MakeMKV software doesn't recognize the new WONDERS OF ALADDIN BR disc. Says it's using newer version of ACCS.
Please update. I need to make copies of it to view it on my other older computers. Thanks!
The Wonders of Aladdin
preserve
Re: The Wonders of Aladdin
This new release from Kino, I presume:
https://www.kinolorber.com/product/the- ... in-blu-ray
The last Kino discs I bought were some of their September releases, which were using AACS 76 and MakeMKV had no trouble with them. If you look in the top left corner when you insert the disc where it says "Protection," does it tell you which version # the disc is using?
Using: ASUS BW-16D1HT 3.00
Maciste
Thanks for the quick reply. The protection is AACS 76.
I tried loading the WOA disc twice in MakeMKV and it gave me an error message. See attachment.
Anyway, I tried it for the third time and it's now working. Go figure.
Thank you for the 'fix'
- woa11.png (887.23 KiB) Viewed 11551 times
preserve
Normally when you see in the log that it has created an AACS dump and tells you where it put it, you should email the dump to svq@makemkv.com - although generally this would be happening for UHDs, not Blu-rays.
Strange that it should work after multiple attempts, though.
Ah good, you found the AACS version, which MakeMKV does support. (For future reference, you can also check the latest AACS version that MakeMKV supports by searching "AACS" in the release notes on the download page: http://makemkv.com/download/)
