Basically when I choose the flac profile for LPCM audio it highlights all audio tracks instead of the one I want. Would it be possible to choose what audio track I'd want in flac instead of all audio tracks
FLAC profile transcodes all audio?
Re: FLAC profile transcodes all audio?
If you are playing back via Plex, you should not have to convert to FLAC; Plex will do that as needed, if your device profiles are set correctly.
Ferrett1983
OK thankyou for the reply but if for any reason I wanted to convert the main audio to FLAC and leave the other audio as normal would their be a way to just do the main and leave the secondary audio?
With the FLAC profile, your only choice for an LPCM source seems to be FLAC.
Chose the AAC-stereo profile, though, and the AAC conversion is selected, but the original LPCM track is available for selection (in expert mode). So it is probably possible to add a rule to the FLAC profile to allow copying the LPCM track.
