Help with deciding which drive to get
Ausfahrt
#1 Post by Ausfahrt » Thu Dec 24, 2020 2:19 pm
I've read the "Ultimate UHD Drives Flashing Guide Updated 2020" which states there is no "best drive".
However, reading posts on the forum gives me the impression that certain drives are more stable than or can become faster than others after being flashed with certain firmware.
These are the three drives available to me:
ASUS BW-16D1HT: €75
LG BH16NS55: €86
LG BH16NS40: €67
If you consider stability, price and flashing options, which drive should I buy?
Thank you all in advance!
Re: Help with deciding which drive to get
#2 Post by dcoke22 » Thu Dec 24, 2020 4:08 pm
I have the ASUS and it has treated me well.
#3 Post by Coopervid » Thu Dec 24, 2020 4:33 pm
You can also find the LG BH16NS55 for the same price as the NS40. These drives are all more or less identical and can be cross-flashed to each other. I have 2 BH16NS55 cross-flahed to ASUS BW16D1HT 3.10 MK as I think this is the best firmware.
Ausfahrt
#4 Post by Ausfahrt » Thu Dec 24, 2020 5:08 pm
I wrote the cheapest price I could find (local internet stores and amazon.de) and NS40 is cheaper. Is there any reason to get the BH16NS55 over the BH16NS40?
asmcom
#5 Post by asmcom » Fri Dec 25, 2020 2:44 am
Be careful when buying the BH16NS55 and also the BH16NS40.
This LG-BH16NS55 model can be purchased cheap on eBay or Amazon as in most cases the drive is the old LG model, white and grey Box or just bulk barebones.
The new Hitachi LG model SVC NS55 is a superior drive and hardware. The newer Hitachi Drive comes in a Hitachi LG box, colour black. To clarify superior, I find the new Hitachi drives quieter and will read most discs thrown at it. When Cross-flashed to WH16NS60 1.02mk the Hitachi model performs better than the older LG model.
The same for the BH16NS40 you can buy the old models SVC NS50 on Amazon or eBay.
The newer 2020 model is SVC NS51.
So be careful with these older models.
Kind Regards
Asmcom :mrgreen:
jonghotti
#6 Post by jonghotti » Fri Dec 25, 2020 2:57 am
Cheaper is never better. If the intent is to buy cheap most likely that is exactly what you’ll end up with
As to the other thing, if it says Hitachi LG or HLDS you want that and skip the other thing!
asmcom
#7 Post by asmcom » Fri Dec 25, 2020 3:09 am
Cheaper is never better. If the intent is to buy cheap most likely that is exactly what you’ll end up with Image
As to the other thing, if it says Hitachi LG or HLDD you want that and skip the other thing!
100% correct Alex. I have had so many customers over the last year who have contacted me after buying garbage drives on Amazon / eBay "basically returns that have been tested with a disc in, disc read, this drive must be okay, let's send this out again"
Some of these customers ends up spending twice the amount of money that they intended, instead of dealing with highly recommend sellers like yourself, Billycar11, Bluntman and Martymcnuts.
It makes common sense sometimes for customers to contact the recommend sellers on the  MakeMKV forum in the 1st place, to seek advise and deal with an experienced seller who eats and sleeps UHD Friendly optical drives. The sellers on the forum can also tell the customers 1st hand which are the best models to go for and which models that are best avoided. Its also fair to say that some forum members are very well informed and read the forum extensively. Therefore they know exactly what they are doing and by virtue they can then make an informed decision and purchase their own drive and flash the firmware successfully.
In the long run getting good advise from a seller on the forum will be a better solution and investment for new customers who do not have first hand knowledge of the pros and cons when purchasing an UHD Friendly Blu-ray Drive.
Happy Christmas
#8 Post by Coopervid » Fri Dec 25, 2020 11:52 am
The guys are absolutely right. What you found on Amazon regarding the BH16NS40 is the old variant SVC40 that is not UHD compatible and made in 2014.
Search with geizhals.eu for LG BH16NS55 and you will find prices in the area of 65 Euros for it e.g. at Alternate.
jonghotti
#9 Post by jonghotti » Sat Dec 26, 2020 2:10 am
Supporting the independent sellers on this board is THE way to go.
We work tirelessly for our customers and back it up with awesome support.
You will not get that from Amazon!
Thank you for your consideration!
