UHD Issues
icebreaker374
UHD Issues
#1 Post by icebreaker374 » Mon Aug 16, 2021 12:33 am
So followup to my last post. I've tried half the Fast and Furious UHD discs I have (I own 1-8) and all of them stop at about halfway and say "The source file '/BDMV/STREAM/xxxxx.m2ts' is corrupt or invalid at offset xxxxxxxxxxx, attempting to work around". I'm using an LG BP60NB10, these discs appear to be AACS 2.0/C v61-65. My UHD Harry Potter set has ZERO issue and it's the exact same AACS range, at this point I'm starting to wonder because I cant find decryption keys for any UHD F&F movies online. Is my drive failing, incapable, or is it a disc issue? I hope its not disc because they're spotless BRAND NEW disks, I just took the plastic wrap off the set YESTERDAY. Would I be better off with an Asus BW-16D1HT? Any help would be so graciously appreciated.
Sidenote, it does show drive platform as mt1959 and my drive is using MK firmware BP60NB10 1.02. Error type reads as a 'HashCheck Error'.
asmcom
Re: UHD Issues
#2 Post by asmcom » Mon Aug 16, 2021 1:15 am
icebreaker374 wrote: Mon Aug 16, 2021 12:33 am So followup to my last post. I've tried half the Fast and Furious UHD discs I have (I own 1-8) and all of them stop at about halfway and say "The source file '/BDMV/STREAM/xxxxx.m2ts' is corrupt or invalid at offset xxxxxxxxxxx, attempting to work around". I'm using an LG BP60NB10, these discs appear to be AACS 2.0/C v61-65. My UHD Harry Potter set has ZERO issue and it's the exact same AACS range, at this point I'm starting to wonder because I cant find decryption keys for any UHD F&F movies online. Is my drive failing, incapable, or is it a disc issue? I hope its not disc because they're spotless BRAND NEW disks, I just took the plastic wrap off the set YESTERDAY. Would I be better off with an Asus BW-16D1HT? Any help would be so graciously appreciated.
I have sent you PM.
Asmcom :mrgreen:
bigdogaxis
Re: UHD Issues
#3 Post by bigdogaxis » Tue Nov 29, 2022 4:40 pm
Having the same issue with this same set of discs. I have found a suggestion to clean them with a 50/50 water/alcohol solution. What was your solution? My drives are the BU40N, MKV V1.17.
