Is my WH16NS60 just plain junk?
thirdgen89gta
Post by thirdgen89gta »
OS device name: /dev/rdisk7
Product: BD-RE WH16NS60
Revision: 1.03
Serial number: M00L8J85112
Firmware date: 2120-05-08 10:10
Highest AACS version: 77
Firmware version: 1.03
About a year ago in January I bought a new WH16NS60 to replace my ASUS that died, and its worked fine for 1080p discs, but it seems the number of 4K discs that fail to rip and report Hash, Read, and corruption errors is way too high to be a bad disc.
Rather frustrated because I paid $120 for this drive not even a year ago and I've got about 5 discs I just can't rip due to corruption errors, has errors..etc.
Below is an example of just one rip on a brand new disc just opened out of the box, but I have 3 others I can't rip at all, Annihilation, Ender's Game, and 300.
Disc Information
Label: STAR_TREK_TMP_DIRECTOR_EDITION
Timestamp: 2022-07-11 16:31:50
Protection: AACS2.0/C v77
Data capacity: 83.50 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
Using LibreDrive mode (v06.3 id=4083C4CCDB14)
Backing up disc into folder "/Volumes/RipStorage/STAR_TREK_TMP_DIRECTOR_EDITION"
Hash check failed for file 00294.m2ts at offset 33074571264, file is corrupt.
Hash check failed for file 00294.m2ts at offset 33279633408, file is corrupt.
Hash check failed for file 00294.m2ts at offset 33280026624, file is corrupt.
Hash check failed for file 00294.m2ts at offset 33280223232, file is corrupt.
Hash check failed for file 00294.m2ts at offset 33280616448, file is corrupt.
Too many hash check errors in file 00294.m2ts.
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00294.m2ts' at offset '33584185344'
Failed to save title /BDMV/STREAM/00294.m2ts to file /Volumes/RipStorage/STAR_TREK_TMP_DIRECTOR_EDITION/BDMV/STREAM/00294.m2ts
Encountered 5 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
Encountered 111 errors of type 'HashCheck Error' - see http://www.makemkv.com/errors/hashcheck/...
Backup done but 1 files failed hash check
Re: Is my WH16NS60 just plain junk?
thirdgen89gta wrote:
Tue Nov 08, 2022 11:37 pm
Revision: 1.03
Disc Information
Number of layers: 3
Did you try cleaning your UHD discs? Use soapy water and wipe off with a microfibre cloth.
thirdgen89gta
They are clean as a whistle, not a spec of anything anywhere, brand new out of the case. There is literally nothing to clean. One disc, maybe.
But 7 discs in a row having issues? I can't imaging its the discs with that kind of failure rate.
demon
Post by demon »
My WH16NS60 stopped reading anything but DVDs awhile back, while my BU40Ns continue to work fine. The same may have happened to you.
Wed Nov 09, 2022 3:10 am
Most UHD's have an invisible to the naked eye film on them from processing that can cause read issues. Try cleaning them!! You won't know for sure until you try.
I often have to clean brand new UHDs before I can read them.
thirdgen89gta
I've never had to clean the discs, and they have not a spot of imperfection. I can't see this many discs in a row failing. And I have cleaned them but I should not have to clean them if they are spotless.
I cut many repetitive lines out of the log.
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 28491933696, attempting to work around
Hash check failed for file 00000.m2ts at offset 30394017792, file is corrupt.
Too many hash check errors in file 00000.m2ts.
AV sync issue in stream 0 at 0:52:15.674 : video frame timecode differs by +41.702ms
AV sync issue in stream 0 at 0:52:15.757 : video frame timecode differs by +41.708ms
AV sync issue in stream 0 at 0:52:15.715 : video frame timecode differs by +41.705ms
AV sync issue in stream 0 at 0:52:15.674 : secondary stream video frame timecode differs by +41.702ms
AV sync issue in stream 0 at 0:52:15.674 : secondary stream video frame timecode differs by -41.708ms
AV sync issue in stream 0 at 0:52:15.590 : secondary stream video frame timecode differs by +83.408ms
AV sync issue in stream 0 at 0:52:15.590 : secondary stream video frame timecode differs by +208.541ms
AV sync issue in stream 0 at 0:52:15.590 : secondary stream video frame timecode differs by +166.83ms
AV sync issue in stream 0 at 0:52:15.715 : secondary stream video frame timecode differs by +166.827ms
Failed to save title 1 to file /Users/william/Movies/Star Trek III- The Search for Spock/Star Trek III- The Search for Spock_t01.mkv
Encountered 1926 errors of type 'HashCheck Error' - see http://www.makemkv.com/errors/hashcheck/...
0 titles saved, 1 failed
Backing up disc into folder "/Volumes/RipStorage/STAR_TREK_IV_TVH"
Hash check failed for file 00007.m2ts at offset 27583309824, file is corrupt.
Hash check failed for file 00007.m2ts at offset 27754752000, file is corrupt.
Hash check failed for file 00007.m2ts at offset 27801151488, file is corrupt.
Hash check failed for file 00007.m2ts at offset 28551407616, file is corrupt.
Hash check failed for file 00007.m2ts at offset 28634572800, file is corrupt.
Too many hash check errors in file 00007.m2ts.
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00007.m2ts' at offset '31757697024'
Failed to save title /BDMV/STREAM/00007.m2ts to file /Volumes/RipStorage/STAR_TREK_IV_TVH/BDMV/STREAM/00007.m2ts
Encountered 6 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
Encountered 12638 errors of type 'HashCheck Error' - see http://www.makemkv.com/errors/hashcheck/...
Post by SamuriHL »
Are you using a microscope to check how clean they are? If not then your claims of "spotless" are meaningless. Uhd discs pack data into a very small space and any imperfection will cause issues. Even ones you can't see.
Wed Nov 09, 2022 1:04 pm
Don't be stubborn and listen to the advice to clean the disc. Then try again.
thirdgen89gta
Not being stubborn, I DID clean them, it just made no difference.
The sheer number of discs that fail to rip with hash check, and report AV Sync or Corruption issues is far too high.
Hence, the WH16NS60 is just junk and I don't think I'd want to replace it with another one.
MakeMKV v1.17.2 darwin(arm64-release) started
Optical drive "BD-RE HL-DT-ST BD-RE WH16NS60 1.03 M00L8J85112d" opened in OS access mode.
Hash check failed for file 00007.m2ts at offset 29108004864, file is corrupt.
Hash check failed for file 00007.m2ts at offset 29244057600, file is corrupt.
Hash check failed for file 00007.m2ts at offset 29261555712, file is corrupt.
Hash check failed for file 00007.m2ts at offset 29266667520, file is corrupt.
Hash check failed for file 00007.m2ts at offset 29269616640, file is corrupt.
Encountered 28008 errors of type 'HashCheck Error' - see http://www.makemkv.com/errors/hashcheck/...
Backup failed
asmcom
Post by asmcom »
Sorry to hear you are having trouble with your WH16NS60. You should really buy a Hitachi BU40N or a Pioneer Drive. The Hitachi WH16NS60 is getting that bad that I have decided to stop selling them and now I am offering them at clearance prices. Hitachi has told me they are EOL product now and are offering at very cheap prices. I am selling the Hitachi Desktop drives very cheap just to clear, as the product no longer seems to be reliable. Billycarr stated on his seller page that he had found around 25% of these desktop drives to be defective and he no longer was selling them. I am finding the same here in Europe. Three years ago this was not the case. Sad to see such a good product no longer reliable. I have been testing the Pioneer BDR-XS07TS Cross-flashed to BDR-XS07TUHD and it is incredible to say the least. Any 4K disc I insert, it reads the disc in seconds. It has backed up these BD100 titles below without a hitch. If you are in the US I suggest you buy a BU40N of Billycarr or a Hitachi drive. The BU40N is a great drive and so is the Hitachi Slim drive.
viewtopic.php?f=20&t=17831
Please see drive below on eBay.
https://www.ebay.co.uk/itm/265976501057
Kind regards
Asmcom :mrgreen:
thirdgen89gta
That is extremely disappointing to here that the general level of quality on these drives has dropped so far considering their cost.
I've had DVD drives and DVD burners that were approaching 10+ years, and the only reason I stopped using them was so I could replace them with Blu-Ray drives. I bet if I took one off the shelf even after it sat for nearly 3 years it would still be working.
As the BU40N is a slim drive is there any issue flashing it via USB? I have one of the Vantec enclosures that doesn't allow flashing, but its not big to get an 18" SATA & Power cable off my gaming PC to flash a drive.
Sat Nov 12, 2022 4:14 am
all cases that work with optical drives should now support flashing the developer made a workaround for lg/asus drives.
flashing over usb has been fine for like 3+ years now no usb was only in the dos flash days
AlloAllo
Post by AlloAllo »
asmcom wrote:
Thu Nov 10, 2022 12:57 am
Kind regards
Asmcom :mrgreen:
I think I just bought one of these 🤣🤦... I'm sure will be fine for my purposes though.
Out of curiosity do we know the root of the failures? is it tolerances on the laser carriage guides, or inconsistencies in the speed of the motor drive? I find it surprising that these fail that often, I guess must be manufacturing tolerances, and shows up more often with the data density of multi layer Blurays
asmcom
Post by asmcom »
:roll:
AlloAllo wrote:
Mon Nov 14, 2022 7:59 pm
Kind regards
Asmcom :mrgreen:
I am fortunate that I have a good relationship with Hitachi. On my last order of drives, I found after testing each drive with 4 discs, "BD100, BD66, DVD and 1080P Blur-ay" , that I had a 20% failure rate. I sent the failed drives back to Hitachi for replacement.
Three years ago I might have had 1 faulty Hitachi desktop drive in 100 units. So to be honest I don't know what has happened.
The BU40N's are a completely different story. I have had none faulty in over 1000 drives, so they are extremely reliable.
I did have a batch before Covid 19 that were making circular scrapes on the discs and destroying the discs, but Hitachi quickly sorted this problem out.
With Pioneer, I have had no faulty units to date, which is a good sign.
Kind Regards
Asmcom :mrgreen:
