Hi there! I heard on a thread that it's possible to play MAKEMKV backups on Sony UBX700 and get dolby atmos and vision. is that true?
if yes how?
how to play backups on UBX700?
Bigboypants
Re: how to play backups on UBX700?
how amazing! I had no idea search existed. i'll do that next time that I want to read four hundred pages of a topic.
nekno
This may work for you. It seems to be working for me in testing.
You can test using the first two minutes of a file by adding the "-ss 0 -t 120" options to your ffmpeg command:
And then in tsMuxer, enable Cutting on the Split & Cut tab and set an end time of "00:02:00.000", to mux 2 mins of audio with the 2 mins of video.
ffmpeg -i uhdbd.m2ts -ss 0 -t 120 -c:v copy -vbsf hevc_mp4toannexb -f hevc - | dovi_tool -m 2 convert --discard -
