Interview with the Vampire won't rip
Richardhg
#1 Post by Richardhg » Tue Nov 17, 2020 8:28 pm
I tried to rip this Blu ray disc. There are three titles on the disk in total and only one is the feature movie, which Makemkv tells me is a 19.4 Gb file. When I'm ripping, the two shorter files rip with no problems (1.3GB and 121.0 MB from the Makemkv information screen).
The main title start's ripping ok, but at 9,961,472 KB (from Windows Explorer) it crashes and I get the error that the rip failed.
I saw a comment in the forum that a user made about using ddrescue, a Linux utility. I have a Linux PC as well, so I'll try using that to create a usable ISO and report back.
Here is the diagnostic trail from Makemkv :
MakeMKV v1.15.3 win(x64-release) started
File 00000.mpls was added as title #0
Title 00009.mpls is equal to title 00000.mpls and was skipped
Title 00010.mpls is equal to title 00000.mpls and was skipped
Title #00001.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00002.m2ts was added as title #1
File 00003.m2ts was added as title #2
Title #00004.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00013.m2ts has length of 64 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory G:/Video from HDTV/Video/Interview with the vampire
Error 'OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '10833358848'
Error 'Internal error - Operation result is incorrect (78)' occurred while reading '\Device\CdRom2' at offset '10833358848'
Error 'OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired' occurred while reading '\Device\CdRom2' at offset '10833358848'
Failed to save title 0 to file G:/Video from HDTV/Video/Interview with the vampire/title_t00.mkv
0 titles saved, 1 failed
preserve
Re: Interview with the Vampire won't rip
#2 Post by preserve » Wed Nov 18, 2020 2:07 am
Are you using an external drive powered via USB? If so, it may be losing power if not on a fully powered hub.
Using: ASUS BW-16D1HT 3.00
