Easy Blu-ray movie playback!
sduensin
Post by sduensin »
After playing with MakeMKV and VLC for awhile, I put together a little script that glues the two together allowing very easy playback of Blu-ray movies. It's free, I did it for myself, and I thought I'd share it. http://www.jaegertech.net/software/cros ... y-playback
Tell your friends! :-)
Scott
shonofear
Re: Easy Blu-ray movie playback!
Post by shonofear »
didnt seem to work for me...
followed your instructions, your programs just hangs.
i tries loading the bluray from my external usb bluray player, but no love
cheers though
flowjoe
Post by flowjoe »
disc parameter in the script is disc:0
I suppose it should be disc:1 for an external drive
sduensin
Post by sduensin »
Give that a try and let me know. I only have one optical drive to test with. :-(
Scott
rcork
Post by rcork »
I've also found a few discs that error out when using OS Access Mode. When i switch to Direct Access it works on those discs.
shonofear
Post by shonofear »
changed settings to =1 which did make it try loading external drive straight up, then makes noises for a while whilst the program bounces up and down on the dock then eventually stops everything....
also trie opening the disc in MakeMkv using Direct Disc Mode then try program but your program then makes MakeMkv quit unexpected (error)
any other options?
am i meant to have any programs opened at the time of using your program?
thanks
heres a console reading of events...
5/01/11 7:43:55 AM [0x0-0x56d56d].Play Blu-ray Disc[64885] MakeMKV v1.6.3 darwin(x86-release) started
5/01/11 7:43:57 AM [0x0-0x56d56d].Play Blu-ray Disc[64885] Optical drive "DVD+R-DL MATSHITA DVD-R UJ-857E ZA0E" opened in OS access mode.
5/01/11 7:43:57 AM [0x0-0x56d56d].Play Blu-ray Disc[64885] Optical drive "BD-ROM PLEXTOR BD-ROM PX-B120U 1.06" opened in OS access mode.
5/01/11 7:44:56 AM com.apple.launchd.peruser.501[130] ([0x0-0x56d56d].Play Blu-ray Disc[64885]) Exited with exit code: 1
shonofear
Post by shonofear »
wow,
not really sure wat i did but now it works...
i only changed a few other settings in playBluRay.sh
one being cache=256 (was 128)
other being [ ${COUNT} == 120 (was 60)
maybe had nothing to do with that, but according to new console report MakeMkv started using Direct Access Mode.
5/01/11 7:51:01 AM [0x0-0x570570].Play Blu-ray Disc[65233] MakeMKV v1.6.3 darwin(x86-release) started
5/01/11 7:51:03 AM [0x0-0x570570].Play Blu-ray Disc[65233] Optical drive "DVD+R-DL MATSHITA DVD-R UJ-857E ZA0E" opened in OS access mode.
5/01/11 7:51:03 AM [0x0-0x570570].Play Blu-ray Disc[65233] Optical drive "BD-ROM PLEXTOR BD-ROM PX-B120U 1.06" opened in OS access mode.
5/01/11 7:51:14 AM [0x0-0x570570].Play Blu-ray Disc[65233] Using direct disc access mode
5/01/11 7:51:28 AM [0x0-0x570570].Play Blu-ray Disc[65233] Evaluation version, 28 day(s) out of 30 remaining
5/01/11 7:51:41 AM [0x0-0x570570].Play Blu-ray Disc[65233] Hit OS X IOSCSIMultimediaCommands bug, used type 0 workaround, see http://www.makemkv.com/osxbd/ for details.
5/01/11 7:51:48 AM [0x0-0x570570].Play Blu-ray Disc[65233] File 00215.mpls was added as title #0
5/01/11 7:51:49 AM [0x0-0x570570].Play Blu-ray Disc[65233] File 00101.mpls was added as title #1
5/01/11 7:51:49 AM [0x0-0x570570].Play Blu-ray Disc[65233] Title 00214.mpls is equal to title 00215.mpls and was skipped
5/01/11 7:51:50 AM [0x0-0x570570].Play Blu-ray Disc[65233] File 00008.mpls was added as title #2
5/01/11 7:51:51 AM [0x0-0x570570].Play Blu-ray Disc[65233] File 00102.mpls was added as title #3
5/01/11 7:51:51 AM [0x0-0x570570].Play Blu-ray Disc[65233] File 00103.mpls was added as title #4
5/01/11 7:51:52 AM [0x0-0x570570].Play Blu-ray Disc[65233] File 00314.mpls was added as title #5
5/01/11 7:51:52 AM [0x0-0x570570].Play Blu-ray Disc[65233] Title 00315.mpls is equal to title 00314.mpls and was skipped
5/01/11 7:51:53 AM [0x0-0x570570].Play Blu-ray Disc[65233] File 00100.mpls was added as title #6
5/01/11 7:51:53 AM [0x0-0x570570].Play Blu-ray Disc[65233] Title #00014.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
5/01/11 7:51:54 AM [0x0-0x570570].Play Blu-ray Disc[65233] File 00051.m2ts was added as title #7
5/01/11 7:51:55 AM [0x0-0x570570].Play Blu-ray Disc[65233] File 00050.m2ts was added as title #8
5/01/11 7:51:55 AM [0x0-0x570570].Play Blu-ray Disc[65233] File 00049.m2ts was added as title #9
5/01/11 7:51:56 AM [0x0-0x570570].Play Blu-ray Disc[65233] File 00048.m2ts was added as title #10
5/01/11 7:51:57 AM [0x0-0x570570].Play Blu-ray Disc[65233] File 00047.m2ts was added as title #11
5/01/11 7:51:58 AM [0x0-0x570570].Play Blu-ray Disc[65233] File 00046.m2ts was added as title #12
5/01/11 7:51:59 AM [0x0-0x570570].Play Blu-ray Disc[65233] File 00045.m2ts was added as title #13
5/01/11 7:52:00 AM [0x0-0x570570].Play Blu-ray Disc[65233] File 00044.m2ts was added as title #14
5/01/11 7:52:00 AM [0x0-0x570570].Play Blu-ray Disc[65233] File 00043.m2ts was added as title #15
5/01/11 7:52:01 AM [0x0-0x570570].Play Blu-ray Disc[65233] File 00042.m2ts was added as title #16
5/01/11 7:52:02 AM [0x0-0x570570].Play Blu-ray Disc[65233] File 00041.m2ts was added as title #17
5/01/11 7:52:03 AM [0x0-0x570570].Play Blu-ray Disc[65233] File 00040.m2ts was added as title #18
5/01/11 7:52:04 AM [0x0-0x570570].Play Blu-ray Disc[65233] File 00039.m2ts was added as title #19
5/01/11 7:52:04 AM [0x0-0x570570].Play Blu-ray Disc[65233] Title #00038.m2ts has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
5/01/11 7:52:04 AM [0x0-0x570570].Play Blu-ray Disc[65233] Title #00003.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
5/01/11 7:52:04 AM [0x0-0x570570].Play Blu-ray Disc[65233] Title #00000.m2ts has length of 39 seconds which is less than minimum title length of 120 seconds and was therefore skipped
5/01/11 7:52:04 AM [0x0-0x570570].Play Blu-ray Disc[65233] Title #00002.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
5/01/11 7:52:04 AM [0x0-0x570570].Play Blu-ray Disc[65233] Title #00052.m2ts has length of 43 seconds which is less than minimum title length of 120 seconds and was therefore skipped
5/01/11 7:52:04 AM [0x0-0x570570].Play Blu-ray Disc[65233] Title #00012.m2ts has length of 69 seconds which is less than minimum title length of 120 seconds and was therefore skipped
5/01/11 7:52:04 AM [0x0-0x570570].Play Blu-ray Disc[65233] Title #00053.m2ts has length of 52 seconds which is less than minimum title length of 120 seconds and was therefore skipped
5/01/11 7:52:05 AM [0x0-0x570570].Play Blu-ray Disc[65233] File 00008.m2ts was added as title #20
5/01/11 7:52:05 AM [0x0-0x570570].Play Blu-ray Disc[65233] Title #00901.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
5/01/11 7:52:05 AM [0x0-0x570570].Play Blu-ray Disc[65233] Title #00900.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
5/01/11 7:52:05 AM [0x0-0x570570].Play Blu-ray Disc[65233] Title #00055.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
5/01/11 7:52:05 AM [0x0-0x570570].Play Blu-ray Disc[65233] Title #00054.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
5/01/11 7:52:05 AM [0x0-0x570570].Play Blu-ray Disc[65233] Title #00007.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
5/01/11 7:52:05 AM [0x0-0x570570].Play Blu-ray Disc[65233] Operation successfully completed
5/01/11 7:52:05 AM [0x0-0x570570].Play Blu-ray Disc[65233] Streaming server started, web server address is http://192.168.1.7:51000 or http://localhost:51000
5/01/11 7:52:05 AM [0x0-0x570570].Play Blu-ray Disc[65233] UPnP server enabled on address 192.168.1.7
5/01/11 7:52:07 AM [0x0-0x570570].Play Blu-ray Disc[65233] [0x100203e18] main libvlc: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
5/01/11 7:52:08 AM [0x0-0x570570].Play Blu-ray Disc[65233] [0x10b919288] main access error: connection failed: Connection refused
5/01/11 7:52:13 AM [0x0-0x570570].Play Blu-ray Disc[65233] [0x1008b4f08] dts decoder: DTS channels:6 samplerate:48000 bitrate:1536000
5/01/11 7:52:16 AM [0x0-0x570570].Play Blu-ray Disc[65233] Stream with high frequencies VQ coding
5/01/11 7:52:22 AM [0x0-0x570570].Play Blu-ray Disc[65233] [0x100861b08] avcodec decoder error: more than 5 seconds of late video -> dropping frame (computer too slow ?)
