Not possible. Your firmware is too new.antaresvii wrote: Wed Apr 30, 2025 2:34 am A screenshot of failure to open drive (works well with other formats):
LibreDrive for Pioneer drives
PM sent. And you should clean the laser lens regarding your reading problems.TylerInHiFi wrote: Wed Apr 30, 2025 6:03 am Hi everyone, I've got a BDR-XD07U with firmware 1.00 that doesn't seem to want to load UHD discs and is running into more frequent issues with regular blu-rays. I didn't see this firmware on the list of officially supported firmware versions, either. Here's the info panel:
Drive Information OS device name: /dev/rdisk2 Current profile: BD-ROM Manufacturer: PIONEER Product: BD-RW BDR-XD07U Revision: 1.00 Serial number: RCDL004518JP Firmware date: 2017-10-30 Bus encryption flags: 1B Highest AACS version: 81 LibreDrive Information Status: Enabled Drive platform: RS8D31 Firmware name: PIONEER BDR-BDS7 Firmware type: Original (unpatched) Firmware version: 1.00/ID69 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
mb_01
Hello, I have a PIONEER BDR-XD05 drive, is there a way making it read 4k UHD discs. Please help me? Thanks!!
Here is my drive:
OS device name: F:
Product: BD-RW BDR-XD05
Revision: 3.10
Serial number: __
Firmware date: 2017-06-22
Drive platform: RS8232
Firmware name: PIONEER BDR-XD05
Firmware version: 3.10/ID34
Here is my drive:
OS device name: F:
Revision: 3.10
Serial number: __
sure email me that info see belowmb_01 wrote: Fri May 02, 2025 8:18 am Hello, I have a PIONEER BDR-XD05 drive, is there a way making it read 4k UHD discs. Please help me? Thanks!!
Here is my drive:
OS device name: F:
Revision: 3.10
Serial number: __
dr1v3n
Hi there
Another BDR-XD05 user here.
May I ask for the matching firmeware? Thx!
OS device name: I:
Revision: 3.10
Serial number: RFDL020161WL
Highest AACS version: 68
PM sent.dr1v3n wrote: Tue May 06, 2025 6:13 am Hi thereAnother BDR-XD05 user here.
Drive Information OS device name: I: Manufacturer: PIONEER Product: BD-RW BDR-XD05 Revision: 3.10 Serial number: RFDL020161WL Firmware date: 2017-06-22 Bus encryption flags: 1B Highest AACS version: 68 LibreDrive Information Status: Enabled Drive platform: RS8232 Firmware name: PIONEER BDR-XD05 Firmware type: Original (unpatched) Firmware version: 3.10/ID34 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
dr1v3n
That worked great! Thank you very much!
mc_link
Does anybody know anything about the BDR-WX01DME which seems to be the only Pioneer drive available to purchase new in the UK now? How does it compare to the coveted BDR-X13/S13?
It doesn't mention supporting UHD, but perhaps like many other Pioneer drives it could do with a firmware flash?
Or, if anybody could sell me a BDR-X13 which is what I was really hoping for, I would be most grateful. Was holding off purchasing one until MakeMKV/LibreDrive supported them but now of course there appear to be none on the open market at all.
we dont know yet if mk fw will enable UHD reading or if you will need to cross flash we will see in the next few monthsmc_link wrote: Thu May 08, 2025 6:59 am Does anybody know anything about the BDR-WX01DME which seems to be the only Pioneer drive available to purchase new in the UK now? How does it compare to the coveted BDR-X13/S13?
mc_link
Hmm. It's rather difficult to justify the purchase not knowing whether it will actually work for UHD or not, on the other hand it's sure to sell out soon if I wait. What a gamble.Billycar11 wrote: Thu May 08, 2025 9:09 am we dont know yet if mk fw will enable UHD reading or if you will need to cross flash we will see in the next few months
i think it will do UHD but you may need to crossflash and then you lose the other junk that drives doesmc_link wrote: Thu May 08, 2025 9:14 amHmm. It's rather difficult to justify the purchase not knowing whether it will actually work for UHD or not, on the other hand it's sure to sell out soon if I wait. What a gamble.Billycar11 wrote: Thu May 08, 2025 9:09 am we dont know yet if mk fw will enable UHD reading or if you will need to cross flash we will see in the next few months
mc_link
I might take a punt. I'm only really interested in reading, maybe a little burning but it's unlikely.Billycar11 wrote: Thu May 08, 2025 10:59 am i think it will do UHD but you may need to crossflash and then you lose the other junk that drives does
I'll post the MakeMKV drive info if I do end up going for it.
otherted
Thanks for reaching out. I had not checked in here for a while but I got it updated another way and seems to be working. Appreciate the help.
mc_link
I took a punt. Drive details reported by MakeMKV:Billycar11 wrote: Thu May 08, 2025 10:59 am i think it will do UHD but you may need to crossflash and then you lose the other junk that drives does
OS device name: \Device\CdRom2
Product: BD-RW BDR-WX1DM
Revision: 1.01
Firmware date: 2023-10-27
Bus encryption flags: 13
Drive platform: Pioneer RS8801
Firmware version: ID36
PenPen
Hello, can I make my BDR-XD07 play UHD blu-rays ? Thx
Revision: 1.03
Serial number: ...
Firmware date: 2020-08-20
Drive platform: RS8D30
Firmware version: 1.03
