All my UHD discs rip failure
phantom0308
Post by phantom0308 » Tue Apr 05, 2022 4:30 pm
I tried to rip all my uhd discs with makemkv but none of them worked, I have sent the tgz files to svq@makemkv.com.
I don’t think the makemkv server does not have the keys for these UHD discs, because in 2021, these UHD discs can be successfully ripped with makemkv, and these UHD discs include
Harry Potter 1-8 Collection
Lord of the Rings 1-3 Collection (including theatrical version and extended version)
Game of Thrones 1-8 collection
Westworld 1-3 collection
The Matrix 1-3 collection,etc.
I have tried to check allow internet access, and the DNS is also set to 8.8.8.8; with the nslookup command line, cmd returns
Server: dns.google
Address: 8.8.8.8
Non-authoritative answer:
Address: 91.224.23.225
I reinstalled the system, and tried the previous version 1.16.5, but it still doesn't work; I uploaded the pictures with the error of opening the UHD disc and decrypting the UHD disc.
I've been stuck with this problem for a month now and would be grateful if anyone could help with this.
Info:
OS device name: F:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.02
Serial number:
Firmware date: 2117-11-24 14:13
Bus encryption flags: 1F
Highest AACS version: 76
Firmware version: 3.02
Disc Information
Label: Harry_Potter_Order_of_Phoenix
Timestamp: 2017-02-22 16:43:44
Protection: AACS2.0/C v61
Data capacity: 68.1 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
MKB20_v61_Harry_Potter_Order_of_Phoenix_690F.tgz
(106.17 KiB) Downloaded 563 times
audit13
Re: All my UHD discs rip failure
Post by audit13 » Mon Apr 11, 2022 2:36 pm
Did you try using your ISP's DNS server settings instead of Google?
Did you submit dump files?
I'm not an expert but these are things I have done in the past to get the program to work.
Post by Billycar11 » Mon Apr 11, 2022 3:03 pm
phantom0308 wrote: Tue Apr 05, 2022 4:30 pm I tried to rip all my uhd discs with makemkv but none of them worked, I have sent the tgz files to svq@makemkv.com.
Server: dns.google
Address: 8.8.8.8
Info:
OS device name: F:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.02
Serial number:
Disc Information
Number of layers: 3
Make sure you makemkv data directory is writable other than that you have to make your stuff stop blocking your access to makemkv key servers
phantom0308
Post by phantom0308 » Fri Apr 15, 2022 8:22 am
audit13 wrote: Mon Apr 11, 2022 2:36 pm Did you try using your ISP's DNS server settings instead of Google?
Thank you for your reply. Before using google's dns, I used the ISP's default dns, which was also unavailable.
phantom0308
Post by phantom0308 » Fri Apr 15, 2022 8:38 am
Billycar11 wrote: Mon Apr 11, 2022 3:03 pm
Server: dns.google
Address: 8.8.8.8
Info:
OS device name: F:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.02
Serial number:
Disc Information
Number of layers: 3
Sorry for taking so long to reply, I don't log into makemkv very often.
I did find a solution. I downloaded the sdf+key under the useful link in your post Ultimate UHD Drives Flashing Guide Updated 2022, that is, the _private_data file, and overwritten it to my .makemkv folder, then I can rip the UHD discs, thank you for so much.
The key update speed will depend on your update speed, so I still want makemkv to automatically download the key from the server. I tried to use the network provided by different local ISPs, but makemkv still cannot obtain the key automatically. What do you think is the reason? Anyway, thanks again for your answer.
Post by Billycar11 » Fri Apr 15, 2022 10:02 am
phantom0308 wrote: Fri Apr 15, 2022 8:38 am
its likely a firewall setting in your router or a geofilter and thats why maybe swapping isps did not help.
you could try a vpn to get around it and just use it anytime you need a key update i normally dont update the privatedata.tar unless i see lots of reports of problems
phantom0308
Post by phantom0308 » Fri Apr 15, 2022 3:51 pm
Billycar11 wrote: Fri Apr 15, 2022 10:02 am
Ok, thank you for your answer, in fact, before posting, I have tried the VPN method, but it still doesn't help makemkv to get the key.
Post by Billycar11 » Fri Apr 15, 2022 8:32 pm
phantom0308 wrote: Fri Apr 15, 2022 3:51 pm Ok, thank you for your answer, in fact, before posting, I have tried the VPN method, but it still doesn't help makemkv to get the key.
It could be the windows firewall too see to make sure it's allowed.
You could also give it the good old uninstall and reinstall see if that fixes it.
I would also try on another PC in the house if you can see if same thing happens
phantom0308
Post by phantom0308 » Fri Apr 15, 2022 10:37 pm
Billycar11 wrote: Fri Apr 15, 2022 8:32 pm It could be the windows firewall too see to make sure it's allowed.
I have added the storage address of makemkv to the exclusions of windows defender
At the same time, the firewall has also added the file that under the makemkv folder
MakeMKV ccextractor
MakeMKV console application
MakeMKV GUI application
to the list of "Allow applications to communicate through Windows Defender Firewall"
But after the above operations are done, the key cannot be obtained after deleting the _private_data file
asmcom
Post by asmcom » Sat Apr 16, 2022 12:44 am
phantom0308 wrote: Fri Apr 15, 2022 10:37 pm
MakeMKV ccextractor
Disable the Windows defender in group policy editor and then try.
or you could disable in the registry
https://hetmanrecovery.com/recovery_new ... ows-11.htm
Asmcom :mrgreen:
phantom0308
Post by phantom0308 » Sat Apr 16, 2022 12:49 am
asmcom wrote: Sat Apr 16, 2022 12:44 am Disable the Windows defender in group policy editor and then try.
Asmcom :mrgreen:
thanks,I will try it later
phantom0308
Post by phantom0308 » Mon Apr 18, 2022 3:07 pm
Asmcom :mrgreen:
I tried the method you mentioned, but it seems that makemkv still can't get the latest key. Could you share a copy of your _private_data with me if it is convenient for you? Thank you.
phantom0308
Post by phantom0308 » Mon Apr 18, 2022 3:19 pm
May I ask from which website can I download hkdata and sdf so that I can manually add them into private data?
Post by Billycar11 » Tue Apr 19, 2022 2:00 pm
phantom0308 wrote: Mon Apr 18, 2022 3:19 pm
Sdf is linked in the guide
HK can change anytime and I I think the developer does not want the keys in the public view
phantom0308
Post by phantom0308 » Fri Apr 22, 2022 1:12 pm
Billycar11 wrote: Tue Apr 19, 2022 2:00 pm Sdf is linked in the guide
OK, thanks a lot.
