Pioneer BDR-XD07UHD
ArArdin
Pioneer BDR-XD07UHD
#1 Post by ArArdin » Mon Feb 28, 2022 11:50 am
Hi all,
I'm considering to buy this one because I always enjoyed the quality that Pioneer drives were build with. Does this one have it too?
If anyone has this drive, I'd like to know how handling and ripping experiences are. And if - next to MakeMKV - AnyDVD HD is supported too.
Thanks in advance.
Re: Pioneer BDR-XD07UHD
#2 Post by dcoke22 » Mon Feb 28, 2022 2:50 pm
The list of which drives work are in the first post of Ultimate UHD Drives Flashing Guide Updated 2022
ArArdin
#3 Post by ArArdin » Mon Feb 28, 2022 5:02 pm
Yeah, the list in the first post is exactly where I got it from.
I'm hoping owners could tell me a it more about the build quality and general experience. Or specific behaviour compared to other drives.
EretzAshur
#4 Post by EretzAshur » Fri Mar 11, 2022 12:12 am
Is this drive capable of ripping UHD Discs?
#5 Post by MartyMcNuts » Fri Mar 11, 2022 6:28 am
All Pioneer UHD drive models can rip UHD discs. I'm also certain that they only work with MakeMKV for UHD ripping purposes.
#6 Post by SamuriHL » Fri Mar 11, 2022 4:11 pm
That's not entirely accurate. While LibreDrive is most DEFINITELY needed, thus requiring MakeMKV be installed, there is another product that has been able to make use of LibreDrive enabled drives.
asmcom
#7 Post by asmcom » Fri Mar 11, 2022 10:03 pm
Hello ArArdin,
I have these drives in stock and I will be testing on Sunday. I can let you know how it goes and I can also supply you a drive to.
viewtopic.php?t=19387
Kind Regards
Asmcom
#8 Post by MartyMcNuts » Fri Mar 11, 2022 11:18 pm
What product??
#9 Post by d00zah » Sat Mar 12, 2022 12:14 am
What product??
This one.
#10 Post by SamuriHL » Sat Mar 12, 2022 1:42 am
Yup. It works very well. I use it with my Pio and bu40n drives.
#11 Post by MartyMcNuts » Sat Mar 12, 2022 2:52 am
Huh, well there you go. I was not aware that that application worked with any official UHD drives. Does that include the LG official UHD drives?
#12 Post by SamuriHL » Sat Mar 12, 2022 3:47 am
Yes hence my mentioning the bu40n. ;) it works with any libredrive enabled drive, official or unofficial. Currently it's querying the sdf to see if a drive is supported by libredrive, activating it if it is, and then ignoring bus encryption on that drive. I love it because I always make a protected iso of my new discs so now I can just pop it in the drive and use its rip to iso function.
ArArdin
#13 Post by ArArdin » Sat Mar 12, 2022 7:12 am
Hello ArArdin,
Thanks, but a few days ago I purchased a Pioneer BDR-S12UHT.
BTW I can confirm the BDR-S12UHT works with AnyDVD.
