good question, and I'm not sure.
I guess Makemkv or bdinfo can list all the mpls files (episodes order) and then you can use tsmuxer, as usual, to make a bdmv folder for each episode.
I used your script to list the mpls files, it basically lists them in the correct order (one episode after the other). Then I imported every playlist separately into tsmuxer and made separate BluRay folders for each episode. Works like a charm! Thank you!RESET_9999 wrote: ↑Sun Aug 07, 2022 12:26 pmgood question, and I'm not sure.
@deadchip suggested this. Not sure if he tried.sofakng wrote: ↑Sun Aug 07, 2022 2:43 pmDoes anybody have any clever solutions when using a USB HDD on the Sony x800m2?
It seems like a pain to unplug the hard drive, connect to a PC and update the movies, and then reconnect it, etc.
Are there any wifi hard drives or anything to make this process easier and not require unplugging the drive?
The main reason I'm interested in this is for the BDMV support so I don't need to manually enable force subtitles?
I heard it is very unstable when working with hard drive, so I no longer want to test it.RESET_9999 wrote: ↑Sun Aug 07, 2022 2:59 pm@deadchip suggested this. Not sure if he tried.sofakng wrote: ↑Sun Aug 07, 2022 2:43 pmDoes anybody have any clever solutions when using a USB HDD on the Sony x800m2?
viewtopic.php?f=12&t=18602&p=123354#p123354
I would get one that is USB 3.0 or C though. (if your pc support it)
Interesting, I just checked Oppo setting it to Player-led: all the L2 trims are working, but only L1 lower contrast (last one) resulted in visible change on the G2.RESET_9999 wrote: ↑Sat Aug 06, 2022 4:40 pmit depends on which player you use. On the x700/x800m2/Shield the L1 and L2 trims are not working at all in LLDV.
yep, so far, all the players that have the option in the menu to select LLDV have no issue. Oppo / Dune and Zidoo player.
I have an Oppo clone and have been concerned with the recent bug reports. It is almost time for me to buy a new TV and I was thinking about trying to track down a CX to get a set that doesn't suffer from the issues recently reported.RESET_9999 wrote: ↑Mon Aug 08, 2022 10:57 amyep, so far, all the players that have the option in the menu to select LLDV have no issue. Oppo / Dune and Zidoo player.
Well I'm not sure about the CX, we have conflicting reports:
set your Oppo to TV-LED.
Thanks very much. I misunderstood the previous posts. I see now that it says, any player with the LLDV switch are not impacted. I thought it was necessary to enable LLDV as a workaround. Understood and thanks very much for your help.RESET_9999 wrote: ↑Mon Aug 08, 2022 8:31 pmWell I'm not sure about the CX, we have conflicting reports:
1- viewtopic.php?p=124851#p124851
2- viewtopic.php?p=124749#p124749
of course, it will work. But we are not talking about the L1 bug with cmv 2.9 hdmi input if that's what you think.
