ok thanks ill update the stuff once you report back.itsvoodoo wrote: Fri Jan 07, 2022 1:16 am I tried on MacOS and Windows 10, those are the platforms I tested on. I do not run Windows 11 but can’t figure that it’s a Windows 11 specific deal. I’ll flash via sata and then try to see if the it will still rip in the enclosure
its problem not 11's tpm requirement then if your on 10 and mac
