Public KeyDB Disc Submissions
fujiland2046
Post by fujiland2046 »
fujiland2046 wrote: Thu Oct 29, 2026 10:11 am Disc type: UHD - The Protector, label 88FU046B
Disc ID: C8C751E0793B4E9340B2AEF6E247FA37BE385EBE
Disc dump filename: MKB20_v82_88FU046B_FC73.tgz
Drive: Asus BC-12D2HT (Corrected)
Drive firmware: 3.00 (Corrected)
Hey fujiland2046, thanks for following the submission template but your disc drive firmware doesn't allow creating complete disc dump files. If the MakeMKV status for your drive contains this line:
BD raw metadata read: Partial
It means that you'll need to flash an alternative firmware. I think your drive should be compatible with the WH16NS60 firmware series but I'd double check in the LibreDrive section of the forum. Once your drive has been flashed and you see:
Feel free to generate a new disc dump file and post it to this thread.
Hi, here is the new disc dump by LG LibreDrive
Drive: LG BU40N
Drive firmware: 1.00 https://drive.google.com/file/d/1lR7_tA ... drive_link
and also the MKB_RO.inf file from the disc dump file - copy it directly from the disc): https://drive.google.com/file/d/1INFA-v ... sp=sharing
keydb_helper
Post by keydb_helper »
Thanks to everyone who followed the template and provided new disc dump files. The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
MKB20_v72_Jaws_CC5B
*MKB20_v82_88FU046B_FC73
*MKB20_v82_FRANKENSTEIN_-_DISC_ONE_C7CA
*MKB20_v82_FRANKENSTEIN_-_DISC_TWO_B976
*MKB20_v82_Gone_with_the_Wind_Part_1_F7B2
*MKB20_v82_Gone_with_the_Wind_Part_2_76E8
*MKB20_v82_The_Family_Man_8442
*MKB20_v82_The_Uprising_7B98
Public KeyDB Disc Submissions KeyDB Download
AverZippy
Post by AverZippy »
Disc type: UHD (ARCANE S1 DISC 2 UHD)
Disc ID: 4f9dd2df02a6c54793732e7fcd0675cb9a49a468
Disc dump filename: MKB20_v77_ARCANE_SEASON_1_-_DISC_2_189F.tgz
Drive: HL-DT-ST BD-RE WH16NS60
Drive firmware: 1.02
LibreDrive status: Enabled
Did you sync the public keydb within the last 15 minutes? yes
Have you verified that all submission links are accessible in incognito/private browsing? yes
Is your MKB_RO.inf file size at least 2MB? yes
MKB_RO.inf link: (The MKB_RO.inf file must be at least 2 megabytes. Do not just extract the MKB_RO.inf file from the disc dump file - copy it directly from the AACS folder on the original disc) https://drive.google.com/file/d/1mh6wiU ... drive_link
Disc dump link: https://drive.google.com/file/d/10GEIed ... drive_link
keydb_helper
AverZippy wrote: Fri Oct 30, 2026 1:34 am Disc type: UHD (ARCANE S1 DISC 2 UHD)
Thanks for the submission AverZippy. Your disc has been added to the public keydb.
bdsucker
Post by bdsucker »
Disc type: UHD
Disc ID: 0x5FD641D5CBFFCBB7A4EBD51B0A840629C9BF657B
Disc dump filename: MKB20_v82_SALO_7CFA
Drive: BW-16D1HT
Disc dump link: https://www.mediafire.com/file/yg8sr98c ... A.tgz/file
