Application failed to initialize
rayfun
Post by rayfun » Fri Nov 13, 2020 4:18 am
I've successfully compiled and installed (/usr/local) version 1.15.3 of MakeMKV.
This is a fresh install, OS (Ubuntu 20.04) is brand new.
There are no duplicate, pre-existing libraries.
Starting MakeMKV results in a pop-up saying:
"MakeMKV BETA popup"
"Application failed to initialize".
That's it. Any ideas before I compile in debug mode and start debugging?
Thanks,
rayfun
bmillham
Re: Application failed to initialize
Post by bmillham » Fri Nov 13, 2020 4:54 pm
Try running makemkv from the command line, it will show more errors and may give you a clue what's happening.
rayfun
Post by rayfun » Sat Nov 14, 2020 11:49 am
That is not the case. See attached screenshots.
Screenshot from 2020-11-14 12-47-42.png (328.82 KiB) Viewed 18563 times
Screenshot from 2020-11-14 12-48-56.png (23.28 KiB) Viewed 18563 times
rayfun
Post by rayfun » Sat Nov 14, 2020 12:02 pm
This is a message in syslog that comes up when trying to start MakeMKV.
gnome-shell[2918]: Window manager warning: Invalid WM_TRANSIENT_FOR window 0x3400008 specified for 0x3400006.
rayfun
Post by rayfun » Sun Nov 15, 2020 12:22 am
Had makemkv-oss configured and install to prefix /usr/local and had not adjusted PREFIX in makemkv-bin Makefile.
So makemkv was looking for /usr/local/bin/makemkvcon but that was located in /usr/bin.
