vseven
Post by vseven »
Not sure what happened but the link in the initial post to the SDF.bin doesn't work anymore for me unless you add the www. to the domain name. I.e https://makemkv.com/sdf.bin doesn't work for me but https://www.makemkv.com/sdf.bin does.
LucasRey
Post by LucasRey »
Hi all, thanks to the OP guide I downgraded correctly my BH16NS55 from 1.03 to DE_LG_WH16NS60_1.00.bin
Prior to flash the DE_LG_WH16NS60_1.00.bin I flashed the WH16NS60 1.02MK as per encrypted firmware:
BH16NS55 on any Firmware directly to > WH16NS60 1.02MK
And everything should be ok. Thank you so much for the guide!!! :wink:
My question now is regarding other driver I own:
Product: BDDVDRW CH12NS40
Revision: 1.01
Firmware date: 2117-11-21 16:06
Firmware version: 1.01
For that drive, there is no references on firts post, so, can I use the same procedure I used with BH16NS55? :
1) Flash WH16NS60 1.02MK
2) Flash DE_LG_WH16NS60_1.00.bin
Thank you
Lucas
Mr_Orange
Post by Mr_Orange »
vseven wrote: Wed Jun 08, 2022 1:26 pm Not sure what happened but the link in the initial post to the SDF.bin doesn't work anymore for me unless you add the www. to the domain name. I.e https://makemkv.com/sdf.bin doesn't work for me but https://www.makemkv.com/sdf.bin does.
It works for me without the www.
LucasRey wrote: Sun Jun 12, 2022 2:25 pm Hi all, thanks to the OP guide I downgraded correctly my BH16NS55 from 1.03 to DE_LG_WH16NS60_1.00.bin
Revision: 1.01
Thank you
Lucas
that would likly work but it looks like the firmware is already old enough to not need to be flashed does it already see UHD discs but with the sleepbug?
LucasRey
Post by LucasRey »
I would like to use/try more apps as well as MakeMKV. For instance, DVDFAB needs firmware 1.0. Currently I didn't notice sleepbug anyway.
Do you think I can proceed with the following steps without break my drive?
Thank you
p_u_a
Post by p_u_a »
Thanks so much to everyone that made this so easy!
I just got a Buffalo BRUHD-PU3-BK brought over to me from Japan and it's working great on 1.03 MK.
I noticed though the firmware shipped on my drive (BU14) was newer than the firmware in the MK firmware pack - I did a dump before flashing with 1.03 MK, is it useful to anyone? Would like to help if I can, and this is literally all I'm capable of :P
p_u_a wrote: Tue Jun 14, 2022 12:09 pm Thanks so much to everyone that made this so easy!
Sadly the type of dump you have is not the kind we need you would have needed to contact the developer before flashing to get a real dump your current dump is just a cal data and some version numbers
But it's not currently needed it's still flashable
p_u_a
Post by p_u_a »
Well that takes away all my capability :P
But massive thanks again though. It went through without any problem and I'm ripping a disc now.
nobo73
Post by nobo73 »
Hi, Now, I am considering to purchase Buffalo BRUHD-PU3-BK.
I am wondering if the latest version of BRUHD-PU3-BK can be downgraded?
I heard that the model is end of life, so I think I should obtain one.
nobo73 wrote: Mon Jun 27, 2022 8:58 pm Hi, Now, I am considering to purchase Buffalo BRUHD-PU3-BK.
Don't spend the extra on it it's just a BU40N in a case
Get the archgon
asmcom
Post by asmcom »
Billycar11 wrote: Tue Jun 28, 2022 5:05 am
Get the archgon
Yes the Archgon is a most better drive and value for money.
Asmcom :mrgreen:
Jeannozt
Post by Jeannozt »
Dear all
hope that somebody can help me.
I mean that my drive is a LG BU40N
I've tried to flash him via MAC OS
All has worked as described, but I'm still not allowed to copy UHD disks
Thanks a lot for any help
Bildschirmfoto 2022-06-29 um 13.59.19.png (249.74 KiB) Viewed 96868 times
Jeannozt wrote: Wed Jun 29, 2022 12:05 pm Dear all
Your drive is not flashed be sure to use enc
Jeannozt
Post by Jeannozt »
Billycar11 wrote: Wed Jun 29, 2022 1:12 pm
Hello what do you mean with use enc
Chatomarocoloco
Post by Chatomarocoloco »
I have the Pioneer BDR-S12UHT recorder and player. Read original UHD blu-ray but could not play due to processor issue.
The problem is that I want to remove the anti copy with MakeMKV and I get the error shown in the image. Is this model compatible?
or the error is due to something else that I do not know.
a greeting.
error blu ray UHD 03.jpg (195.32 KiB) Viewed 295936 times
infortmacion 02.jpg (172.88 KiB) Viewed 295936 times
