Errors reading a DVD. Help
smokeywhitetown
Post by smokeywhitetown »
The DVD plays fine in my PS3. Hmm? This is a part of a box set and most of the other DVDs in this box set seem fine via my Mac, except a few stragglers.
MakeMKV v1.15.3 darwin(x64-release) started
Optical drive "BD-RE HL-DT-ST BD-RE WP50NB40 1.01d" opened in OS access mode.
Title #1 has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #2 has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #3 was added (19 cell(s), 3:39:14)
Title #4 was added (4 cell(s), 0:46:06)
Title #5 was added (4 cell(s), 0:46:12)
Title #6 was added (4 cell(s), 0:46:13)
Title #7 was added (3 cell(s), 0:34:39)
Title #8 was added (4 cell(s), 0:46:04)
Title #9 was added (19 cell(s), 3:39:14)
Title #10 has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11 has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title 7 in VTS 3 is equal to title 1 and was skipped
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading 'BD-RE HL-DT-ST BD-RE WP50NB40 1.01' at offset '1134592'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading 'BD-RE HL-DT-ST BD-RE WP50NB40 1.01' at offset '0'
Encountered 1 errors of type 'Read Error' - see http://www.makemkv.com/errors/dvdread/
preserve
Re: Errors reading a DVD. Help
Post by preserve »
Did you read the info in the link?
I don't think I've seen this exact error before. You may want to let us know what the DVD is (and title your thread more specifically as well).
Sometimes when getting errors on DVDs, I go back to an older DVD-only drive instead of my Blu-ray drive, and then MakeMKV has no issues.
Also to note that just because a disc plays "fine" in one player, such as a gaming console or a regular disc player, doesn't mean that it won't have issues in MakeMKV. MakeMKV is more discerning as it needs to create an exact copy of the data on the disc, whereas other players can skip over unreadable information during playback.
Using: ASUS BW-16D1HT 3.00
smokeywhitetown
preserve wrote:
Sat Nov 14, 2020 2:35 pm
I did, just wondered if someone recognised the specificity of the error.
Makes me think I should have also held onto my external DVD drive.
The DVD is one of the discs present in a box set. Almost all the other discs in the set are fine, and I don't see obvious scratches on the discs either. It may be worth mentioning that on my PS3 the intro theme for the files where I'm having issues did seem to play a little faster or more higher pitched than the other episodes, even those on the very same disc.
Last edited by smokeywhitetown on Sat Nov 14, 2020 4:13 pm, edited 1 time in total.
preserve
Post by preserve »
smokeywhitetown wrote:
Sat Nov 14, 2020 4:08 pm
The DVD is one of the discs present in a box set. Almost all the other discs in the set are fine.
Yes, but even if the other discs work okay, that doesn't mean that one disc in a set can't be bad for various reasons. Anyway I'm afraid I don't have much more insight, but perhaps some of the other members here will chime in.
smokeywhitetown
I do thank you for your reply though.
