Tango wrote: Sat Feb 26, 2022 9:27 am My drive flashed and supposedly was updated with LibreDrive - but it wasn't!
I followed the instructions:
Then I unplugged the drive and let it sit for a few minutes and reconnected it. I started up MakeMKV and got this:
So, apparently, even though I flashed it properly and it finished the job in the console, the drive did not get flashed. Also note this 2nd screen shot is after I also rebooted my iMac.
What do I need to do to fix this?
Your BH16NS58 1.03 is most likely encrypted, so in your command, simply change "main" to "enc" and the flash should work. I also suggest flashing to WH16NS60 1.02-MK from the MK firmware pack (in the old folder) as WH16NS60 1.03-MK is absolute garbage.
Azores26
Post by Azores26 »
Hi everyone! I have some doubts about optical drive enclosures and I would be thankful if someone could help me, please. I'm thinking about buying a LG-BU40N drive for flashing and I also would like to buy a SATA-USB enclosure for it. However, in this guide, some drive enclosures are mentioned as not being compatible with flashing.
More especifically, I was looking to buy a cheap SATA-USB enclosure on AliExpress. Do you think that the enclosure could have problems with the drive if I tried flashing it? Aren't these kind of enclosures supposed to be just an SATA-USB adapter?
Thanks in advance.
Tango
Post by Tango »
MartyMcNuts wrote: Sat Feb 26, 2022 10:17 am
Now I get this. Yay! Thank you for the help!
Screen Shot 2022-02-27 at 5.03.32 PM.png (224.3 KiB) Viewed 24275 times
kuze22
Post by kuze22 »
Looking to grab a drive for mostly UHD backups, found the BDR-XS07TUHD on Amazon UK. The master drive list shows BDR-XS07UHD as supported for UHD and backup and wondered if the T version is the same?
Some searches showed conflicting information that BDR-XS07TUHD will never be supported for UHD rip\playback but thought this could be outdated information.
Alternatively, if you have any ideas on the best bang for buck UHD drive for rips on amazon UK, no problem for me to flash with modified firmware.
Thanks in advance for any ideas. :mrgreen:
Pioneer BDR-XS07TUHD 6x Slot Loading Portable USB 3.1 BD Burner
https://www.amazon.co.uk/Pioneer-BDR-XS ... C55&sr=8-1
kuze22 wrote: Tue Mar 01, 2022 5:47 pm Looking to grab a drive for mostly UHD backups, found the BDR-XS07TUHD on Amazon UK. The master drive list shows BDR-XS07UHD as supported for UHD and backup and wondered if the T version is the same?
Should be fine I think it's just the eu version of it
kuze22
Post by kuze22 »
Thanks Billycar11 - I will go for it and see what happens.
FubbAyH
Post by FubbAyH »
Just for anyone who is Googling, the Pioneer BDR-XD07TUHD is indeed just a European variant of the BDR-XD07UHD. In MakeMKV the product identifies as "BD-RW BDR-XD07U", and the firmware name is "PIONEER BDR-BDS7". It's working great for ripping UHDBDs.
ArArdin
Post by ArArdin »
FubbAyH wrote: Wed Mar 09, 2022 1:09 am Just for anyone who is Googling, the Pioneer BDR-XD07TUHD is indeed just a European variant of the BDR-XD07UHD. In MakeMKV the product identifies as "BD-RW BDR-XD07U", and the firmware name is "PIONEER BDR-BDS7". It's working great for ripping UHDBDs.
Looking for a BDR-XD07UHD (without the "T") I came across this one and contacted the vendor if the two maybe could be the same. He said the T stands for "top-loader". Which I found odd because the XD07UHD is a top loader already, if I can trust the internet images. He couldn't provide any further information. I got the idea he didn't know much about anything.
Good that your BDR-XD07UTHD is working great.
I ordered a BDR-S12UHT instead. As I speak, it's doing its maiden run ripping a UHDBD. It's very silent, I must say.
Blackened2687
Post by Blackened2687 »
A letter "T" in XD07TUHD, XS07TUHD, XD07TB, XD07TS, XS07TS means "Taiwan". These are models marketed for Taiwan primarily, and they are also sold in Europe and Australia. Their American counterparts are XD07UHD, XS07UHD, XD07B, XD07S, XS07S respectively. There are also XD07CB, XD07CS, XS07CS, which are marketed for China (note a "C" letter in the model name). And there are also Japanese models with completely different names, colors and firmware IDs. For anyone interested, these models are XD07J-UHD, XS07B-UHD, XD07BK/R/W, AD07BK/R/W, XD07LE, XD07R-N, XS07JL and XS07JM. Quite a list, I must say.
Baby_Groot
Post by Baby_Groot »
Just checking whether it's possible to change the firmware on my blu-ray drives to make them UHD compatible? I have two drives (both the same) and they're MT1959 platform and manufactured after 2015 (manufactured May 2016 and the other March 2021). The drive models are the external LG BP50NB40 but with SVC code NB40.
The May 2016 drive on MakeMKV shows up as:
Drive Information:
Product: BD-RE BP50NB40
Revision: 1.00
Serial number: XXXXXXXXXXX
Firmware date: 2115-04-22 15:17
Highest AACS version: 76
LibreDrive Information:
Firmware version: 1.00
& the March 2021 drive shows up on MakeMKV as:
Drive Information:
Revision: 1.03
Harware support: Yes
Firmware support: No
Firmware version: 1.03
It's the SVC code I'm worried about (NB40) as most of the guides state to have NB50 (I think?). Can any anyone confirm whether these will work for 4K before I try something that bricks my drive?
Thanks! :)
MrDark
Post by MrDark »
I hope someone here can help me. I am desperate and do not know what else to do:/
I have received the drive LG WH16NS60 new. Flashed the drive to version 1.02. Now I have the following problem. MakeMKV can not open and edit the bluray. If I want to manually pull the data from the disk, I can do that, but I get a disconnect after a while. So I can not download most of the files. As soon as the disconnect takes place, the hard disk also temporarily disappears from the overview in windows and then reappears. However, data from the BluRay can be displayed in the folder without problems. Yes I have tried 4 different BluRays and the same problem with all of them.The same thing happens to me with version 1.03. This all occurs in Windows and Linux
Picture of my MakeMKV interface: https://imgbb.com/bQmskRn
MakeMKV error Log:
MakeMKV v1.16.7 win(x64-release) started
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02 M0024881131' at offset '589824'
udf: node fe/efe failed!
udf: udf mount: Metadata file not readable, substituting Metadata copy file
Error 'OS error - Dieses Gerät ist nicht vorhanden' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02 M0024881131' at offset '24837160960'
Error 'OS error - Dieses Gerät ist nicht vorhanden' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02 M0024881131' at offset '24837220352'
Error 'OS error - Dieses Gerät ist nicht vorhanden' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02 M0024881131' at offset '24836898816'
Error 'OS error - Dieses Gerät ist nicht vorhanden' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02 M0024881131' at offset '24836923392'
Error 'OS error - Dieses Gerät ist nicht vorhanden' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02 M0024881131' at offset '24837095424'
Error 'OS error - Dieses Gerät ist nicht vorhanden' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02 M0024881131' at offset '24837097472'
Error 'OS error - Dieses Gerät ist nicht vorhanden' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02 M0024881131' at offset '24837107712'
Error 'OS error - Dieses Gerät ist nicht vorhanden' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02 M0024881131' at offset '24836964352'
Error 'OS error - Dieses Gerät ist nicht vorhanden' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02 M0024881131' at offset '24836995072'
Error 'OS error - Dieses Gerät ist nicht vorhanden' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02 M0024881131' at offset '24837029888'
Error 'OS error - Dieses Gerät ist nicht vorhanden' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02 M0024881131' at offset '24837072896'
Error 'OS error - Dieses Gerät ist nicht vorhanden' occurred while reading '/AACS/MKB_RO.inf' at offset '0'
Error 'OS error - Dieses Gerät ist nicht vorhanden' occurred while reading '/AACS/Content000.cer' at offset '0'
asmcom
Post by asmcom »
MrDark wrote: Thu Mar 10, 2022 9:08 pm I hope someone here can help me. I am desperate and do not know what else to do:/
MakeMKV error Log:
Here is some helpful advice:
Please ensure that “Show AV Synchronization Messages” and “Expert Mode” are enabled in MakeMKV Settings.
If you are using Windows 10 / 11, please configure MakeMKV to run as administrator when launching. To do this right click on the MakeMKV shortcut or MakeMKV .exe file which can be found in this location, “"C:\Program Files (x86)\MakeMKV.exe" and choose properties/then select the compatibility tab and tick the box saying “Run this program as an administrator” and click apply.
When using MakeMKV 1st of all make sure MakeMKV is closed. Then insert disc. When you see the disc appear in the explorer then open the MakeMKV application.
Asmcom :mrgreen:
MrDark
Post by MrDark »
asmcom wrote: Thu Mar 10, 2022 9:28 pm
MakeMKV error Log:
Asmcom :mrgreen:
I have now enabled "Show AV Sync Message" and "Expert Mode". Even as an administrator and with the procedure you described in the last sentence, I have the same error message as above. The "Info" tab only shows "No information available".
MrDark
Post by MrDark »
MakeMKV error Log:
Asmcom :mrgreen:
here a addition to my last post. have now received another error:
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.03 M0024881131' at offset '23967694848'
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.03 M0024881131' at offset '23967758336'
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.03 M0024881131' at offset '655360'
udf: UDF mount: disc not properly formatted or damaged disc (rootdirs failing)
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.03 M0024881131' at offset '32768'
Baby_Groot wrote: Thu Mar 10, 2022 7:36 pm Just checking whether it's possible to change the firmware on my blu-ray drives to make them UHD compatible? I have two drives (both the same) and they're MT1959 platform and manufactured after 2015 (manufactured May 2016 and the other March 2021). The drive models are the external LG BP50NB40 but with SVC code NB40.
Drive Information:
Revision: 1.00
Drive Information:
Revision: 1.03
Thanks! :)
The older one I am not 100% on but I do think it should be ok. If you are not afraid of bricking it, give it a try.
The 2nd one can be done, for sure. Most of the BP50NB40's I have flashed are SVC: NB40.
For UHD campatibility, these need to be cross-flashed to either BP60NB10 or BU40N firmware as the BP50NB40 firmware is not UHD capable. If you don't want to do it yourself, you can get a single drive flasher from me which is very easy to use. See my signature for the link.
