LibreDrive for Pioneer drives
ctaverna76
#271 Post by ctaverna76 » Tue Jul 19, 2022 1:08 am
I need assistance please. I recently purchased a Pioneer Drive and I am not sure what firmware is needed to flash the drive.
OS device name: F:
Manufacturer: PIONEER
Product: BD-RW BDR-XD07U
Revision: 1.03
Serial number: AGDL009272UC
Firmware date: 2020-08-20
Bus encryption flags: 13
Highest AACS version: 76
Drive platform: RS8D31
Firmware version: 1.03/ID05
#272 Post by Billycar11 » Tue Jul 19, 2022 3:22 am
ctaverna76 wrote: Tue Jul 19, 2022 1:08 am I need assistance please. I recently purchased a Pioneer Drive and I am not sure what firmware is needed to flash the drive.
OS device name: F:
Revision: 1.03
none
ctaverna76
#273 Post by ctaverna76 » Tue Jul 19, 2022 12:20 pm
The firmware is from 2020 and the drive cannot decrypt. I definitely need to flash the drive. When you state "none", are you saying that there is no firmware for this model drive?
Thank you.
#274 Post by d00zah » Tue Jul 19, 2022 1:09 pm
ctaverna76 wrote: Tue Jul 19, 2022 12:20 pm The firmware is from 2020 and the drive cannot decrypt. I definitely need to flash the drive. When you state "none", are you saying that there is no firmware for this model drive?
Thank you.
He's saying all features are enabled, so there's nothing more to do:
When you say "the drive cannot decrypt", I'm guessing you might benefit from reading the UHD FAQ linked in my sig?
#275 Post by MartyMcNuts » Tue Jul 19, 2022 11:53 pm
Thank you.
Your Pioneer drive will only be able to decrypt UHD discs if it is one of Pioneer's UHD models.
mvcoder
#276 Post by mvcoder » Thu Jul 21, 2022 1:18 am
I have a Pioneer BDR-209D 1.34 which I've been using to rip BD's (retail movies) for a few years now, but since LibreDrive began supporting this drive earlier this year, many of my discs are only ripping at a max of 2.0X whereas they used to rip at 4.0X to 7.0X.
I tried the speed_ 0=99 setting in the registry but that didn't help, so I changed the sdf_Stop key to the drive's ID to disable LibreDrive entirely. That has restored my read speeds again.
What disadvantage am I likely to face without LibreDrive, particularly with future release Blurays?
My highest AACS version is 76 and so far the latest release Blurays are ripping at 4-7X successfully.
#277 Post by Billycar11 » Thu Jul 21, 2022 2:03 am
mvcoder wrote: Thu Jul 21, 2022 1:18 am I have a Pioneer BDR-209D 1.34 which I've been using to rip BD's (retail movies) for a few years now, but since LibreDrive began supporting this drive earlier this year, many of my discs are only ripping at a max of 2.0X whereas they used to rip at 4.0X to 7.0X.
for non UHD you only miss getting around aacs revoks so not really losing much
hybrid_model
#278 Post by hybrid_model » Tue Jul 26, 2022 3:55 pm
Hi guys.
I have two old Pioneer drives and both didn't work. I'm attaching the LibreDrive information of both.
Can someone please explain me what should I do to rip 4K UHD BD discs ?
Thanks in advance.
drive 2.jpg (18.85 KiB) Viewed 30987 times
emrysblack
#279 Post by emrysblack » Tue Jul 26, 2022 5:21 pm
Sadly those Pioneer drives don't support UHD at all. You need a Pioneer drive with U in the model name such as Pioneer BDR-S12UHT for an example. Older drives predate 4k discs and the ability to read them.
asmcom
#280 Post by asmcom » Thu Jul 28, 2022 12:44 am
hybrid_model wrote: Tue Jul 26, 2022 3:55 pm Hi guys.
Thanks in advance.
Please see drives below I sell on eBay or with 5% discount for MakeMKV members.
Pioneer listing below, all of which are excellent readers and burners:
https://www.ebay.co.uk/itm/264990662673
https://www.ebay.co.uk/itm/265623019904
https://www.ebay.co.uk/itm/265630912065
https://www.ebay.co.uk/itm/265668732882
Kind Regards
Asmcom :mrgreen:
SirReallySam
#281 Post by SirReallySam » Fri Jul 29, 2022 1:18 pm
Hi there, I've recently got a new UHD Pioneer drive that I'm trying to rip UHD discs with.
It's the following:
OS device name: E:
Revision: 1.03
Serial number: TJDL000950WL
Highest AACS version: 61
In theory should this work I think? I'm on the most updated MakeMKV, have enabled internet access in the preferences and have sent of the .tgz files off to svq@makemkv.com a couple of weeks ago. I'm still getting 'the volume key is unknown for this disc' only for UHD discs, standard blu-ray and dvds are working fine however.
Any help would be appreciated.
Thanks,
Sam
asianman6924
#282 Post by asianman6924 » Fri Jul 29, 2022 2:33 pm
Could I get some assistance please. I have a Pioneer BDR-212U that Libredrive cannot activate.
What do I need to do to get this to work?
I have also attached a zip log file that MakeMKV made if that helps.
Thank you everyone for the help!
MKB20_v76_The_Lord_of_the_Rings-_The_Return_of_the_King_F2B7.tgz
(1.18 MiB) Downloaded 1115 times
TeddyRaspin
#283 Post by TeddyRaspin » Fri Jul 29, 2022 3:52 pm
Update it to 1.02 firmware version.
asianman6924
#284 Post by asianman6924 » Fri Jul 29, 2022 4:10 pm
TeddyRaspin wrote: Fri Jul 29, 2022 3:52 pm Update it to 1.02 firmware version.
Thank you TeddyRaspin! I updated to firmware 1.02 and it worked like a charm. I appreciate your kind help.
TeddyRaspin
#285 Post by TeddyRaspin » Sat Jul 30, 2022 4:48 pm
asianman6924 wrote: Fri Jul 29, 2022 4:10 pm
You're welcome. :wink:
