Can't decide which drive to get
vetting
#1 Post by vetting » Sun Apr 18, 2021 5:58 pm
I am in the making of buying a drive with enclosure from one of the vendors here on the forum. After reading many post about the drives, I can't come to a conclusion about which drive to get. Some say the ASUS BW-16D1HT is a workhorese, and the one to get. Som say the LG WH16NS60 is the fastest and the best. Some say both these drives are prone to die on you with about 50 rips. Some say the best to get is the LG BU40N beacuse it will not fail you.
Well... I love makeMKV, and I need a new drive to rip my blurays. What do you guys recomend?
Re: Can't decide which drive to get
#2 Post by Billycar11 » Sun Apr 18, 2021 7:38 pm
I recommend the BU40N they have a low fail rate.
All the 5.25 desktop drives are the same if your going to get any of those get the cheapest WH14NS40
vetting
#3 Post by vetting » Mon Apr 19, 2021 9:27 pm
Billycar11 wrote: Sun Apr 18, 2021 7:38 pm I recommend the BU40N they have a low fail rate.
Thank you for your recommendation :)
asmcom
#4 Post by asmcom » Mon Apr 19, 2021 10:45 pm
vetting wrote: Sun Apr 18, 2021 5:58 pm I am in the making of buying a drive with enclosure from one of the vendors here on the forum. After reading many post about the drives, I can't come to a conclusion about which drive to get. Some say the ASUS BW-16D1HT is a workhorese, and the one to get. Som say the LG WH16NS60 is the fastest and the best. Some say both these drives are prone to die on you with about 50 rips. Some say the best to get is the LG BU40N beacuse it will not fail you.
I recommend BH16NS55. I have no faulty drives in the last 300 drives. Amazing product. Also BU40N is a very good drive, but can not handle speed control.
Kind Regards
Asmcom :mrgreen:
vetting
#5 Post by vetting » Wed Apr 21, 2021 10:03 am
asmcom wrote: Mon Apr 19, 2021 10:45 pm
Kind Regards
Asmcom :mrgreen:
