Pioneer BDR-XD07UHD
ArArdin
Pioneer BDR-XD07UHD
Post by ArArdin »
Hi all,
I'm considering to buy this one because I always enjoyed the quality that Pioneer drives were build with. Does this one have it too?
If anyone has this drive, I'd like to know how handling and ripping experiences are. And if - next to MakeMKV - AnyDVD HD is supported too.
Thanks in advance.
Re: Pioneer BDR-XD07UHD
The list of which drives work are in the first post of Ultimate UHD Drives Flashing Guide Updated 2022
ArArdin
Post by ArArdin »
Yeah, the list in the first post is exactly where I got it from.
I'm hoping owners could tell me a it more about the build quality and general experience. Or specific behaviour compared to other drives.
EretzAshur
Post by EretzAshur »
Is this drive capable of ripping UHD Discs?
EretzAshur wrote: Fri Mar 11, 2022 12:12 am Is this drive capable of ripping UHD Discs?
All Pioneer UHD drive models can rip UHD discs. I'm also certain that they only work with MakeMKV for UHD ripping purposes.
Post by SamuriHL »
MartyMcNuts wrote: Fri Mar 11, 2022 6:28 am All Pioneer UHD drive models can rip UHD discs. I'm also certain that they only work with MakeMKV for UHD ripping purposes.
That's not entirely accurate. While LibreDrive is most DEFINITELY needed, thus requiring MakeMKV be installed, there is another product that has been able to make use of LibreDrive enabled drives.
asmcom
Post by asmcom »
ArArdin wrote: Mon Feb 28, 2022 5:02 pm Yeah, the list in the first post is exactly where I got it from.
Hello ArArdin,
I have these drives in stock and I will be testing on Sunday. I can let you know how it goes and I can also supply you a drive to.
viewtopic.php?t=19387
Kind Regards
Asmcom
SamuriHL wrote: Fri Mar 11, 2022 4:11 pm
What product??
Post by d00zah »
MartyMcNuts wrote: Fri Mar 11, 2022 11:18 pm What product??
This one.
Post by SamuriHL »
Yup. It works very well. I use it with my Pio and bu40n drives.
SamuriHL wrote: Sat Mar 12, 2022 1:42 am Yup. It works very well. I use it with my Pio and bu40n drives.
Huh, well there you go. I was not aware that that application worked with any official UHD drives. Does that include the LG official UHD drives?
Post by SamuriHL »
Yes hence my mentioning the bu40n. ;) it works with any libredrive enabled drive, official or unofficial. Currently it's querying the sdf to see if a drive is supported by libredrive, activating it if it is, and then ignoring bus encryption on that drive. I love it because I always make a protected iso of my new discs so now I can just pop it in the drive and use its rip to iso function.
ArArdin
Post by ArArdin »
asmcom wrote: Fri Mar 11, 2022 10:03 pmHello ArArdin,
Thanks, but a few days ago I purchased a Pioneer BDR-S12UHT.
BTW I can confirm the BDR-S12UHT works with AnyDVD.
