Best enclosures / best external - new to UHD
NewToThis
Post by NewToThis »
Hi all,
I’ve never owned a BD writer until now, I checked the thread
viewtopic.php?t=19634
and picked
LG BU40N, UHD Official Internal Slim Sata 9.5mm Rip speed 6x BD 66 ~45 mins BD 100 ~1 hour 5mins
Reason why I picked this was due to size and it would be portable. Is this still the best drive to own? - I have 30 days to return and it only arrived this morning. -
I do also have on order:
LG WH14NS40, UHD Friendly Internal 5.25 sata Rip speed 8x BD 66 ~45 mins BD 100 ~1 hour if flashed properly other wise 6x rips speed and slower then BU40N
This one is not in stock and is on back order. Stock seems hard in UK.
My question: if the LG BU40N is the best drive to still own could someone recommend a USB-C enclosure please?
I did look around the web but I only found this:
https://www.delock.com/produkt/42595/kaufen.html
But can’t find where to buy from a good seller.
If you can help and have any better recommendations on a better drive to buy or an external that already has a UHD inside that is compatible and available in UK please :D
Re: Best enclosures / best external - new to UHD
Asmcom is a UK vantec dealer and can bundle a usb C cable for a small price increase with one.
see the guide for his contact info
asmcom
Post by asmcom »
Billycar11 wrote:
Mon Jun 13, 2022 2:52 am
Yes I can supply USB C cable no problem with Vantec or Archgon drive.
viewtopic.php?t=19387
UK delivery next day
Asmcom :mrgreen:
