LibreDrive for Pioneer drives
I have the BDR-212V on Firmware 1.02. It is coming up as possibly supported, so I would appreciate it if you updated the list. Info below:
OS device name: H:
Manufacturer: PIONEER
Product: BD-RW BDR-212V
Revision: 1.02
Serial number: UADL004799WL
Firmware date: 2022-05-31
Bus encryption flags: 13
Highest AACS version: 18
Firmware version: ID06
OS device name: H:
Revision: 1.02
I just posted this on the previous page:mastercko wrote: ↑Sun Jan 08, 2023 1:13 pmHi,
OS device name: H:
Revision: 1.02
In the first place you don't need Libredrive support if you stick to DVDs or BDs. If you want it and it says something like "possible" you need to send the information for your drive to Mike. It has been posted in this thread what you have to send.
See the post of mike_admin:
viewtopic.php?f=19&t=27378&p=129189&hil ... er#p129189
Hi,Coopervid wrote: ↑Sun Jan 08, 2023 1:40 pmI just posted this on the previous page:
Thanks for pointing me in the right direction. I must have skimmed over and missed your earlier post, apologies. I sent the dump file mentioned in the linked post from mike_admin to support@makemkv.com. Please let me know if there is anything else that is needed from my end.
Usually not. You need to have internet access enabled in Makemkv for the updates to happen in the background.mastercko wrote: ↑Sun Jan 08, 2023 5:09 pmHi,Coopervid wrote: ↑Sun Jan 08, 2023 1:40 pmI just posted this on the previous page:
Hi Guys,
I'm new in this forum. I've got my new computer case who comes without 5,25" slot, so I've changed my Blu-ray drive following some recomandations to a Verbatim... well a Pioneer BD-RW BDR-UD04 more exactly.
It reads both BluRay and UHD Bluray BUT the quality is inconsistent. On recent UHDs the image is just fine but I've got some lag issues every minute with VLC and others readers like MPHC. With an old Bluray the image is fine too but if I try to move up further in the movie I've got a lot of glitches.
Here are the informations about my actual reader from MakeMKV.
As I've read all topics about LibreDrive I didn't need to flash my actual drive. But Is it a common problem ? Reading Blurays was perfectly fine with my old LG 5,25" SATA drive, but can it be the same with a recent Drive ?
Thanks in advance for you're help.
Informations lecteur
Nom du lecteur SE : G:
Fabricant : PIONEER
Produit : BD-RW BDR-UD04
Révision : 1.14
Numéro de série : nope
Date micrologiciel : 2020-06-15
Marqueurs d'encryptage bus : 1B
Version AACS la plus haute : 68
Drive platform: RS8A10
Firmware version: 1.14
Hello TomatoFrito,TomatoFrito wrote: ↑Tue Jan 10, 2023 11:48 pmHi Guys,
As I've read all topics about LibreDrive I didn't need to flash my actual drive. But Is it a common problem ? Reading Blurays was perfectly fine with my old LG 5,25" SATA drive, but can it be the same with a recent Drive ?Code: Select all
Informations lecteur Nom du lecteur SE : G: Fabricant : PIONEER Produit : BD-RW BDR-UD04 Révision : 1.14 Numéro de série : nope Date micrologiciel : 2020-06-15 Marqueurs d'encryptage bus : 1B Version AACS la plus haute : 68 LibreDrive Information Status: Enabled Drive platform: RS8A10 Firmware name: PIONEER BDR-US04 Firmware type: Original (unpatched) Firmware version: 1.14 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
You must have a faulty drive. This is very unusual. We have sold over 250 of these drives and all positive reviews. Sent it back to the supplier as this should not be happening. Very unusual for a Pioneer Drive. The seller must not have tested this drive. We test each drive with 4 discs including playback test.
Kind Regards
Sean
UHD Friendly Drives
Click Here! viewtopic.php?f=20&t=19387
What's you PC specs maybe it can't decode h.265TomatoFrito wrote: ↑Tue Jan 10, 2023 11:48 pmHi Guys,
Hi asmcom,asmcom wrote: ↑Wed Jan 11, 2023 12:45 amHello TomatoFrito,TomatoFrito wrote: ↑Tue Jan 10, 2023 11:48 pmHi Guys,
Kind Regards
Sean
UHD Friendly Drives
Thanks for you're answer,
Well, it's a original model bought from Amazon, in this case should I get one from one of the eBay sellers ? I Thought it will work without flash or any other modification.
Best regards.
Hi Billycar11,Billycar11 wrote: ↑Wed Jan 11, 2023 4:49 amWhat's you PC specs maybe it can't decode h.265TomatoFrito wrote: ↑Tue Jan 10, 2023 11:48 pmHi Guys,
My PC is brand new and export video with h.265 hardware encoding. (Ryzen 7 7700x, B650E chipset MB, Nvidia RTX 3090, Windows 11).
Best regards.
Send the drive back to Amazon and ask for a replacement.TomatoFrito wrote: ↑Wed Jan 11, 2023 5:49 amHi asmcom,asmcom wrote: ↑Wed Jan 11, 2023 12:45 amHello TomatoFrito,TomatoFrito wrote: ↑Tue Jan 10, 2023 11:48 pmHi Guys,
Kind Regards
Sean
UHD Friendly Drives
Best regards.
Kind Regards
Asmcim
I ordered and just received the Pioneer BDR-XD08UMB-S, and... holy... this thing is SO small. Amazing. It's practically the size of a single CD case. And in theory this should be more reliable than the giant ASUS BW-16D1X-U I've been using for the last 3 weeks? Amazing. Have not tested it yet... later tonight. Been very impressive, hardware-wise, so far...Coopervid wrote: ↑Wed Jan 04, 2023 10:47 amCheck the list in this post.b@ner#les wrote: ↑Wed Jan 04, 2023 3:18 amI have a recently purchased ASUS BW-16D1X-U. When it works, great. But I often have to try again, or just rip a few chapters at a time, otherwise it inevitably errors out and then i have to restart makemkv, and/or reboot my machine (windows 10). My 4k "Empire Strikes Back" simply refuses to rip on this drive (and I've tried a 2nd copy of Empire--same issue). SO... looking at trying another drive while I can still return this one. I'm considering a new Pioneer. Suggestions on which model? I have an M1 mac pro as well as hi-end Gaming PC (windows 10), so external drive is ideal. Suggestions on which pioneer?
viewtopic.php?f=16&t=19634
Any of the Pioneer slim drives that connect via USB should be appropriate for your needs.
PLugged it in, and did not even require a power cable (powered via the USB-C cable). MakeMKV recognized it instamagically, and it successfully ripped my 4K Empire Strike Back on the first try! Nice. Returning the ASUS drive--this pioneer is a keeper. And it is so freakin' small!b@ner#les wrote: ↑Thu Jan 12, 2023 8:22 pmI ordered and just received the Pioneer BDR-XD08UMB-S, and... holy... this thing is SO small. Amazing. It's practically the size of a single CD case. And in theory this should be more reliable than the giant ASUS BW-16D1X-U I've been using for the last 3 weeks? Amazing. Have not tested it yet... later tonight. Been very impressive, hardware-wise, so far...Coopervid wrote: ↑Wed Jan 04, 2023 10:47 amCheck the list in this post.b@ner#les wrote: ↑Wed Jan 04, 2023 3:18 amI have a recently purchased ASUS BW-16D1X-U. When it works, great. But I often have to try again, or just rip a few chapters at a time, otherwise it inevitably errors out and then i have to restart makemkv, and/or reboot my machine (windows 10). My 4k "Empire Strikes Back" simply refuses to rip on this drive (and I've tried a 2nd copy of Empire--same issue). SO... looking at trying another drive while I can still return this one. I'm considering a new Pioneer. Suggestions on which model? I have an M1 mac pro as well as hi-end Gaming PC (windows 10), so external drive is ideal. Suggestions on which pioneer?
Hi guys,
at the moment I'm using a Verbatim 4K BD RW (Pioneer BDR-UD04). I tried to backup with the latest MakeMKv version the UHD "last action hero". But I got SCSI errors
The sdftool tells me:
Status: not enabled. But the first post of this thread says it is enabled.
What is the problem here?
Thanks a lot
Sebastian
sdftool -d /dev/sr1 --info
SDF.bin version: 0x0090
Drive Tool SDF present
Drive Specific SDF present
[Drive Specific SDF] Embedded Info Strings:
8000:LibreDrive Information
8013:Status
8105:Enabled
8001:Drive platform
:RS8A10
8015:Firmware name
:PIONEER BDR-US04
8002:Firmware type
8106:Original (unpatched)
8003:Firmware version
:1.14
8005:DVD all regions
8100:Yes
8006:BD raw data read
8100:Yes
8007:BD raw metadata read
8100:Yes
8009:Unrestricted read speed
8100:Yes
[Drive Specific SDF] Embedded Status Message:
8099:Using LibreDrive mode (v%1 id=%2)
:01.0
:489CDFD6D392
Identification SDF present
8013:Status
8001:Drive platform
:Pioneer RS8A10
:GENE
pioneer:SAT :8A10:GENE:RAL :PIONEER :BD-RW BDR-UD041.14: 20/06/15 :-
Thanks a lot
Sebastian
Clean your disc!Pace17881 wrote: ↑Sat Jan 14, 2023 8:04 pmHi guys,
The sdftool tells me:Status: not enabled. But the first post of this thread says it is enabled.Code: Select all
sdftool -d /dev/sr1 --info SDF.bin version: 0x0090 Drive Tool SDF present Drive Specific SDF present [Drive Specific SDF] Embedded Info Strings: 8000:LibreDrive Information 8013:Status 8105:Enabled 8001:Drive platform :RS8A10 8015:Firmware name :PIONEER BDR-US04 8002:Firmware type 8106:Original (unpatched) 8003:Firmware version :1.14 8005:DVD all regions 8100:Yes 8006:BD raw data read 8100:Yes 8007:BD raw metadata read 8100:Yes 8009:Unrestricted read speed 8100:Yes [Drive Specific SDF] Embedded Status Message: 8099:Using LibreDrive mode (v%1 id=%2) :01.0 :489CDFD6D392 Identification SDF present [Identification SDF] Embedded Info Strings: 8000:LibreDrive Information 8013:Status 8102:Possible, not yet enabled 8001:Drive platform :Pioneer RS8A10 8003:Firmware version :GENE [Identification SDF] Drive autodetect string: pioneer:SAT :8A10:GENE:RAL :PIONEER :BD-RW BDR-UD041.14: 20/06/15 :-
Thanks a lot
Sebastian
hi,
After cleaning the disc the scsi errors are gone. But the disc could not be read. After a reboot and some retries it works now.
Then i tried the next uhd disc (Eternals) and I got the following error:
After some retries it worked also for this disc. Is my new pioneer drive broken? I bought it yesterday....
MakeMKV v1.17.2 linux(x64-release) started
Using LibreDrive mode (v01.0 id=489CDFD6D392)
Evaluation version, 19 day(s) out of 30 remaining
Saved AACS dump file as /home/sebastian/.MakeMKV/MKB20_v76_MARVEL_STUDIOS'_ETERNALS_-_ULTRA_HD_FE31.tgz
