Help flashing WH16NS60
grandpixel
Post by grandpixel »
I purchased Archgon 9.5mm drive, discovered it's actually a LG BU40N, tried the GUI flash tool, didn't work - don't remember why, tried makemkvcon64.exe f --all-yes etc, flashed successfully to 1.00, shows in MakeMKV as LibreDrive, etc.. all is well, ripping 4K discs for days.
So I ordered a couple of WH16NS60 for a different machine. Default firmware is 1.03. Using the same method as above, but with "enc" option, I'm trying to flash to "HL-DT-ST-BD-RE_WH16NS60-1.03-NM00600-212005081010.bin" but it gives me an error.
PS C:\Program Files (x86)\MakeMKV> .\makemkvcon64.exe f --all-yes -d D: rawflash enc -i .\HL-DT-ST-BD-RE_WH16NS60-1.03-NM00600-212005081010.bin
Reading input file .\HL-DT-ST-BD-RE_WH16NS60-1.03-NM00600-212005081010.bin
Current Drive ID: HL-DT-ST_BD-RE__WH16NS60_1.03_212005081010_KLFL5BG5428
Write DRAM NG 02/3A/01
Command produced error code 0x8f023a01
Here is the info from MakeMKV on the drive.
Product: BD-RE WH16NS60
Revision: 1.03
Serial number: KLFL5BG5428
Firmware date: 2120-05-08 10:10
Highest AACS version: 60
Harware support: Yes
Firmware support: No
Firmware version: 1.03
Any ideas what I'm doing wrong?
Re: Help flashing WH16NS60
makemkvcon64.exe f --all-yes -d D: rawflash enc -i C:\WH16NS60-1.02-MK.bin
do that in cmd not powershell
grandpixel
Maybe I'm blind but I've looked all over the forum for the MK firmware and all I can find is:
HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
DE_LG_WH16NS60_1.00.bin
Where do I get WH16NS60-1.02-MK.bin?
The firmware now is the factory 1.03. I can go to 1.02 MK without going to 1.03 MK?
Should I go to 1.00 after?
asmcom
Post by asmcom »
grandpixel wrote: Wed Oct 27, 2021 7:00 pm Maybe I'm blind but I've looked all over the forum for the MK firmware and all I can find is:
You have it already.
1.02mk
Asmcom :mrgreen:
grandpixel
I'm getting the same error.
grandpixel wrote: Wed Oct 27, 2021 11:05 pm I'm getting the same error.
Email me billycar5924@gmail.com I'll give you a free flasher just to see what's up here you seem to be doing things right
How is the drive connected to PC? Is the drive tray empty and closed?
grandpixel
Yes, drive is empty and closed. Connected internally via SATA. Going to email Billy and see if he can help.
grandpixel
Soo, I mentioned I have 2 new WH16NS60 drives. I just tried the other one and it worked fine to 1.02MK. I still need to figure out what's wrong with the first one.
(should I flash the one from 1.02MK to 1.00 now?)
grandpixel wrote: Thu Oct 28, 2021 4:08 pm Soo, I mentioned I have 2 new WH16NS60 drives. I just tried the other one and it worked fine to 1.02MK. I still need to figure out what's wrong with the first one.
If you only use MakeMKV for ripping, leave it on 1.02-MK. If you use other software, such as DVDFab, flash it to 1.00.
grandpixel
MartyMcNuts wrote: Thu Oct 28, 2021 11:19 pm If you only use MakeMKV for ripping, leave it on 1.02-MK. If you use other software, such as DVDFab, flash it to 1.00.
I mean, I'd like it to function as a normal drive otherwise.
The first drive still won't take a flash, even using Billy's script. Is there a tool to recover a drive? I'm not sure if it's actually "bricked". I've been using it to rip HD blu-rays.
grandpixel wrote: Fri Oct 29, 2021 12:05 am
well it still could be a few different things the drive is defective and wont take a flash i have seen that 1 time before.
the sata port is on does not support flashing some 3rd party sata controllers dont.
or its a new sub revision 1.03 i do notice a 10:10 after your fw that does not look familiar ill look in so some of my remote flash logs to see if i have others like that.
i would try swapping the sata port next with the drive you were able to flash.
grandpixel
First drive: haven't attempted swapping SATA ports yet.
Second drive: flashed to 1.02, and says it successfully flashed to 1.00, but still reporting 1.02 < now this is strange
C:\Program Files (x86)\MakeMKV>makemkvcon64.exe f --all-yes -d G: rawflash enc -i DE_LG_WH16NS60_1.00.bin
Reading input file DE_LG_WH16NS60_1.00.bin
Current Drive ID: HL-DT-ST_BD-RE__WH16NS60_1.02_211810291936_KLLL5BG5418
 100% Operation finished
Done successfully
Firmware version: 1.02
grandpixel
Drive 1: Swapping SATA ports fixed the problem. Flashed to 1.02.
Neither drive will flash to 1.00. It says "Programming flash - 100% Operation finished - Done successfully" but still showing 1.02. Well at least I can keep ripping now. Any ideas on getting to 1.00?
grandpixel wrote: Fri Oct 29, 2021 4:49 am Drive 1: Swapping SATA ports fixed the problem. Flashed to 1.02.
Remove enc from command as the firmware is no longer encrypted.
