BU40N 1.03 to MK 1.03 - Not sure where to go from here
bachelorbob
Re: BU40N 1.03 to MK 1.03 - Not sure where to go from here
#16 Post by bachelorbob » Wed Dec 09, 2020 8:47 pm
For further clarification:
Specs from MakeMKV:
Manufacturer: hp HLDS
Product: BDRE BU40N
Revision: BW42
Firmware date: 2117-11-29 16:55
Bus encryption flags: 1F
Specs from Mac system report:
BDRE BU40N :
Product ID: 0x3940
Vendor ID: 0x13fd (Initio Corporation)
Version: 3.10
Serial Number: 38343543533032333238392020202020
Speed: Up to 5 Gb/sec
Location ID: 0x14400000 / 13
I seem to be the only person with a BW42 revision drive here. (I have seen others post about BW41.) I have not tested the drive with a UHD disc yet, but the drive does have the CD rip issue/bug.
So, flash with 1.03 MK or 1.04 MK? Is there an HP (not ASUS) BU40N 3.1x MK firmware?
#17 Post by Billycar11 » Wed Dec 09, 2020 10:46 pm
Yes flash BU40N 1.03 MK as my guide says
It's in the all you need firmware pack
bachelorbob
#18 Post by bachelorbob » Wed Dec 09, 2020 10:55 pm
Even though 1.03 MK is for an LG BU40N and mine is an HP BU40N with a 3.10 firmware? I am not willing to brick the drive on an experiment. And I am unable to save/extract the stock firmware as almost all utilities, instructions, and applications are for Windows/PC.
#19 Post by Billycar11 » Wed Dec 09, 2020 11:36 pm
bachelorbob wrote: Wed Dec 09, 2020 10:55 pm Even though 1.03 MK is for an LG BU40N and mine is an HP BU40N with a 3.10 firmware? I am not willing to brick the drive on an experiment. And I am unable to save/extract the stock firmware as almost all utilities, instructions, and applications are for Windows/PC.
then flashing is not for you there is always a chance to brick it.
also you dont have 3.10 fw you have bw42.
all bu40ns should be intercompatible i would flash it but if you dont want to you can always buy a preflashed and tested drive
asmcom
#20 Post by asmcom » Thu Dec 10, 2020 7:00 am
Deleted
asmcom
#21 Post by asmcom » Thu Dec 10, 2020 7:03 am
Billycar11 wrote: Thu Jul 11, 2019 8:18 am definitely do not flash asus 3.10mk you will be unable to go back to bu40n fw without the new dos flash windows flashers won't work, i have done it to prove amscom WRONG before 1.03mk was out and well he is WRONG but see if i release this info publicly people will misread/understand it again and ruin their dive.
if anyone softbricks there drive this way pm me if and only if your pc supports dosflash i'll help you
I have never Flashed 3.10mk to 1.03mk in my life.
I confirm you can flash. Hitachi LG-BU40N 1.03 to 1. 03mk no problem command line or LG Patched Flasher.
Asmcom :mrgreen:
#22 Post by Billycar11 » Thu Dec 10, 2020 7:09 am
asmcom wrote: Thu Dec 10, 2020 7:03 am
Asmcom :mrgreen:
yes this was refenced from when there was no mk 1.03 bu40n and you could downgrade it with asus firmware but you needed dosflash to recover it
asmcom
#23 Post by asmcom » Thu Dec 10, 2020 7:14 am
Billycar11 wrote: Thu Dec 10, 2020 7:09 am
Asmcom :mrgreen:
Hi Billy,
Must be cross wires. I would never flash a desktop drive with Slim and Vice Versa even when drunk LOL.
I hope you and your family are well and have a good Christmas.
Regards
Asmcom :mrgreen:
Grentuu
#24 Post by Grentuu » Mon Aug 03, 2026 7:23 pm
Verbatim 43888 external HL-DT-ST BU40N Firmware 1.05 MT1959
Purchased toay.
I have SDFTool v1.3.6 and the latest All You Need Firmware Pack. Which exact firmware file should I flash? My pack contains DE_LG_BU40N_1.03.bin but not DE_LG_BU40N_1.03_MK.bin.
Sayaka
#25 Post by Sayaka » Mon Aug 03, 2026 9:52 pm
If you downloaded the latest All You Need Firmware Pack from Marty's SDFtool Flasher thread, you should most certainly have a DE_LG_BU40N_1.03_MK.bin file and a DE_LG_BU40N_1.00.bin file inside the Slim External Drives folder.
Remove the disc from the drive if there is one.
Flash DE_LG_BU40N_1.03_MK.bin, leave encryption as is (it will likely be ticked), no bootloader either, just do a regular WRITE for this one, NOT Recover.
Unplug the drive and leave it that way for 30 seconds. Plug it back in. Check that the flash succeeded with MakeMKV. Close MakeMKV.
Then, if you plan on using DVDFab or want additional Linux compatibility, flash DE_LG_BU40N_1.00.bin, this time encryption will be unticked for sure, leave it as is, no bootloader either; again just do a regular WRITE for this one, NOT Recover.
Unplug the drive and leave it that way for 30 seconds. Plug it back in. Enjoy. :)
