LG internal WH16NS40 Blu-Ray drive can't read UHD disc
Re: LG internal WH16NS40 Blu-Ray drive can't read UHD disc
Sometimes the problem is located between the keyboard and the screen.
. Glad it worked!
Stevelois
Indeed and we call that a "code 18".
Nonetheless, I often flash the bios / firmware of various drive while the tray was opened and never had any issue at all. Also, it was only my last flashing attempts the tray was opened, all previous ones, the tray was closed with no disc ofc. But I'm happy I could finally rip the disc
I learned a new expression "code 18". Is there anything that also resembles a "forehead installation"? People expecting everything installing OK with just letting their forehead fall on the keyboard and the program will install magically?
Stevelois
Well I live in Québec province of Canada and "code 18" is a common expression from IT's like me meaning the problem is at 18 inch from the computer screen
So in the end, it's a mistake from the user
There is no expression that resembles of "forehead installation" and the meaning isn't the same as "code 18"
daaajester
Hey steve, for the ns60 drive where did you find the 1.03 firmware?? I checked the post you linked and could not find the mentioned file. Is there anyway you could email me a link directly to it and the firmware installer you used?? My drive is refusing to recognize any 4k discs now it seems.
See guide below has the solution to all your problemsdaaajester wrote: Tue Mar 14, 2023 11:29 am Hey steve, for the ns60 drive where did you find the 1.03 firmware?? I checked the post you linked and could not find the mentioned file. Is there anyway you could email me a link directly to it and the firmware installer you used?? My drive is refusing to recognize any 4k discs now it seems.
It's in the MK firmware pack. Note: WH16NS60 1.03. For BH16NS60 the max. version is 1.02.daaajester wrote: Tue Mar 14, 2023 11:29 am Hey steve, for the ns60 drive where did you find the 1.03 firmware?? I checked the post you linked and could not find the mentioned file. Is there anyway you could email me a link directly to it and the firmware installer you used?? My drive is refusing to recognize any 4k discs now it seems.
asmcom
Do not install 1-03 it is of poor performance. 1-02mk is the bestCoopervid wrote: Tue Mar 14, 2023 2:43 pmIt's in the MK firmware pack. Note: WH16NS60 1.03. For BH16NS60 the max. version is 1.02.daaajester wrote: Tue Mar 14, 2023 11:29 am Hey steve, for the ns60 drive where did you find the 1.03 firmware?? I checked the post you linked and could not find the mentioned file. Is there anyway you could email me a link directly to it and the firmware installer you used?? My drive is refusing to recognize any 4k discs now it seems.
Asmcom
