically the same and you can flash to make it either an ASUS or a LG. Any reason you don't consider a Pioneer?
I should check if they are available in Italy. Anyway, Alex Coluzzi told me that the LG is not so good and it will not last a lot.
The Pioneer are those on the 1st page?
liamtoh1
Post by liamtoh1 » Fri Feb 17, 2023 8:44 pm
daave wrote: Fri Feb 17, 2023 8:40 pm
1 drive missing from the 1st page for Pioneer is BDR-XD08UMB-S which also works out of the box (without any firmware updates) with MakeMKV
daave
Post by daave » Sat Feb 18, 2023 12:11 pm
Guys, I have a problem. My LG WH16NS40 has arrived today but my Lenovo laptop with Win11 doesn't recognize it. I am using this as adapter https://www.amazon.it/Inateck-Adattator ... b_title_ce
What should I do?
Post by Coopervid » Sat Feb 18, 2023 12:55 pm
Get another one. Yours is only for SSD and HDD.
https://www.amazon.de/Unitek-Y-3324-Br% ... C94&sr=8-1
daave
Post by daave » Sat Feb 18, 2023 1:10 pm
Coopervid wrote: Sat Feb 18, 2023 12:55 pm Get another one. Yours is only for SSD and HDD.
The disk player works, it means the tray is working but it doesn't get recognized by win11.
So you think that is just the adapter?
Post by Coopervid » Sat Feb 18, 2023 5:35 pm
Yes. And I had told you to check the adapter on page one which is the same I posted the Amazon link for. Yours doesn't work with optical drives.
daave
Post by daave » Sat Feb 18, 2023 6:43 pm
Coopervid wrote: Sat Feb 18, 2023 5:35 pm Yes. And I had told you to check the adapter on page one which is the same I posted the Amazon link for. Yours doesn't work with optical drives.
Bought it. Waiting for delivery.
Thank you
asmcom
Post by asmcom » Sun Feb 19, 2023 2:22 pm
I can supply you Pioneer drives to Italy with no import duty. Dispatched from Ireland.
viewtopic.php?t=19387
Asmcom
DavidO
Post by DavidO » Mon Feb 20, 2023 9:26 am
Billycar11 wrote: Sun Feb 12, 2023 5:56 am no point flashing it but is the nb52 1.03 not out there? i have it if not
also fyi the pioneer is slower just so you know 4x vs 6x about 30 mins extra on a bd100
Any chance you can upload the NB52 "DE" firmware? The LG website only goes to NB50.
Post by Billycar11 » Mon Feb 20, 2023 10:58 pm
DavidO wrote: Mon Feb 20, 2023 9:26 am
there is no DE for it only MK and stock.
i dont really see a need for it seems like only people who want to return things want it and there no point flashing it back to stock to return it they dont check. so its a waste of your time and my google drive space.
and its completely not needed as BP50NB52 still does not see UHDs
and this is the UHD guide not the return my drive to stock guide
daave
Post by daave » Tue Feb 21, 2023 1:36 pm
Guys, I bought a LG WH16NS40, I have to flash some firmware? Which one? Is there a final guide to do it?
The 1st page is not so clear
bluedanes
Post by bluedanes » Tue Feb 21, 2023 7:23 pm
Billycar11 wrote: Mon May 27, 2019 5:20 am
BP50NB40, UHD Officialish External Slim 9.5mm USB 2.0 | Rip speed 6x BD 66 ~45 mins BD 100 ~1 hour 5mins
What do they mean by 'Officialish'?
Post by Billycar11 » Tue Feb 21, 2023 9:14 pm
daave wrote: Tue Feb 21, 2023 1:36 pm Guys, I bought a LG WH16NS40, I have to flash some firmware? Which one? Is there a final guide to do it?
How is this not clear?
Just get an automated flasher from me or Marty then
daave
Post by daave » Tue Feb 21, 2023 9:18 pm
Billycar11 wrote: Tue Feb 21, 2023 9:14 pm
I am missing something, why should I need to flash my drive? I ripped a bluray disc this afternoon without flashing anything. The firmware change is useful for ripping 4k bluray?
