Barb and Star Go to Vista Del Mar (PLAYLIST) Please
Steveredrum
Post by Steveredrum » Fri Apr 02, 2021 3:10 am
Barb and Star Go to Vista Del Mar [U.S.A Retail]
PLAYLIST Please It's Screen Pass
hvnphoto
Re: Barb and Star Go to Vista Del Mar (PLAYLIST) Please
Post by hvnphoto » Sat Apr 03, 2021 9:19 pm
00214.MPLS
Steveredrum
Post by Steveredrum » Sun Apr 04, 2021 1:07 am
Thanks for your reply
hvnphoto
Post by hvnphoto » Sun Apr 04, 2021 3:40 pm
Title information
Name: Barb and Star Go To Vista Del Mar
Source file name: 00214.mpls
Duration: 1:46:59
Chapters count: 16
Segment count: 10
Segment map: 509,508,505,501,502,503,504,510,506,507
File name: Barb and Star Go To Vista Del Mar_t167.mkv
For those interested in the segment map.
digimars
Post by digimars » Wed Apr 07, 2021 8:55 pm
Does this playlist apply to the RedBox version as well?
asr101
Post by asr101 » Sat Apr 10, 2021 4:02 am
Thank you for helping us out.
sms7826
Post by sms7826 » Sat Apr 10, 2021 10:44 pm
00214.mpls appears to be the right one. The segment map matches, and it's ll there and in order. But the filename of the mkv is different. It wants to be t69
Post by Woodstock » Sat Apr 10, 2021 11:14 pm
MakeMKV filename depends on your minimum rip size. Someone with a 30 minimum size (like I use) will have different file numbers than someone using 120 or 1800 seconds.
Only the titles that meet the minimum file size are counted.
imacmike
Post by imacmike » Tue Apr 13, 2021 8:13 am
Target (US) exclusive edition has a different playlist, as 00214.mpls is not available on that edition. No other playlist contains the segment map listed above either. Appears to be a completely different authoring.
Chihiro Aston
Post by Chihiro Aston » Sat Apr 17, 2021 2:21 am
For the Target version of the Blu-ray, looks like the source file name is 00992.mpls [Segment map: 508,502,505,504,506,503,501,509,510,507].
I installed Java and pointed MakeMKV to the Java.exe file [Preferences > Protection]. This allows MakeMKV to read the menus on the disc. After you scan the disc, you'll see this track tagged as "FPL_MainFeature".
Stupidest movie I have seen in a while and I loved every minute :lol:.
DR650SE
Post by DR650SE » Thu Apr 22, 2021 10:14 pm
digimars wrote: Wed Apr 07, 2021 8:55 pm Does this playlist apply to the RedBox version as well?
Did you ever get an answer? I don't think this works on the Redbox version :(
tylergfoster
Post by tylergfoster » Thu Apr 20, 2023 2:40 am
Chihiro Aston wrote: Sat Apr 17, 2021 2:21 am For the Target version of the Blu-ray, looks like the source file name is 00992.mpls [Segment map: 508,502,505,504,506,503,501,509,510,507].
It's been a long time since this thread was bumped, but I have the Target disc. The title 00992 does not appear on my copy. I found one with the above segment map, but it is only 95% correct. The scene of Barb and Star at the hotel bar with Edgar is correct up to the point where Star uses her greeting card "talent" to cheer Edgar up, and then the sequence is out of order until Edgar is on the phone the next morning, at which point the entire rest of the movie is unaffected. If anyone has any tips on determining the correct segment map, I'd appreciate it.
Chihiro Aston
Post by Chihiro Aston » Tue Apr 02, 2024 6:07 pm
When I've had issues with finding the correct title track, I install Java. This thread should have the steps: viewtopic.php?t=24780. I just downloaded and installed on Windows 10. I rescanned the disc and (for me) it flagged 00209.mpls as "(FPL-MainFeature"). Apologies, not sure where I got 00992.mpls - I don't even have that track on my disc.
