LibreDrive for Pioneer drives
#331 Post by Coopervid » Tue Nov 01, 2022 10:16 pm
techguymaxc wrote: Tue Nov 01, 2022 9:04 pm Got my new BDR-X13UBK drive and it isn't reading 4k discs. It was my understanding that Pioneer drives containing "U" in the model number all have UHD reading capability, but I have tried several discs and none read, same as the last Pioneer drive that didn't have a "U". When I open MakeMKV with a disc already in the drive nothing happens. When I put a new disc in, MakeMKV sees a disc has been inserted and attempts to read, then gives up after a minute and says "No disc inserted".
Here's the status window info:
Manufacturer: PIONEER
Product: BD-RW BDR-X13
Revision: 1.01
Serial number:
Firmware date: 2022-02-18
Highest AACS version: 77
Drive platform: Pioneer RS9400
Firmware version: ID56
I Told you you should have waited.... There is a X13U 1.01 on the list but the firmware might differ. Send a PM to mike admin and he can dump your firmware to his server to add support.
techguymaxc
#332 Post by techguymaxc » Tue Nov 01, 2022 10:21 pm
Thanks,
I'll PM Mike.
#333 Post by Coopervid » Wed Nov 02, 2022 11:31 am
A big warning to everybody purchasing UHD capable Pioneer full size drives!!!
Starting with the 13 series you can't assume anymore that the letter "U" in their drive names also allows UHD capability!!!!
These are UHD capable:
X13U-S
S13UBK
S13U-X
This is NOT UHD capable:
X13UBK
Edited and corrected on Nov. 3rd, 2022.
techguymaxc
#334 Post by techguymaxc » Wed Nov 02, 2022 2:11 pm
Lol
#335 Post by Coopervid » Wed Nov 02, 2022 2:11 pm
Read your PM
asmcom
#336 Post by asmcom » Thu Nov 03, 2022 1:03 am
Coopervid wrote: Wed Nov 02, 2022 11:31 am A big warning to everybody purchasing UHD capable Pioneer full size drives!!!
X13U-S
S13UBK
These are NOT UHD capable:
X13UBK
S13U-X
S13U-X should be UHD capable unless I am reading something wrong?
COMPUTER DRIVES
BDR-S13U-X
Premium model for computer videophiles Internal BD/DVD/CD Writer with PureRead 4+ , RealTime PureRead and M-DISC™ Support Equipped with an audio CD playback quality checking function. All-black housing with vibration and noise reduction coating
The latest version of PureRead 4+ and RealTime PureRead
Audio CD checking function
Up to 6x writing on M-DISC(BD) SL and M-DISC(DVD)
CyberLink PowerDirector® 19 for video editing and BD/DVD authoring (available for download free of charge)
High-quality front design
Windows® 11 Compatible
Up to 16x1 maximum write speed on BD-R media
VIEW MORE
PRICE$290BUY
/StaticFiles/PUSA/Images/Product Images/Computer/BDR-211UBK/BDR-S13U-X-main-1angled_800x600.jpg/StaticFiles/PUSA/Images/Product Images/Computer/BDR-211UBK/BDR-S13U-X-strait1_800x600.jpg
OVERVIEW
SPECS
KEY FEATURES
Ultra HD Blu-ray compatible
Yes
M-DISC compatible
Yes
CD-DA(audio CD)playback quality checking function
Yes
PureRead 4+
Yes
Custom Eco function
Yes
Display disc information
Yes
Easy Setting
Yes
Dust-resisting and sound-dampening front bezel
Yes
Honeycomb structure
Yes
High-quality loading mechanism and noise reduction finish
Yes
All-black housing with special coating to reduce vibration, improve heat dissipation
Yes
Low-noise electrolytic capacitors
Yes
Low-resistance flat cable
Yes
Anti-vibration cushions and rubber
Yes
Copper-plated screws
Yes
Pioneer BD Drive Utility
Yes
Dust-resisting and sound-dampening mechanism
Yes
PEAK POWER REDUCER
Yes
BDXL compatible
Yes
Optimum Writing Speed Feature
Yes *This function emphasizes writing accuracy by automatically selecting the optimum writing speed for various BD-R media
Optimal Write Strategy Prediction Algorithm
Yes
Disc Record Surface Quality Mode
Yes *This mode reduces the apparent color unevenness of the disc after writing.
DVD-R CLV fixed writing mode
Yes *When writing a DVD-R, the writing method is fixed to CLV. This mode reduces the apparent color unevenness of the disc while maintaining the writing accuracy
MINIMUM SYSTEM REQUIREMENTS - 4K ULTRA HD BLU-RAY
Operating System
Windows®11, Windows 10
CPU
7th generation Intel Core® i7/i5 processor for Desktop PC (Kaby Lake-S), 7th generation Intel Core i7/i5 processor for Notebook PC (Kaby Lake-H) *U processor is incompatible
GPU
Intel® HD Graphics 630 (Internal GPU for 7th generation processor)
Memory
6GB minimum
External Display
HDMI 2.0a and HDCP² 2.2 compatible, 4K display (3840 x 2160 minimum display resolution), HDR compatible (Incompatible display reproduces HDR contents with HDR>SDR format.)
Motherboard
Intel SGX(Software Guard Extensions) support Intel 200 series motherboard, HDCP² 2.2/HDMI 2.0a output compatible, Intel internal GPU output compatible
Ultra HD Blu-ray compatible, with playback software included
Ultra HD Blu-ray offers 4K resolution as well as richer color tones, for more realistic images.
*Playback of Ultra HD Blu-ray requires a CPU that supports Intel Software Guard Extensions (Intel SGX) technology. Intel SGX has been removed from Intel 11th generation and newer CPUs, and support for SGX may be removed on new versions of Intel drivers or utility programs such as Intel SGX and Intel Management Engine drivers and firmware in the future. Such changes could cause these platforms to lose support for Ultra HD Blu-ray movie disc playback.
For information on other PC environment requirements, download the Ultra HD Blu-ray Advisor Tool to your PC, and check. https://pioneer.jp/device_e/product-e/ibs/eula.php
#337 Post by Coopervid » Thu Nov 03, 2022 9:18 am
I have to correct myself. The S13U-X is UHD capable. The US site must have been corrected since it was listed as not UHD compatible. I will modify my post above.
asmcom
#338 Post by asmcom » Thu Nov 03, 2022 9:23 am
I have order a couple of these models to test amongst others. When I saw your post I thought I would double check in case Pioneer USA had given me wrong information.
Anyway no harm done and have a nice day.
Asmcom :mrgreen:
tmackery
#339 Post by tmackery » Fri Nov 04, 2022 2:06 am
Just bought the BDR-X13U-S . It looks like the firmware should be supported (X13U 1.01) but I'm still getting a Status of "Possible, not yet enabled" even after enabling internet access. Is there something I'm missing or forgetting to do? Or is it not supported yet?
OS device name: F:
Product: BD-RW BDR-X13U
Revision: 1.01
Serial number:
Firmware date: 2022-02-28
Highest AACS version: 61
Firmware version: ID29
larry.schapker
#340 Post by larry.schapker » Fri Nov 04, 2022 2:29 am
I too am having issues with a newly received Pioneer BDR-X13U-S.
I load a UltraHD disk (i.e. Deadpool) into the drive and using MakeMKV v1.17.2 on Kubuntu (KDE Ubuntu), the app can see the disk, but not "open" the disk:
From the "Info pane"
OS device name: /dev/sr2
Revision: 1.01
Serial number: XXXXXXXXXXX
Highest AACS version: 60
Disc Information
Label: DEADPOOL
Timestamp: 2016-04-05 14:48:45
Protection: AACS2.0/C v60
Data capacity: 54.54 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
Snippet from the log after attempting to open the disk:
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..03F to device 'SG:dev_21:7'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..0020..03F to device 'SG:dev_21:7'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..07F to device 'SG:dev_21:7'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..0020..07F to device 'SG:dev_21:7'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..0BF to device 'SG:dev_21:7'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..0020..0BF to device 'SG:dev_21:7'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..0FF to device 'SG:dev_21:7'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..0020..0FF to device 'SG:dev_21:7'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..002000800 to device 'SG:dev_21:7'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SG:dev_21:7'
Saved AACS dump file as /home/larry-local/.MakeMKV/MKB20_v60_Deadpool_4B6D.tgz
Not sure what other information I should be providing. Please advise!
Thank you!
#341 Post by Coopervid » Fri Nov 04, 2022 10:51 am
Guys, don't just post - read.
This applies to both larry.schapker and tmackery. Just a few posts above I stated:
X13U-S
S13UBK
S13U-X
X13UBK
larry.schapker
#342 Post by larry.schapker » Fri Nov 04, 2022 3:01 pm
Agreed. I seen your post, but my drive is supported supposedly.
#343 Post by dcoke22 » Fri Nov 04, 2022 3:24 pm
Coopervid wrote: Fri Nov 04, 2022 10:51 am These are UHD capable:
X13U-S
S13UBK
S13U-X
X13UBK
As I understand it, both larry.schapker and tmackery said they have a BDR-X13U-S which is UHD compatible I think. Perhaps mike admin needs a firmware dump to be able to specifically support those drives?
#344 Post by Coopervid » Fri Nov 04, 2022 3:29 pm
Oops. Yes. These Pioneer product codes drive me nuts. Yes, they should conatct mike to upload their firmware to his server.
larry.schapker
#345 Post by larry.schapker » Fri Nov 04, 2022 4:30 pm
Coopervid wrote: Fri Nov 04, 2022 3:29 pm Yes, they should conatct mike to upload their firmware to his server.
I'll be glad to do so if I have some basic instructions (i.e. I'm new to "driver Firmware" <grin>). A simple list of instructions (maybe there is a link?) would help greatly.
