jonghotti
Re: Ultimate UHD Drives Flashing Guide Updated 2020
#511 Post by jonghotti » Thu Dec 31, 2020 8:34 pm
bobby121418 wrote: Thu Dec 31, 2020 12:55 am Hi,
I am looking to get a slim drive to flash myself. I was going to get LG BP60NB10 but it is now out of stock. Which other would the experts recommend?
LG BU40N with Vantec enclosure
Olds69Hrst
Re: Ultimate UHD Drives Flashing Guide Updated 2021
#512 Post by Olds69Hrst » Sun Jan 03, 2021 4:45 am
I'm running into the following error when trying to flash my drive (WH14NS40 SVC CODE:NS50)
Windows PowerShell
Copyright (C) Microsoft Corporation. All rights reserved.
Try the new cross-platform PowerShell https://aka.ms/pscore6
PS C:\WINDOWS\system32> cd..
PS C:\WINDOWS> cd..
PS C:\> cd "C:\Program Files (x86)\MakeMKV"
PS C:\Program Files (x86)\MakeMKV> .\makemkvcon64.exe f --all-yes -d E: rawflash enc -i C:\Users\Ed\Desktop\WH16NS60-1.02.bin
C:\Program Files (x86)\MakeMKV\makemkvcon64.exe: unrecognized option `--all-yes'
Use: makemkvcon [switches] Command [Parameters]
Commands:
info <source>
prints info about disc
mkv <source> <title id> <destination folder>
saves a single title to mkv file
backup <source> <destination folder>
backs up disc to a hard drive
Source specification:
iso:<FileName> - open iso image <FileName>
file:<FolderName> - open files in folder <FolderName>
Any help would be appreciated.
disc:<DiscId> - open disc with id <DiscId> (see list Command)
dev:<DeviceName> - open disc with OS device name <DeviceName>
Switches:
-r --robot - turn on "robot" mode, see http://www.makemkv.com/developers
#513 Post by MartyMcNuts » Sun Jan 03, 2021 10:55 pm
Olds69Hrst wrote: Sun Jan 03, 2021 4:45 am I'm running into the following error when trying to flash my drive (WH14NS40 SVC CODE:NS50)
Windows PowerShell
PS C:\WINDOWS> cd..
Commands:
info <source>
Switches:
1. Make sure you have at least MakeMKV version 1.15.1. The newer the better.
2. Use sdftool.exe instead of makemkvcon.exe
The rest of your command looks fine.
You could always use my SDFtool Flasher GUI. https://www.makemkv.com/forum/viewtopic ... 16&t=22896
jesperb
#514 Post by jesperb » Tue Jan 05, 2021 2:08 pm
Dear All.
First of all, thank you so much for this thread. It is sad that we have to work so hard to backup our legally obtained movies but here we are.
I'm looking for an external drive with which to backup UHD movies (and Blurays and DVDs but that not as much of a problem) and I have been going through the list at the top of the thread but finding a drive and an enclosure in Sweden has been a bit problematic.
I did find the ASUS BW-16D1H-U PRO but as an external drive, not the internal version that is listed here and I'm wondering if you know if this would work.
It looks like this:
Article number: 90DD01L0-M69000
I cannot see a firmware version as the shops typically do not list them.
I have also contacted Alex about a pre-flashed version but he understandably has a lot to do and if I could get something myself that would make it easier than international shipping.
I also found the LG BU40N but not the only slim enclosure that is recommended here.
Thank you all again
#515 Post by Woodstock » Tue Jan 05, 2021 2:25 pm
jesperb wrote: Tue Jan 05, 2021 2:08 pm I did find the ASUS BW-16D1H-U PRO but as an external drive, not the internal version that is listed here and I'm wondering if you know if this would work.
Short answer: No, it won't.
Longer answer: This is not a UHD-capable drive. It works fine from lesser things, but not UHD.
jesperb
#516 Post by jesperb » Tue Jan 05, 2021 3:51 pm
Thank you so much. I'm a bit confused as some drives that are not marked UHD can still be used, but maybe there is a way to tell that I have not figured out.
Nevertheless, I found that I could import the Buffalo BRUHD-PU3-BK UHD BD from Germany and that one should be flashable *fingers crossed*.
#517 Post by d00zah » Tue Jan 05, 2021 4:20 pm
jesperb wrote: Tue Jan 05, 2021 3:51 pm Thank you so much. I'm a bit confused as some drives that are not marked UHD can still be used, but maybe there is a way to tell that I have not figured out.
Of course, you could remove all doubt... Drives for sale, Flashing Services, where to buy...
ZmYkR
#518 Post by ZmYkR » Tue Jan 05, 2021 4:26 pm
Hey people.
I'm new to all this, so I have a few questions if you don't mind.
So first of all I checked which drives from the recommended list are available for me at a good price. Turns out there are 3 that I can get at pretty much the same price new.
LG BH16NS55
ASUS BW-16D1HT
LG BU40N
There is no “Best Drive” They are all made by LG and rebranded the drives just fit different use cases.
I get that, but can you tell me what the differences are between these drives (other than the BU40N being slim)?
I'd like to use my drive in an external enclosure, so the BU40N would be nice for that. But is it slower than the big boys, or worse in any other way?
Does it matter what enclosure I use? I understand that the Vantec ones are recommended here, but they don't seem to be available in the EU. What are other options, are there enclosures that straight up do not work, or would they just be slower or something like that?
If I buy one of the mentioned drives, I'll be guaranteed to get it working if I do everything right, or are there drives/versions of these drives, that can not be made suitable?
That's all for now. Thanks :)
kichilron
#519 Post by kichilron » Tue Jan 05, 2021 7:42 pm
hej everyone,
I have been using MakeMKV for a while now and just bought it as well. Though I never tried UHD disks, I would love to now that LOTR came out on 4K.
I have an ASUS BC-12D2HT and heard it's possible to flash it to be UHD Friendly. I can't make much of the tutorials provided.
Which is why I wanted to ask if anyone offers remote flashing (am willing to pay via PayPal)?
I don't have permission to PM anyone yet, as I'm new to the forum as it seems.
Would be glad about any replies, thank you.
#520 Post by Coopervid » Tue Jan 05, 2021 11:07 pm
ZmYkR wrote: Tue Jan 05, 2021 4:26 pm Hey people.
LG BH16NS55
ASUS BW-16D1HT
LG BU40N
Anything works for Makemkv. If you want to use AnyDVD as well you will have to get one of the full size drives. No slim.
#521 Post by Coopervid » Tue Jan 05, 2021 11:09 pm
kichilron wrote: Tue Jan 05, 2021 7:42 pm hej everyone,
The vendors like Billycar offer remote flashing. Check here:
https://www.makemkv.com/forum/viewforum.php?f=20
jonghotti
#522 Post by jonghotti » Wed Jan 06, 2021 1:46 am
I can help as well my contact info in my signature thank you.
myklj
#523 Post by myklj » Wed Jan 06, 2021 2:00 am
The SDFtool Flasher worked great! I downgraded my LG WH16NS40 from 1.03 to 1.02. The new results show it now as WH16NS60 at 1.02 (no longer S40). Looking at the video it shows using a MK bin file. I did not find that MK file but I seen an update previous (pg 10 - 2/7/20) where he recommends:
"flash HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin and be done with it, you fix not being able to downgrade, you get faster ripping and no sleep bug."
I did find that file! It ran all ran well. The MakeMKV immediately recognized ID changes but Win Device Mgr had to be rescanned a few times to catch it.
Great tools...Thanks!
Samazar
#524 Post by Samazar » Wed Jan 06, 2021 10:32 am
From the recommended drives in the OP, is there one now that is reliable and super fast - I guess speed is an advantage.
I'm an Apple user, is the Mac version of Make MKV just as good as the windows version. If not, I suppose I could look into a used windows laptop.
How long does it take to RIP one disc (2k and 4K)?
asmcom
#525 Post by asmcom » Wed Jan 06, 2021 4:30 pm
Samazar wrote: Wed Jan 06, 2021 10:32 am From the recommended drives in the OP, is there one now that is reliable and super fast - I guess speed is an advantage.
Sent you a private message.
Asmcom :mrgreen:
