LibreDrive for Pioneer drives
horze
Post by horze »
Billycar11 wrote: Wed Mar 23, 2022 11:15 pm
horze wrote: Wed Mar 23, 2022 10:57 pm hey guys
with the BDR-S12UHT now supported, could one argue this is the best drive to now get over the LG BH16NS55 and ASUS BW-16D1HT Pro (obviously flashed to make friendly)
Is there any benefits of having a friendly drive over a BDR-S12UHT official
The other drives are faster and work with more programs
Pioneer rips UHD at 4x LG/Asus can rip up to 12x or 8x stock
thanks for your reply Billycar11
How about in terms of rip issues? and build quality.
horze wrote: Wed Mar 23, 2022 11:35 pm
i would recommend a BU40N if you use other ripping programs for UHD or if you only use makemkv get a pioneer.
the BU40N/bp60 and clones are the best build quality for lg/asus the pioneer drives are regarded to be better but i have not done extensive testing like i have for the lg/asus drives and wont until they need to be flashed if ever
horze
Post by horze »
Billycar11 wrote: Thu Mar 24, 2022 12:54 am
thankyou billy, appreciate your honesty
asmcom
New VANTEC DX2 looks amazing with Pioneer BDR-S12UHT
Post by asmcom »
Hi Everybody,
Just setup my new Pioneer BDR-S12UHT with one of my new DX2 Vantec enclosures, It really looks brilliant with the Vantec DX2. I am well pleased with my new drive and enclosure. This enclosure and drive is so silent.
Asmcom :mrgreen:
aat92
Post by aat92 »
MartyMcNuts wrote: Mon Mar 21, 2022 9:37 am
aat92 wrote: Mon Mar 21, 2022 7:21 am
Coopervid wrote: Sun Mar 20, 2022 9:23 pm
List the Makemkv status report. Maybe your firmware version isn't supported.
Debug log started at Sun Mar 20 19:02:25 2022 , written by MakeMKV v1.16.7 win(x64-release)
001005:0000 MakeMKV v1.16.7 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\Albert/MakeMKV_log.txt
DEBUG: Code 3 at wPw@X*c]4mg& [n>)i&~--ZG:29395310
SDF v088: PIONEER_BD-RW___BDR-XD05_3.10_OLDL00XXXXXX
Application exited at Sun Mar 20 19:04:26 2022
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-XD05
Revision: 3.10
Serial number: OLDL00XXXXXX
Firmware date: 2017-06-22
Highest AACS version: 62
Drive platform: RS8232
Firmware name: PIONEER BDR-XD05
Firmware version: 3.10/ID34
i thought thats what LibreDrive is meant to do. read the whole disc data raw bypassing anything that gets in the way to protect the data
No, libredrive won’t pass everything. It stops a drive from being revoked with new AACS revisions and re-enables UHD disc reading within a drive’s firmware if it could already recognise a UHD disc. The AACS encryption/decryption process still works the same as always. Libredrive doesn’t change that.
As mentioned before, your drive isn't a UHD model and doesn't natively read UHD discs.
why does mike admin say on libredrive post what is Libredrive: "LibreDrive compatible drive is required to read UHD discs."
and its enabled on my drive? why would it be enabled if its not compatible to read UHD discs?
aat92 wrote: Sat Mar 26, 2022 1:41 am
OS device name: E:
Revision: 3.10
What Mike says is correct. A drive that has LibreDrive enabled is needed to read UHD discs. He does not say anything about all LibreDrive enabled drives being able to read UHD discs. LibreDrive does not equal UHD readability! LibreDrive does however, re-enable UHD reading if the original firmware already had it.
destine97
Post by destine97 »
I've got a BDR-212XJ (Identifies as a BDR-212M) which, despite apparently matching the list in the first post, isn't getting LibreDrive enabled. (it's not a UHD capable drive. But it is beige!)
OS device name: /dev/sr1
Product: BD-RW BDR-212M
Revision: 1.01
Serial number: XXXXXXXXXXXX
Firmware date: 2020-07-21
Highest AACS version: 76
Firmware version: GENE
And sdftool info output:
SDF.bin version: 0x0088
Drive Tool SDF present
Drive Specific SDF not present
Identification SDF present
8000:LibreDrive Information
8013:Status
8001:Drive platform
:Pioneer RS8F00
8003:Firmware version
:GENE
pioneer:SAT :8F00:GENE:RAL :PIONEER :BD-RW   BDR-212M1.01: 20/07/21  :-
The entry I would expect it to match is
PIONEER-BD-RW___BDR-212M-1.01-5013125C-8F00ID56-20200721
Anyone have any idea what's going on here? Is there some sort of firmware mismatch despite the fact that the drive model and firmware version appear to be the same?
lukandelic
Post by lukandelic »
Hello, I'm noob so forgive me asking obvious questions but do you know if my drive is compatible with LibreDrive?
On the first page this drive is listed with newer firmware 1.01
PIONEER-BD-RW___BDR-212D-1.01-F567BFF5-8F00ID61-20200721
My setup:
SDF id v088: PIONEER_BD-RW___BDR-212D_1.00_SLDL012739WL
Product: BD-RW BDR-212D
Revision: 1.00
Serial number: SLDL012739WL
Firmware date: 2019-01-10
Bus encryption flags: 13
Highest AACS version: 72
Firmware version: ID61
Anyway what to do to be compatible? Do i need to flash firmware? How to do it safe?
lukandelic wrote: Sun Mar 27, 2022 7:25 pm Hello, I'm noob so forgive me asking obvious questions but do you know if my drive is compatible with LibreDrive?
My setup:
Revision: 1.00
You don't need to update your firmware just email the developer and he will help you dump yours and then it will be added
You could update it through official pioneer methods if you don't want to wait and it should be safe
kuro2K20
Post by kuro2K20 »
Hello everybody ! ^^
For me, the message "no disc" appear !
Fabricant : PIONEER
Produit : BD-RW BDR-212M
Révision : 1.01
Date micrologiciel : 2020-07-21
Marqueurs d'encryptage bus : 1B
Version AACS la plus haute : 68
Drive platform: RS8F00
Firmware version: 1.01/ID56
and same thing with my another drive...
Fabricant : PIONEER
Produit : BD-RW BDR-S09
Révision : 1.54
Version AACS la plus haute : 63
Drive platform: RS8600
Firmware version: 1.54/ID43
Any idea ?
Thanks ! ^^
kuro2K20 wrote: Tue Mar 29, 2022 3:26 am Hello everybody ! ^^
Fabricant : PIONEER
Révision : 1.01
Fabricant : PIONEER
Révision : 1.54
Any idea ?
Thanks ! ^^
I guess you are trying to read UHDs. Your drives are not UHD capable. Only those that include a letter "U" in their names.
kuro2K20
Post by kuro2K20 »
My two Pioneer drive are not compatible ???
Compatible with Libredrive? yes. This doesn't mean they can read UHDs. Like said: Only Pioneer drives that contain the letter"U" can read UHDs. Maybe somewhen in the future they can be ugraded by cross-flashing. Who knows... But not right now. You will need another drive to read UHDs.
kuro2K20
Post by kuro2K20 »
Ok !
Good thing I have an Asus and an LG (both flashed) that can read my UHD discs ^^ ;)
Actually, I only use my two Pioneer for burning...
kuro2K20 wrote: Tue Mar 29, 2022 9:43 pm Ok !
Yes. The Pios are good burners for 50GB discs. Burn at 2x speed for best quality. For 25GB discs you can also use the LG / ASUS drives.
