audio format not supported
alsuraiye
Post by alsuraiye »
hi all
i have used make mkv to rib THE BFG movie and ALITA BATTLE ANGEL 4K howeever when played them using my sony ubp-700 it says audio format not supported.
can you help directing me here?
thanks
Re: audio format not supported
Which audio track(s) did you select to rip? If you play the MKV with something like VLC, what audio track codecs do you see available?
https://www.sony.com/electronics/blu-ra ... ifications
AUDIO FORMAT
AAC (.AAC, .mka), AIFF (.aiff, .aif), ALAC (.m4a), Dolby® Digital (.ac3, .mka), DSD - DSDIFF/DSD (.dff, .dsf), FLAC (.flac, .fla), HEAAC v.1/v.2/level2, LPCM (.mka), Mokey’s Audio, Vorbis, WMA10 Pro, WMA9 Standard (.WMA)
Despite that being a UHD player, it seems to have a limited amount of audio codec support.
