Hi all,
I'm considering to buy this one because I always enjoyed the quality that Pioneer drives were build with. Does this one have it too?
If anyone has this drive, I'd like to know how handling and ripping experiences are. And if - next to MakeMKV - AnyDVD HD is supported too.
Thanks in advance.
Pioneer BDR-XD07UHD
Re: Pioneer BDR-XD07UHD
The list of which drives work are in the first post of Ultimate UHD Drives Flashing Guide Updated 2022
ArArdin
Yeah, the list in the first post is exactly where I got it from.
I'm hoping owners could tell me a it more about the build quality and general experience. Or specific behaviour compared to other drives.
EretzAshur
Is this drive capable of ripping UHD Discs?
All Pioneer UHD drive models can rip UHD discs. I'm also certain that they only work with MakeMKV for UHD ripping purposes.
That's not entirely accurate. While LibreDrive is most DEFINITELY needed, thus requiring MakeMKV be installed, there is another product that has been able to make use of LibreDrive enabled drives.MartyMcNuts wrote: Fri Mar 11, 2022 6:28 am All Pioneer UHD drive models can rip UHD discs. I'm also certain that they only work with MakeMKV for UHD ripping purposes.
asmcom
Hello ArArdin,ArArdin wrote: Mon Feb 28, 2022 5:02 pm Yeah, the list in the first post is exactly where I got it from.
I have these drives in stock and I will be testing on Sunday. I can let you know how it goes and I can also supply you a drive to.
viewtopic.php?t=19387
Kind Regards
Asmcom
What product??SamuriHL wrote: Fri Mar 11, 2022 4:11 pmThat's not entirely accurate. While LibreDrive is most DEFINITELY needed, thus requiring MakeMKV be installed, there is another product that has been able to make use of LibreDrive enabled drives.MartyMcNuts wrote: Fri Mar 11, 2022 6:28 am All Pioneer UHD drive models can rip UHD discs. I'm also certain that they only work with MakeMKV for UHD ripping purposes.
Yup. It works very well. I use it with my Pio and bu40n drives.
Huh, well there you go. I was not aware that that application worked with any official UHD drives. Does that include the LG official UHD drives?SamuriHL wrote: Sat Mar 12, 2022 1:42 am Yup. It works very well. I use it with my Pio and bu40n drives.
Yes hence my mentioning the bu40n.MartyMcNuts wrote:Huh, well there you go. I was not aware that that application worked with any official UHD drives. Does that include the LG official UHD drives?SamuriHL wrote: Sat Mar 12, 2022 1:42 am Yup. It works very well. I use it with my Pio and bu40n drives.
ArArdin
Thanks, but a few days ago I purchased a Pioneer BDR-S12UHT.asmcom wrote: Fri Mar 11, 2022 10:03 pmHello ArArdin,
BTW I can confirm the BDR-S12UHT works with AnyDVD.
