BU40N Firmware for both MakeMKV and DVDFab
icarus
Post by icarus »
Hey All,
What would be the firmware to use that will allow me to use MakeMKV, and also DVDFab's ISO creator? I'm aware that I can do a disk backup with MakeMKV, but I would like the option to just create an ISO in DVDFab. My drive information is below. Thanks!
OS device name: G:
Product: BD-RE BU40N
Revision: 1.03
Highest AACS version: 76
Firmware version: 1.03
asmcom
Re: BU40N Firmware for both MakeMKV and DVDFab
Post by asmcom »
icarus wrote:
Thu Jun 30, 2022 1:53 pm
Hey All,
OS device name: G:
Revision: 1.03
Use firmware:
DE_LG_BU40N_1.00.bin
You will find the link to this firmware link under slim drives directory.
https://www.mediafire.com/file/6ndv5i14 ... k.zip/file
Asmcom :mrgreen:
icarus
Post by icarus »
Thank you. I was able to flash the firmware with that version. Is this of concern or will it limit me in anyway - Firmware type: Original (unpatched)?
OS device name: G:
Revision: 1.00
Firmware date: 2116-12-20 15:28
Firmware version: 1.00
Post by SamuriHL »
No, it's exactly what you want.
originalsnuffy
Post by originalsnuffy »
I recently updated the BU40N to 1.04 (modded).
I am getting hash errors on the main title stream file for a disc (the new Beatles Get Back).
Would moving to an earlier firmware be helpful in getting things to work better? If so, which firmware should I use?
originalsnuffy wrote:
Thu Jul 14, 2022 4:03 am
1.04-MK sucks!!! DE 1.00 is the best followed by 1.03-MK.
originalsnuffy
Thanks Marty. I installed 1.00 DE and will try it out.
SidebandSamurai
Post by SidebandSamurai »
Makemkv reports the following: BD-RE-HL-DT-ST BD-RE BU40N 1.01 MZFL4T91101.
The drive seems to be ripping blue rays pretty well. I am currently ripping Star Trek the original Series. Will I encounter any problems with this drive?
