software Question
ham6817
software Question
Post by ham6817 »
I'm looking for disk burning software. What's the go to software that is being used now a days. Sorry if not allowed
Re: software Question
There are dozens, if not hundreds, of disk authoring packages out there, from free to very expensive. To even start to answer a question like this, you need to specify the environment you're using (Windows, MacOS, Linux, *BSD, other) and your budget.
ham6817
Post by ham6817 »
I understand there are countless numbers of programs out there, But instead of me wasting time and money going through searching down loading and trying them out only to find out i do like it, i rather see what people are using or recommend. I run windows 10 and my budget is based on how much i like the program to even want to spend money on it. So do you have recommendations or not?
asmcom
Post by asmcom »
ham6817 wrote: Sun Sep 19, 2021 6:24 pm I understand there are countless numbers of programs out there, But instead of me wasting time and money going through searching down loading and trying them out only to find out i do like it, i rather see what people are using or recommend. I run windows 10 and my budget is based on how much i like the program to even want to spend money on it. So do you have recommendations or not?
Try Imgburn, great program and great Author.
https://www.imgburn.com/
Regards Asmcom :mrgreen:
