Looking for UHD compatible 9.5mm internal drive
dproton
Post by dproton »
Hi all
Forum newbie......appreciate any support in advance...I have look thru the forum and have yet to find any 9.5mm slot in drive that would support MakeMKV for regular 4K and 4kUHD disks. Have experience using the 5.25 drives with MakeMKV with windows machines but looking now to do some mod with a Mac. Thanks!!!!!
Re: Looking for UHD compatible 9.5mm internal drive
Look here:
viewtopic.php?f=16&t=19634
For best ripping results I would advise a Pioneer drive. If you are not in a hurry please wait a bit. There is WIP to flash cheaper Pioneer drives to make them UHD compatible. If you don't want to wait pick one Pio from the list or the next best LG is a BU40N.
asmcom
Post by asmcom »
dproton wrote:
Fri Nov 11, 2022 8:50 pm
Hi all
I have Pioneer Slot drives available that work just fine with MakeMKV. The silver is very popular with MAC OS. Please see pictures in eBay links. I offer 5% discount for MakeMKV forum members, see 1st Weblink below for details and how to apply for discount.
viewtopic.php?t=19387
https://www.ebay.co.uk/itm/265976501057
https://www.ebay.co.uk/itm/265630912065
Kind Regards
Asmcom
