Flashing DVDFab and mkv
KenVal
Hi have a slim LG bu40n drive, is there a firmware to work with DVDFab and mkv. I have used the DVDFab downgrade tool which has reduced firmware to 1.0 and works with DVDFab but not mkv, would like to use both systems if possible.
asmcom
Re: Flashing DVDFab and mkv
Being familiar with this drive and having helped you remotely. I would suggest to replace as it does not seem to function properly on 1.00 firmware. Can talk to you this week
Hope all is good in your life
Asmcom
Asmcom
How is your drive hooked up and what is the error you are getting full log would be helpfulKenVal wrote: Sun Mar 28, 2021 7:45 pm Hi have a slim LG bu40n drive, is there a firmware to work with DVDFab and mkv. I have used the DVDFab downgrade tool which has reduced firmware to 1.0 and works with DVDFab but not mkv, would like to use both systems if possible.
asmcom
Glad you are now sorted Ken. You know I am here to help anytime.
Asmcom
Asmcom
