Help flashing WH16NS60
grandpixel
Post by grandpixel » Wed Oct 27, 2021 4:20 am
I purchased Archgon 9.5mm drive, discovered it's actually a LG BU40N, tried the GUI flash tool, didn't work - don't remember why, tried makemkvcon64.exe f --all-yes etc, flashed successfully to 1.00, shows in MakeMKV as LibreDrive, etc.. all is well, ripping 4K discs for days.
So I ordered a couple of WH16NS60 for a different machine. Default firmware is 1.03. Using the same method as above, but with "enc" option, I'm trying to flash to "HL-DT-ST-BD-RE_WH16NS60-1.03-NM00600-212005081010.bin" but it gives me an error.
PS C:\Program Files (x86)\MakeMKV> .\makemkvcon64.exe f --all-yes -d D: rawflash enc -i .\HL-DT-ST-BD-RE_WH16NS60-1.03-NM00600-212005081010.bin
Reading input file .\HL-DT-ST-BD-RE_WH16NS60-1.03-NM00600-212005081010.bin
Current Drive ID: HL-DT-ST_BD-RE__WH16NS60_1.03_212005081010_KLFL5BG5428
Write DRAM NG 02/3A/01
Command produced error code 0x8f023a01
Here is the info from MakeMKV on the drive.
Product: BD-RE WH16NS60
Revision: 1.03
Serial number: KLFL5BG5428
Firmware date: 2120-05-08 10:10
Highest AACS version: 60
Harware support: Yes
Firmware support: No
Firmware version: 1.03
Any ideas what I'm doing wrong?
Re: Help flashing WH16NS60
Post by Billycar11 » Wed Oct 27, 2021 5:58 am
makemkvcon64.exe f --all-yes -d D: rawflash enc -i C:\WH16NS60-1.02-MK.bin
do that in cmd not powershell
grandpixel
Post by grandpixel » Wed Oct 27, 2021 7:00 pm
Maybe I'm blind but I've looked all over the forum for the MK firmware and all I can find is:
HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
DE_LG_WH16NS60_1.00.bin
Where do I get WH16NS60-1.02-MK.bin?
The firmware now is the factory 1.03. I can go to 1.02 MK without going to 1.03 MK?
Should I go to 1.00 after?
asmcom
Post by asmcom » Wed Oct 27, 2021 8:26 pm
grandpixel wrote: Wed Oct 27, 2021 7:00 pm Maybe I'm blind but I've looked all over the forum for the MK firmware and all I can find is:
You have it already.
1.02mk
Asmcom :mrgreen:
grandpixel
Post by grandpixel » Wed Oct 27, 2021 11:05 pm
I'm getting the same error.
Post by Billycar11 » Wed Oct 27, 2021 11:08 pm
grandpixel wrote: Wed Oct 27, 2021 11:05 pm I'm getting the same error.
Email me billycar5924@gmail.com I'll give you a free flasher just to see what's up here you seem to be doing things right
Post by MartyMcNuts » Wed Oct 27, 2021 11:17 pm
How is the drive connected to PC? Is the drive tray empty and closed?
grandpixel
Post by grandpixel » Thu Oct 28, 2021 3:52 pm
Yes, drive is empty and closed. Connected internally via SATA. Going to email Billy and see if he can help.
grandpixel
Post by grandpixel » Thu Oct 28, 2021 4:08 pm
Soo, I mentioned I have 2 new WH16NS60 drives. I just tried the other one and it worked fine to 1.02MK. I still need to figure out what's wrong with the first one.
(should I flash the one from 1.02MK to 1.00 now?)
Post by MartyMcNuts » Thu Oct 28, 2021 11:19 pm
grandpixel wrote: Thu Oct 28, 2021 4:08 pm Soo, I mentioned I have 2 new WH16NS60 drives. I just tried the other one and it worked fine to 1.02MK. I still need to figure out what's wrong with the first one.
If you only use MakeMKV for ripping, leave it on 1.02-MK. If you use other software, such as DVDFab, flash it to 1.00.
grandpixel
Post by grandpixel » Fri Oct 29, 2021 12:05 am
MartyMcNuts wrote: Thu Oct 28, 2021 11:19 pm If you only use MakeMKV for ripping, leave it on 1.02-MK. If you use other software, such as DVDFab, flash it to 1.00.
I mean, I'd like it to function as a normal drive otherwise.
The first drive still won't take a flash, even using Billy's script. Is there a tool to recover a drive? I'm not sure if it's actually "bricked". I've been using it to rip HD blu-rays.
Post by Billycar11 » Fri Oct 29, 2021 12:12 am
grandpixel wrote: Fri Oct 29, 2021 12:05 am
well it still could be a few different things the drive is defective and wont take a flash i have seen that 1 time before.
the sata port is on does not support flashing some 3rd party sata controllers dont.
or its a new sub revision 1.03 i do notice a 10:10 after your fw that does not look familiar ill look in so some of my remote flash logs to see if i have others like that.
i would try swapping the sata port next with the drive you were able to flash.
grandpixel
Post by grandpixel » Fri Oct 29, 2021 4:37 am
First drive: haven't attempted swapping SATA ports yet.
Second drive: flashed to 1.02, and says it successfully flashed to 1.00, but still reporting 1.02 < now this is strange
C:\Program Files (x86)\MakeMKV>makemkvcon64.exe f --all-yes -d G: rawflash enc -i DE_LG_WH16NS60_1.00.bin
Reading input file DE_LG_WH16NS60_1.00.bin
Current Drive ID: HL-DT-ST_BD-RE__WH16NS60_1.02_211810291936_KLLL5BG5418
 100% Operation finished
Done successfully
Firmware version: 1.02
grandpixel
Post by grandpixel » Fri Oct 29, 2021 4:49 am
Drive 1: Swapping SATA ports fixed the problem. Flashed to 1.02.
Neither drive will flash to 1.00. It says "Programming flash - 100% Operation finished - Done successfully" but still showing 1.02. Well at least I can keep ripping now. Any ideas on getting to 1.00?
Post by MartyMcNuts » Fri Oct 29, 2021 5:41 am
grandpixel wrote: Fri Oct 29, 2021 4:49 am Drive 1: Swapping SATA ports fixed the problem. Flashed to 1.02.
Remove enc from command as the firmware is no longer encrypted.
