What does MakeMKV do with HDR10+ metadata?
Mr_Orange
Post by Mr_Orange » Fri Nov 13, 2020 10:50 am
.... as per the subject.
Re: What does MakeMKV do with HDR10+ metadata?
Post by SamuriHL » Fri Nov 13, 2020 11:25 am
It's embedded in the video track. It leaves it alone which is to say it's included.
Mr_Orange
Post by Mr_Orange » Fri Nov 13, 2020 11:29 am
OK, thank you.
If I had a TV which supported HDR10+ (I don't so this is all hypothetical), it would display with the HDR10+ metadata without any additional processing beyond the initial rip by MakeMKV?
quietvoid
Post by quietvoid » Fri Nov 13, 2020 1:06 pm
Yes, the metadata is self contained in the original HEVC stream.
Rumourd
Post by Rumourd » Fri Aug 27, 2021 9:47 am
Once you've ripped a DV or HDR10+ disc, and you wanna Handbrake it to a smaller size, how do you get the DV/HDR10+ layer to copy over to the new file?
quietvoid
Post by quietvoid » Fri Aug 27, 2021 1:01 pm
Handbrake by itself can't do it all..
You need to extract both HDR10+ and DV (converted to profile 8 ), then feed them to x265.
I don't know if Handbrake supports custom options for x265.
For HDR10+ you need: https://x265.readthedocs.io/en/master/c ... hdr10-info
And for DV: https://x265.readthedocs.io/en/master/c ... vision-rpu
staknhalo
Post by staknhalo » Fri Aug 27, 2021 1:08 pm
Do you think if you ever had time and it interested you, that you could make a tool/add it to yours to extract + insert HDR10+ metadata into an HEVC stream like your tool and others we have for DV/RPU metadata? Your tool already extracts HDR10+ to convert to DV IIRC, so just the insert back as HDR10+ metadata part?
quietvoid
Post by quietvoid » Fri Aug 27, 2021 2:18 pm
Eventually, I just have no way to test anything HDR10+ related..
The process would be the same as for Dolby Vision, but I need to refactor things first.
staknhalo
Post by staknhalo » Fri Aug 27, 2021 2:31 pm
You're the best :)
quietvoid
Post by quietvoid » Sun Sep 05, 2021 9:36 pm
This is now in the newly renamed "hdr10plus_tool" (yes very original).
See here: https://github.com/quietvoid/hdr10plus_ ... /tag/1.0.0
Since I don't have an HDR10+ display, this needs testing.
staknhalo
Post by staknhalo » Mon Sep 06, 2021 3:53 pm
Awesome, thanks :)
I'll test it out and let you know how it goes as soon as I can, thanks again.
staknhalo
Post by staknhalo » Mon Sep 06, 2021 11:03 pm
Hey, played around with it - does not appear to be working right unfortunately (or maybe user error?).
I took the HDR10+ metadata from the first 5 mins of WW84 and exported to json and then applied it to the first 5 minutes of Annihilation's HDR10 only BL stream. Mediainfo does report it as HDR10+ and it kicks in HDR10+ mode on my Hisense - but I am noticing no scene changing/flashing going at all going on - which should be noticeable given the mismatched input files. It's apparently just playing in HDR10 only, but while being reported as/in HDR10+ mode - with none of metadata actually being used.
Now, I did get this error when making the video file with the tool, but I assumed it wasn't discarding all the metadata, just at the very end of the video - I should still have metadata/scene changing going on at the start/rest of the video.
Here is the json that was originally extracted along with the resulting file that was made if you wanna take peek at them: https://mega.nz/file/sbol0KQI#snrJiB6QC ... 8-ETxbGkH8
quietvoid
Post by quietvoid » Mon Sep 06, 2021 11:32 pm
Normally if the TV switches to HDR10+, the metadata should be used.
To me that makes it work.
I don't know if it would necessarily be flashing, though.
Depends on the metadata and if the video is brighter than your TV can display without tonemapping.
I know of this test video for HDR10+, if you want to try: http://ff.de/hdr10plus-metadata-test/
That should be showing a noticeable change.
In the meantime I might try using your JSON and turning it into Dolby Vision to see if it flashes for me.
edit: I'm seeing some slight changes around 0:55, 1:45, and 4:24. That's pretty much it.
staknhalo
Post by staknhalo » Tue Sep 07, 2021 12:00 am
Yes, that's showing what I was looking for, however...
change at 0:55 confirmed - it's subtle as hell and hard to see - I could only notice out of the entire scene the top part of the inside of the metal door/doorframe/whatever, reflection or something got dimmer. I was expecting an overall scene brighter/dimmer effect. I couldn't notice anything at the other two times.
So apologies, and thanks again :)
