UHD disc inconsistency
recordplay
So I been ripping Blu-ray for over 6 years now and 4K Blu-ray for 2 years and I have noticed that with 4K blu-rays the rate in which I get errors from discs is extremely higher than normal 1080p blurays I've done in the past. With normal 1080p, I would say I get no errors 99% of the time unless there is a visible scratch on the disc. With 4K, its a crapshoot. Every other disc I get it either won't rip completely because of errors, some slow down to the point of failure and then there are some that won't rip it all. Not to be negative because I would say 80% rip just fine and those are mostly Warner, Universal and Paramount. Lionsgate gives a little trouble but the worst is Fox and Disney with Disney being the worst by a longshot. To make it short, what is the reason behind this? are 4K Blu-ray more prone to errors and if so why do Disney have so many issues?
Re: UHD disc inconsistency
in my experience with UHD drives i have had 400+ drives and ripped 800+ UHDs mostly the same test discs but.
i have found its more likely your drive is defective than the disc any of the desktop drives that work with makemkv are just no where near as good and consistent as the BU40N.
there are some stand out bad discs like Blackhawk but most are fine.
and yes bd 66 and bd 100 both uhd disc types are currently, are harder to read by any drive that can do it but some like the BU40N are better at it
recordplay
Thats interesting because Sony disc rarely give me problems and Blackhawk rip fine for me. I probably will just bite the bullet and get another drive. Any suggestions? I see u mention the BU40N. Where can I purchase one that can rip 4k discs with the firmware?Billycar11 wrote: Sun Jan 10, 2021 5:47 am in my experience with UHD drives i have had 400+ drives and ripped 800+ UHDs mostly the same test discs but.
https://www.makemkv.com/forum/viewtopic ... 16&t=19634
See the Recommended Pre-Flashed Drive Sellers section.
jonghotti
- Contact:
Don't worry people you can trust your desktop drives.
asmcom
Well said, I second that. My customers have nothing but praise, for the desktop drives I have supplied.
Asmcom
We all know the desktop drives have quality problems.asmcom wrote: Sun Jan 10, 2021 9:48 pm
Asmcom![]()
You yourself have admitted it.
Maybe what we consider a bad drive differs but if any drive I get that has trouble with any disc I would consider that drive defective if that disc worked in one of my known good drives.
So all your drives that failed on game if thrones I would have returned.
asmcom wrote: Fri Dec 25, 2020 2:11 amI have just backed up Seasons 1 to 8 and the 3 bonus discs yesterday.sm754plop wrote: Wed Dec 23, 2020 1:05 pm Firstly please merge with the other GOT thread - as its the steelbook version I thought it might be better to do a new thread.
I have a ASUS BW-16D1HT 3.01 which just ejects the new GOT Steel book collection released Dec 14th.
Have tried with a couple discs from S1 and S8
Would it work if i upgrade my ASUS Drive flash? Im on mac so will have to find a windows laptop, or see if i can get bootcamp on a 2010 MacPro running Mojave.
All other times ive used this drive its worked, so maybe there is new drm on the discs?
I used the following drives.
2 X BU40N 1-03mk
2 X BH16NS55 CF WH16NS60 1-02mk
2 X BH16NS40 CF WH16NS60 1-02mk
ASUS Firmware 3.00, 3.01 and 3.02 was having problems with most of the discs in Seasons 2 and 3. But on other titles the ASUS could be the best and the LG Drives could struggle.
On this occasion I found the BH16NS55 and the BU40N to be the most reliable. All done, no hash errors
Asmcom![]()
jonghotti
- Contact:
Billy, enough. Please stop hijacking threads with this stuff.
Stop deleting your threads with this stuffjonghotti wrote: Sun Jan 10, 2021 10:35 pm Billy, enough. Please stop hijacking threads with this stuff.
Sorry sellers! Before buying a new drive clean all your UHD discs with liquid soap and warm water. Rub with microfiber cloth after that. Try again with your current drive.
To be clear I'm not saying anyone flashes drives wrong or bad you can't if the drive is the right hardware we all do it the same way and we all know what we are doing.
This all comes down to lg and asus not us.
only our testing methods are different.
And yes you should always clean your discs if you have trouble before determine if you need a new drive my usual recommendation is
Clean disc
Replace disc
Clean drive laser
Optional reduce read speed
New drive
Clean disc
Replace disc
Clean drive laser
New drive
asmcom
Yes Billy I returned my 1 ASUS drive that I Flashed with three different firmwares. 3.00, 3.01 & 3.10mk it was indeed found to be faulty.Billycar11 wrote: Sun Jan 10, 2021 10:25 pmWe all know the desktop drives have quality problems.asmcom wrote: Sun Jan 10, 2021 9:48 pm
Asmcom![]()
So all your drives that failed on game if thrones I would have returned.asmcom wrote: Fri Dec 25, 2020 2:11 amI have just backed up Seasons 1 to 8 and the 3 bonus discs yesterday.sm754plop wrote: Wed Dec 23, 2020 1:05 pm Firstly please merge with the other GOT thread - as its the steelbook version I thought it might be better to do a new thread.
2 X BU40N 1-03mk
Asmcom![]()
That is my second ASUS drive faulty in over 270 drives. I would not say I have a problems with Desktop Drives because of this one drive.
Come on Billy give it a break. The whole world knows by now you hate desktop drives. Jonghotti is right, if you have said it once you have said it 100 times about desktop drives.
I have had 1 problem copying game of thrones box set with 1 x faulty ASUS drive, which is now 2 in total in the last 2 years. Hope this clarifies things for you Billy.
For the avoidance of doubt and clarification Billy, I had a faulty ASUS Drive which I noticed when backing up my Game of Thrones Box Set. It has now been replaced. I do not have problems with quality issues and Desktop Drives.
Because you did and you stopped selling them does not mean that I have problems with Desktop Drives.
Kind Regards Billy, hope all is good with you.
my 50+ pile of defective desktop drives says hello to your 2asmcom wrote: Mon Jan 11, 2021 4:44 am
I have had 1 problem coping game of thrones box set with 1 x faulty ASUS drive, which is now 2 in total in the last 2 years. Hope this clarifies things for you Billy.
Kind Regards Billy, hope all is good with you.![]()
asmcom
Touch wood Billycar11, hope I never have a pile of defective drives like this and hope it does not happen to Marty, Bluntman or Jonghotti either.
I wish you and your family Health and Happiness for 2021. Hopefully this dreadful Coronavirus will be put behind us and the new vaccines will help save lives.
Asmcom
Asmcom
Cid67
I'm going to have to agree with Billy. I had a lg desktop drive that i bought on eBay, pre patched. It came dead on arrival.I had it swapped out for another one. it worked for the most part at first but it stopped reading disks shortly after. Now i have a bu40n that i patched myself and it works great, may be anecdotal but it rings true to me. My bu40n is just far more reliable and it looks better too. slimmer, sleeker, faster etc. just my two cents.
