BU40N 1.03 to MK 1.03 - Not sure where to go from here
bachelorbob
Re: BU40N 1.03 to MK 1.03 - Not sure where to go from here
Post by bachelorbob »
For further clarification:
Specs from MakeMKV:
Manufacturer: hp HLDS
Product: BDRE BU40N
Revision: BW42
Firmware date: 2117-11-29 16:55
Bus encryption flags: 1F
Specs from Mac system report:
BDRE BU40N :
Product ID: 0x3940
Vendor ID: 0x13fd (Initio Corporation)
Version: 3.10
Serial Number: 38343543533032333238392020202020
Speed: Up to 5 Gb/sec
Location ID: 0x14400000 / 13
I seem to be the only person with a BW42 revision drive here. (I have seen others post about BW41.) I have not tested the drive with a UHD disc yet, but the drive does have the CD rip issue/bug.
So, flash with 1.03 MK or 1.04 MK? Is there an HP (not ASUS) BU40N 3.1x MK firmware?
Yes flash BU40N 1.03 MK as my guide says
It's in the all you need firmware pack
bachelorbob
Even though 1.03 MK is for an LG BU40N and mine is an HP BU40N with a 3.10 firmware? I am not willing to brick the drive on an experiment. And I am unable to save/extract the stock firmware as almost all utilities, instructions, and applications are for Windows/PC.
bachelorbob wrote: Wed Dec 09, 2020 10:55 pm Even though 1.03 MK is for an LG BU40N and mine is an HP BU40N with a 3.10 firmware? I am not willing to brick the drive on an experiment. And I am unable to save/extract the stock firmware as almost all utilities, instructions, and applications are for Windows/PC.
then flashing is not for you there is always a chance to brick it.
also you dont have 3.10 fw you have bw42.
all bu40ns should be intercompatible i would flash it but if you dont want to you can always buy a preflashed and tested drive
asmcom
Post by asmcom »
Deleted
asmcom
Post by asmcom »
Billycar11 wrote: Thu Jul 11, 2019 8:18 am definitely do not flash asus 3.10mk you will be unable to go back to bu40n fw without the new dos flash windows flashers won't work, i have done it to prove amscom WRONG before 1.03mk was out and well he is WRONG but see if i release this info publicly people will misread/understand it again and ruin their dive.
if anyone softbricks there drive this way pm me if and only if your pc supports dosflash i'll help you
I have never Flashed 3.10mk to 1.03mk in my life.
I confirm you can flash. Hitachi LG-BU40N 1.03 to 1. 03mk no problem command line or LG Patched Flasher.
Asmcom :mrgreen:
asmcom wrote: Thu Dec 10, 2020 7:03 am
Asmcom :mrgreen:
yes this was refenced from when there was no mk 1.03 bu40n and you could downgrade it with asus firmware but you needed dosflash to recover it
asmcom
Post by asmcom »
Billycar11 wrote: Thu Dec 10, 2020 7:09 am
Asmcom :mrgreen:
Hi Billy,
Must be cross wires. I would never flash a desktop drive with Slim and Vice Versa even when drunk LOL.
I hope you and your family are well and have a good Christmas.
Regards
Asmcom :mrgreen:
