Ultimate UHD Drives Flashing Guide Updated 2024
asmcom
Post by asmcom »
Coopervid wrote:
Mon Feb 13, 2023 9:38 pm
It is my personally experience which is very subjective. However, the sellers of drives in this forum who sold many of them state the same. Ask Billycar11 or MartyMcNuts.
I would agree totally with what you said Coppervid.
Asmcom :mrgreen:
Click Here! viewtopic.php?f=20&t=19387
Lord Szechenyi
Post by Lord Szechenyi »
I'm about to buy an LG BH16NS55, according to the guide, if it's only version 1.04 it's good, but the specific model I found says it was manufactured in February 2020, does this mean it won't work?
Also, I'm an absolute noob at this, and I'm still confused on what the step-by-step is.
Mr_Orange
Post by Mr_Orange »
Does it say MT1959 on it? That is more critical than the date of manufacture although I suspect Feb 2020 is fine.
Firmware version doesn't matter as you should flash it to WH16NS60 1.02MK.
Lord Szechenyi
Mr_Orange wrote:
Thu Feb 16, 2023 2:13 am
Where does it say that?
(btw these are the pics from the listing)
Lord Szechenyi wrote:
Wed Feb 15, 2023 8:21 pm
Post your Makemkv info. The information for the chip should be MT1959. Most likely it is and you are good to flash it.
daave
Post by daave »
Hello everyone, I would like to buy a UHD official drive for ripping and playing 4K bluray and the normal ones.
Which are the UHD official internal or external drive that I can get? Is there an updated list? I am from Italy.
Thank you in advance.
daave wrote:
Thu Feb 16, 2023 4:16 pm
Page 1 of this thread.
daave
Post by daave »
Thank you Coopervid. So that one is the latest list, is it?
Thu Feb 16, 2023 10:23 am
Did you see my reply under your post? Anyway - you should be fine to flash.
Go to page one. See Unlocked flashers and download the first two links. Flash either LG BH16NS55 1.03 from the OLD directory or cross-flash to BH16NS60 1.02 from the HL-DT-ST directory. You need the SDFToolFlasher. Older flashers won't work.
daave
Post by daave »
I have another question, if I buy a UHD friendly drive, I can't play the movie on my laptop but I can rip it and then play, right?
If I buy a UHD official drive, can I play the movie on whatever laptop?
Because I saw that the CPU must support SGX in order to play the movie directly without ripping. (SGX is supported only by Intel cpus (10th gen or earlier)
Dakinathon
Post by Dakinathon »
A month ago ( January 2023) I bought the https://www.amazon.com/MthsTec-Powerful ... B09QC1VYNZ. It contains within the enclosure the latest and greatest Blu-Ray LG WH16NS48 drive. When it works (about 80% of the time, these are older Blu-Ray disks) it is amazingly fast at 16X it backs up a 2 hour Blu-Ray movie in about 20 minutes. The other 20% of the time with newer videos it will error out in literally 3 to 4 sec. Disappointing to say the least. The error(s) = OS error and Scsi error are shown below. Since this is the case, can I take it for granted that MakeMKV needs to be updated to be able to bypass (New?) security measures.
At this time there is no firmware available for this drive, it is that new and I have come to believe that MakeMKV is causing the problem. I'm not an expert, I'm searching and struggling to find a way to make this work.
Any help or insights that anyone can offer would be gratefully accepted.
Thanks in advance for reading this request.
MakeMKV v1.17.3 win(x64-release) started
Using Java runtime from C:\Program Files\Java\jre1.8.0_351\bin\java.exe
Title #00631.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00050.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00299.mpls has length of 83 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00800.mpls was added as title #0
File 00801.mpls was added as title #1
File 00802.mpls was added as title #2
File 00803.mpls was added as title #3
Title #00307.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00088.mpls has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00089.mpls has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00090.mpls has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00091.mpls has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00092.mpls has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00086.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00052.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00053.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00058.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00057.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00056.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00059.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00060.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00061.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00062.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00063.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00064.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00065.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00066.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00067.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00068.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00069.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00070.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00071.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00072.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00074.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00075.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00076.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00077.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00078.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00079.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00080.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00082.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00085.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00087.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00093.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00094.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00049.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00450.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00047.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00051.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00054.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00055.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00048.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00189.mpls has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00600.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00601.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00681.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00431.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00682.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00688.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00689.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00683.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00684.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00685.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00686.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00687.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00690.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00102.mpls has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00103.mpls has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.mpls has length of 83 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.mpls has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title 00850.mpls is equal to title 00800.mpls and was skipped
Title 00851.mpls is equal to title 00801.mpls and was skipped
Title 00852.mpls is equal to title 00802.mpls and was skipped
Title 00853.mpls is equal to title 00803.mpls and was skipped
Title #00002.m2ts has length of 83 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00014.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00013.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00127.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00102.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00103.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 4 titles into directory E:/Video/COSMOS- A SpaceTime Odyssey, Season 1 Disc 1
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '219936768'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '219936768'
Failed to save title 0 to file E:/Video/COSMOS- A SpaceTime Odyssey, Season 1 Disc 1/COSMOS- A SpaceTime Odyssey, Season 1 Disc 1-EPL_0101_t00.mkv
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00801.m2ts' at offset '0'
Failed to save title 1 to file E:/Video/COSMOS- A SpaceTime Odyssey, Season 1 Disc 1/COSMOS- A SpaceTime Odyssey, Season 1 Disc 1-EPL_0102_t01.mkv
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00802.m2ts' at offset '0'
Failed to save title 2 to file E:/Video/COSMOS- A SpaceTime Odyssey, Season 1 Disc 1/COSMOS- A SpaceTime Odyssey, Season 1 Disc 1-EPL_0103_t02.mkv
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00803.m2ts' at offset '0'
Failed to save title 3 to file E:/Video/COSMOS- A SpaceTime Odyssey, Season 1 Disc 1/COSMOS- A SpaceTime Odyssey, Season 1 Disc 1-EPL_0104_t03.mkv
0 titles saved, 4 failed
Dakinathon wrote:
Thu Feb 16, 2023 8:04 pm
Nah a firmware flash won't fix that it's either a disc issue or drive issue.
The usual steps are
Clean the disc
Replace the disc
Clean the drive
Replace the drive with a Wp/bp50nb40 BU40N ect... Or get a flashed and tested drive from one of the sellers
daave wrote:
Thu Feb 16, 2023 6:13 pm
Forget SGX. Rip the movie with either an official or friendly drive. Play with VLC or MPC.
daave
Post by daave »
Thank you Cooper. I have a laptop and I am buying a LG WH16NS40, what kind of adapter I need in order to use it?
See page 1 for enclosure and adapter options.
