They are technically the same and you can flash to make it either an ASUS or a LG. Any reason you don't consider a Pioneer?
I should check if they are available in Italy. Anyway, Alex Coluzzi told me that the LG is not so good and it will not last a lot.Coopervid wrote: Fri Feb 17, 2023 8:38 pm They are technically the same and you can flash to make it either an ASUS or a LG. Any reason you don't consider a Pioneer?
The Pioneer are those on the 1st page?
1 drive missing from the 1st page for Pioneer is BDR-XD08UMB-S which also works out of the box (without any firmware updates) with MakeMKVdaave wrote: Fri Feb 17, 2023 8:40 pmI should check if they are available in Italy. Anyway, Alex Coluzzi told me that the LG is not so good and it will not last a lot.Coopervid wrote: Fri Feb 17, 2023 8:38 pm They are technically the same and you can flash to make it either an ASUS or a LG. Any reason you don't consider a Pioneer?
Guys, I have a problem. My LG WH16NS40 has arrived today but my Lenovo laptop with Win11 doesn't recognize it. I am using this as adapter https://www.amazon.it/Inateck-Adattator ... b_title_ce
What should I do?
What should I do?
Get another one. Yours is only for SSD and HDD.
https://www.amazon.de/Unitek-Y-3324-Br% ... C94&sr=8-1
The disk player works, it means the tray is working but it doesn't get recognized by win11.Coopervid wrote: Sat Feb 18, 2023 12:55 pm Get another one. Yours is only for SSD and HDD.
So you think that is just the adapter?
Yes. And I had told you to check the adapter on page one which is the same I posted the Amazon link for. Yours doesn't work with optical drives.
Bought it. Waiting for delivery.Coopervid wrote: Sat Feb 18, 2023 5:35 pm Yes. And I had told you to check the adapter on page one which is the same I posted the Amazon link for. Yours doesn't work with optical drives.
Thank you
I can supply you Pioneer drives to Italy with no import duty. Dispatched from Ireland.daave wrote: Fri Feb 17, 2023 8:40 pmI should check if they are available in Italy. Anyway, Alex Coluzzi told me that the LG is not so good and it will not last a lot.Coopervid wrote: Fri Feb 17, 2023 8:38 pm They are technically the same and you can flash to make it either an ASUS or a LG. Any reason you don't consider a Pioneer?
viewtopic.php?t=19387
Asmcom
Any chance you can upload the NB52 "DE" firmware? The LG website only goes to NB50.Billycar11 wrote: Sun Feb 12, 2023 5:56 am no point flashing it but is the nb52 1.03 not out there? i have it if not
also fyi the pioneer is slower just so you know 4x vs 6x about 30 mins extra on a bd100
there is no DE for it only MK and stock.DavidO wrote: Mon Feb 20, 2023 9:26 amAny chance you can upload the NB52 "DE" firmware? The LG website only goes to NB50.Billycar11 wrote: Sun Feb 12, 2023 5:56 am no point flashing it but is the nb52 1.03 not out there? i have it if not
i dont really see a need for it seems like only people who want to return things want it and there no point flashing it back to stock to return it they dont check. so its a waste of your time and my google drive space.
and its completely not needed as BP50NB52 still does not see UHDs
and this is the UHD guide not the return my drive to stock guide
Guys, I bought a LG WH16NS40, I have to flash some firmware? Which one? Is there a final guide to do it?
The 1st page is not so clear
What do they mean by 'Officialish'?Billycar11 wrote: Mon May 27, 2019 5:20 am
BP50NB40, UHD Officialish External Slim 9.5mm USB 2.0 | Rip speed 6x BD 66 ~45 mins BD 100 ~1 hour 5mins
How is this not clear?daave wrote: Tue Feb 21, 2023 1:36 pm Guys, I bought a LG WH16NS40, I have to flash some firmware? Which one? Is there a final guide to do it?
Just get an automated flasher from me or Marty then
I am missing something, why should I need to flash my drive? I ripped a bluray disc this afternoon without flashing anything. The firmware change is useful for ripping 4k bluray?Billycar11 wrote: Tue Feb 21, 2023 9:14 pmHow is this not clear?daave wrote: Tue Feb 21, 2023 1:36 pm Guys, I bought a LG WH16NS40, I have to flash some firmware? Which one? Is there a final guide to do it?
