Ultimate UHD Drives Flashing Guide Updated 2025
Re: Ultimate UHD Drives Guide Updated 2020
Can someone recommend or confirm what kind of cable I could use to connect a slim/laptop drive to a PC via USB (mini SATA -> USB)?
I bought an LG BU40N recently, don't have a laptop, was hoping that one of the two "approved" Unitek cables would work, but they have the full large SATA connectors. I need one for mini SATA. Just a cable, BTW, I don't want an enclosure.
fordprefect
Thanks,
I will need to wait then till I get the adapter. There is no way for makemkv on libreelec. Just want to be sure that I don't have unsuitable generation of the drive.
Thanks for the hint for macOS. I guess only thing I have to adapt is the path to this /Applications/MakeMKV.app/Contents/MacOS/makemkvcon
The current FW version looks to be recent enough (3.x), but if you don't see "Drive platform: MT1959"(MT1939 is too old), STOP!fordprefect wrote: ↑Tue Nov 17, 2020 7:58 pmThanks,
Thought that would be 'close enough'.fordprefect wrote: ↑Tue Nov 17, 2020 7:58 pmThanks for the hint for macOS. I guess only thing I have to adapt is the path to this /Applications/MakeMKV.app/Contents/MacOS/makemkvcon
fordprefect
Ok, if that should happen I can't expect it to work and would need to get a different drive, right?
Yes, absolutely fine thanks.Thought that would be 'close enough'.
Correct.fordprefect wrote: ↑Tue Nov 17, 2020 8:31 pmOk, if that should happen I can't expect it to work and would need to get a different drive, right?
https://smile.amazon.com/gp/product/B01 ... UTF8&psc=1VarHD wrote: ↑Tue Nov 17, 2020 7:41 pmCan someone recommend or confirm what kind of cable I could use to connect a slim/laptop drive to a PC via USB (mini SATA -> USB)?
Is this part of the guide a typo
WH14NS40 > WH16NS60 1.02MK
Seems odd to put the NS60 FW on the NS40
No. NS60 is the best firmware if you're only using MakeMKV. It's very reliable, fast, and no bugs.
Seeing all the posts related to external adapter issues, I'm glad I have an original CM Stacker where I can fit up to 10 optical drives.
I just picked up a Feb-2020 built BW-16D1HT in retail box for cheap since the seller had reading issues when using PowerDVD. It came with 3.10 and immediately flashed it to the 3.10MK version with SDFTool, no problems with MakeMKV ripping a Blu-ray.
fordprefect
It worked perfectly under linux with the linked description. The command to run was plainly makemkvcon without any path etc.
First UHD rip seems to work fine too. Thanks for support.
mossman1120
I am trying to find a factory copy of the 1.04 version for a WH16NS40. I can only see 1.03 and 1.05. Would anyone happen to have a copy of that? Thanks.
why would you need it?mossman1120 wrote: ↑Tue Nov 24, 2020 3:50 amI am trying to find a factory copy of the 1.04 version for a WH16NS40. I can only see 1.03 and 1.05. Would anyone happen to have a copy of that? Thanks.
mossman1120
In case one has to RMA a dead drive that came with 1.04
If it needs RMAing, just put 1.05 on it.mossman1120 wrote: ↑Tue Nov 24, 2020 4:54 amIn case one has to RMA a dead drive that came with 1.04
This ^MartyMcNuts wrote: ↑Tue Nov 24, 2020 10:17 amIf it needs RMAing, just put 1.05 on it.mossman1120 wrote: ↑Tue Nov 24, 2020 4:54 amIn case one has to RMA a dead drive that came with 1.04
