Rip full 4K disc?
Ferrett1983
Rip full 4K disc?
Post by Ferrett1983 » Tue Jan 26, 2021 12:16 pm
Could anyone tell me if makemkv can rip the full 4K disc with all the menus etc? Also I'm reading that dolby vision is not very compatible with alot of devices, is there anyway you can disable this whilst using makemkv?
Sorry I'm relatively new to all this so any help would be much appreciated.
Re: Rip full 4K disc?
Post by Billycar11 » Tue Jan 26, 2021 12:46 pm
folder icon top left make sure to check the decrypt option
Ferrett1983
Post by Ferrett1983 » Tue Jan 26, 2021 1:14 pm
Thanks billycar, have you had any problems with ripping full 4k discs.
Post by Billycar11 » Tue Jan 26, 2021 1:30 pm
Ferrett1983 wrote: Tue Jan 26, 2021 1:14 pm Thanks billycar, have you had any problems with ripping full 4k discs.
Nope no problems related to backing the full disc works great in makemkv it's how I test my drives
asmcom
Post by asmcom » Mon Feb 01, 2021 3:16 am
Ferrett1983 wrote: Tue Jan 26, 2021 12:16 pm Hi,
Also, if you would like A ISO container, after folder backup, you can use Imgburn to create ISO.
Asmcom :mrgreen:
