No, I bought it a few years ago. I thought that I had seen availability but then I'm not actively looking....FrostBitten wrote: ↑Mon Jan 16, 2023 6:14 pmHave you gotten that recently? Because it seems that they're no longer available on the primary market...Mr_Orange wrote: ↑Mon Jan 16, 2023 6:15 amYou really don't have to buy a Pioneer. I have an LG BH16NS55 which is flashed with the WH16NS60_1.02MK firmware and it has, and continues to, perform flawlessly. I have ripped over 180 UHDs so far.FrostBitten wrote: ↑Mon Jan 16, 2023 6:02 amJust buy the out-of-box UHD capable pioneer drives if you can, and save yourself much angst and $$.
Ultimate UHD Drives Flashing Guide Updated 2024
I do have availability of this drive. See my seller page on this forumMr_Orange wrote: ↑Mon Jan 16, 2023 10:22 pmNo, I bought it a few years ago. I thought that I had seen availability but then I'm not actively looking....FrostBitten wrote: ↑Mon Jan 16, 2023 6:14 pmHave you gotten that recently? Because it seems that they're no longer available on the primary market...
Asmcom
Click Here! viewtopic.php?f=20&t=19387
I followed your advice, and I was able to start ripping UHDs through MakeMKV! Thanks a million!
Hello, I've been using a WH14NS40 with WH16NS60 1.02-MK and it seems to rip fine but it fails halfway through writing BD DL. It seems like Pioneer are the best drives to get now, although they are a little pricy. I am planning to get a BDR-XS07UHD, although I am not ripping UHD now but maybe in the future.
Have a WH16NS60 drive in a NST-536S3-BK enclosure on 1.02 firmware. Whenever I power on the enclosure I can rip a disc or two without an issue (4k or Blu-ray) but after that, whenever I put a disc in, I get the "No disc inserted" message. Luckily, powering off the drive and then powering it back on after a minute or so resolves the issue temporarily. But I keep having to do this. Any idea what the cause of this is or how to remedy it?
I have an LG BP50Nb40 UltraslimPortable Blu-ray Writer. I cannot find it listed in your instructions. I am building a website for film reviews, and I rip the extras from those discs to accompany a film's review: clips, trailers, stills, etc. At present, I only have HD Blu-ray discs, so I am able to rip them from my drive without a problem. I want the site to look as professional as possible, so I worry about the quality of an HD rip. If a visitor watches the trailer or clip I have embedded in a review article, It is small enough to be acceptable. But if the visitor chooses to watch it full-screen, the picture quality suffers. This is especially true for older films like Citizen Kane or Seven Samurai. For this reason, I have been considering buying a 4K copy of each film I review.
I have a few questions:
1. Can I flash the firmware on my particular 4K player? I should point out that I work on a Mac.
2. I have only seen flash files with .exe extension. Is there a flash file that will work for a Mac?
3. If I can and do flash my drive, will I still be able to rip from HD Blu-ray discs? (Some films are not available in 4K UHD.
4. What do you charge for remote flashing?
The quality issue is almost certainly due to transcoding/re-encoding/etc. being performed before/during the upload to your website. So ripping in 4K won't help.JSD50 wrote: ↑Wed Jan 18, 2023 7:05 pmI have an LG BP50Nb40 UltraslimPortable Blu-ray Writer. I cannot find it listed in your instructions. I am building a website for film reviews, and I rip the extras from those discs to accompany a film's review: clips, trailers, stills, etc. At present, I only have HD Blu-ray discs, so I am able to rip them from my drive without a problem. I want the site to look as professional as possible, so I worry about the quality of an HD rip. If a visitor watches the trailer or clip I have embedded in a review article, It is small enough to be acceptable. But if the visitor chooses to watch it full-screen, the picture quality suffers. This is especially true for older films like Citizen Kane or Seven Samurai. For this reason, I have been considering buying a 4K copy of each film I review.
Anyways, to answer your questions:
1. From OP:
2. From OP:Billycar11 wrote: ↑Mon May 27, 2019 5:20 amBP50NB40 to > BP50NB40-NB50-1.03MK then to > BP60NB10 1.02MK or 1.00MK
NB52 to > BP50NB40-NB50-1.03MK with enc > BP50NB40-NB50-1.03MK with bootloader/full flash > BP60NB10 1.00_HBD from Marty download/file.php?id=2143
if using command line add "full" after rawflash
3. YesBillycar11 wrote: ↑Mon May 27, 2019 5:20 amMac/linux commands to flash.
1. download sdf.bin https://makemkv.com/sdf.bin
2. download the all you need firmware pack
3. Extract the file you need for your drive from the all you need firmware pack pick from the recommended firmware section.
4. then in terminal on the Mac
copy sdf.bin and the firmware file extracted from theall you need firmware pack into /tmp folder.
5. in terminal change directory "cd /Applications/MakeMKV.app/Contents/MacOS"
6. type "./makemkvcon f -l"
This will show your drive identifier should look similar to this ''/IOBDServices/D5D25996'
Found 1 drives(s)
00: /IOBDServices/D5D25996, /dev/rdisk3, /dev/rdisk3
HL-DT-ST_BD-RE_BU40N_1.01_211910161032_MOFK6283224
7. to perform the flash, type "./makemkvcon f -d '/IOBDServices/D5D25996' -f /tmp/sdf.bin rawflash main -i /tmp/your firmware filename here
or ./makemkvcon f -d '/IOBDServices/D5D25996' -f /tmp/sdf.bin rawflash enc -i /tmp/your firmware filename here
if your firmware is on the encrypted list
4. From OP's signature:
Billycar11 wrote: ↑Mon May 27, 2019 5:20 amAuto flash kit $25 Email me for one Billycar5924@gmail.com
I'm curious if you're burning movies to BD DL and if so, why? I'm always fascinated by people's reasons. One person I remember was just trying to get movies into the back seat of the minivan for the kids. Another person was trying to get a copy of their movies to a second home.Ancela wrote: ↑Tue Jan 17, 2023 1:17 pmHello, I've been using a WH14NS40 with WH16NS60 1.02-MK and it seems to rip fine but it fails halfway through writing BD DL. It seems like Pioneer are the best drives to get now, although they are a little pricy. I am planning to get a BDR-XS07UHD, although I am not ripping UHD now but maybe in the future.
For people who want errorless results burning BD DL discs:Ancela wrote: ↑Tue Jan 17, 2023 1:17 pmHello, I've been using a WH14NS40 with WH16NS60 1.02-MK and it seems to rip fine but it fails halfway through writing BD DL. It seems like Pioneer are the best drives to get now, although they are a little pricy. I am planning to get a BDR-XS07UHD, although I am not ripping UHD now but maybe in the future.
https://forum.redfox.bz/threads/the-lon ... -tl.86133/
I'm trying to watch 3D movies on my 3D TV. I haven't been able to get any players to work with MKV (MK3D).dcoke22 wrote: ↑Thu Jan 19, 2023 7:11 amI'm curious if you're burning movies to BD DL and if so, why? I'm always fascinated by people's reasons. One person I remember was just trying to get movies into the back seat of the minivan for the kids. Another person was trying to get a copy of their movies to a second home.Ancela wrote: ↑Tue Jan 17, 2023 1:17 pmHello, I've been using a WH14NS40 with WH16NS60 1.02-MK and it seems to rip fine but it fails halfway through writing BD DL. It seems like Pioneer are the best drives to get now, although they are a little pricy. I am planning to get a BDR-XS07UHD, although I am not ripping UHD now but maybe in the future.
I got a Pioneer XS07UHD and it burned and played back no problem!
Hello together,
I've a question regarding my BD/UHD Drive. It is an Asus BC-12D2HT from late 2018 that I bought some years ago without knowing about this guide. But a short search showed be it might work with it.
Firmware version is 3.01, so it should be relatively easy to flash.
If I understand everything right I should use the BC-12D2HT_3.11_MK with the SDFtool Flasher.
Bootloader and everything else isn't needed and better avoided.
I would just like to be sure I understand everything correctly before I start and in the worst case brick the drive.
Post your Makemkv info. Most important it should use the MT1959 chip. If MT1939 it is not UHD compatible.RoyalNuts wrote: ↑Fri Jan 20, 2023 12:15 pmHello together,
Here is the info without the serial number.Coopervid wrote: ↑Fri Jan 20, 2023 5:41 pmPost your Makemkv info. Most important it should use the MT1959 chip. If MT1939 it is not UHD compatible.RoyalNuts wrote: ↑Fri Jan 20, 2023 12:15 pmHello together,
OS device name: /dev/rdisk6
Manufacturer: ASUS
Product: BC-12D2HT
Revision: 3.01
Serial number:-----
Firmware date: 2117-11-15 19:26
Bus encryption flags: 1E
Highest AACS version: 68
Harware support: Yes
Firmware support: No
Firmware version: 3.01
Unrestricted read speed: Possible (with patched firmwar
Correct.RoyalNuts wrote: ↑Fri Jan 20, 2023 12:15 pmHello together,
You are good to go to flash.
