WilJ27
Post by WilJ27 » Thu Nov 12, 2020 6:14 pm
Billycar11 wrote: Wed Nov 11, 2020 11:08 pm @Billycarr11
Is there a specific place where I can find one of these tools? Or could I just do a google search?
WilJ27
Post by WilJ27 » Thu Nov 12, 2020 6:35 pm
WilJ27 wrote: Wed Nov 11, 2020 10:48 pm Hi, I'm somewhat new to make mkv and I tried out the application but it keeps saying something like "Error #5." I use a BP50NB40 and it's updated to 1.03. I want to use makemkv to rip my 4k copy of Alita: Battle Angel. What do I do to make it work?
because 1.03 is encrypted use makemkv cmd or sdf tool
So I've tried the sdf tool, but I keep getting "Command produced error code 0x8f056103"
WilJ27
Post by WilJ27 » Thu Nov 12, 2020 6:40 pm
So I've tried the sdf tool, but I keep getting 'Command produced error code 0x8f056103."
Post by Billycar11 » Thu Nov 12, 2020 8:31 pm
WilJ27 wrote: Thu Nov 12, 2020 6:40 pm So I've tried the sdf tool, but I keep getting 'Command produced error code 0x8f056103."
Did you check the enc option
Do you have makemkv installed
WilJ27
Post by WilJ27 » Thu Nov 12, 2020 8:38 pm
I did and I do have makemkv installed. It’s v1.15.2. Does it have to be v1.15.3?
Post by Billycar11 » Thu Nov 12, 2020 8:57 pm
WilJ27 wrote: Thu Nov 12, 2020 8:38 pm I did and I do have makemkv installed. It’s v1.15.2. Does it have to be v1.15.3?
What firmware are you trying to flash?
Post by Billycar11 » Thu Nov 12, 2020 11:14 pm
WilJ27 wrote: Thu Nov 12, 2020 9:00 pmBP50NB40
What version
WilJ27
Post by WilJ27 » Fri Nov 13, 2020 12:11 am
I have tried DE 1.01mk, old HL-DT-ST nb50 1.01 and nb50 1.02
Post by Billycar11 » Fri Nov 13, 2020 12:12 am
WilJ27 wrote: Fri Nov 13, 2020 12:11 am I have tried DE 1.01mk, old HL-DT-ST nb50 1.01 and nb50 1.02
do 1.03 mk with enc checked
shockracer
Post by shockracer » Fri Nov 13, 2020 2:50 am
I have an LG WH16NS40, tried to jump straight to firmware DE_LG_WH16NS40_1.02_NS50. Kept getting "Update Failure #4". I then started the app and selected mk-firmware-park-20200720/MK/HL-DT-ST/WH16NS40-NS50, then selected HL-DT-STBD-RE_WH16NS40-NS50-1.05-NM00900-212005061440, selected the drive that matched and clicked start. BOOM, install was successful. I was then able to re-run the program and select firmware DE_LG_WH16NS40_1.02_NS50, once again, BOOM, it was successful!
Thank you for this program and your continued dedication to it!
Post by Billycar11 » Fri Nov 13, 2020 8:32 am
shockracer wrote: Fri Nov 13, 2020 2:50 am I have an LG WH16NS40, tried to jump straight to firmware DE_LG_WH16NS40_1.02_NS50. Kept getting "Update Failure #4". I then started the app and selected mk-firmware-park-20200720/MK/HL-DT-ST/WH16NS40-NS50, then selected HL-DT-STBD-RE_WH16NS40-NS50-1.05-NM00900-212005061440, selected the drive that matched and clicked start. BOOM, install was successful. I was then able to re-run the program and select firmware DE_LG_WH16NS40_1.02_NS50, once again, BOOM, it was successful!
that would have never been a problem if you read my guide and flashed to WH16NS60 1.02mk from the start
ergeeg
Post by ergeeg » Mon Nov 16, 2020 7:58 pm
75 / 5000
Übersetzungsergebnisse
Hi!
I have this drive:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Serial number: xxxxxxx
Bus encryption flags: 1F
Highest AACS version: 50
Harware support: Yes
Firmware support: No
Firmware version: 3.10
I keep getting error # 1 why?
I selected this MK firmware "ASUS-BW-16D1HT-3.10-WM01601-211901041014.bin"
THX!
Post by MartyMcNuts » Tue Nov 17, 2020 12:23 am
ergeeg wrote: Mon Nov 16, 2020 7:58 pm 75 / 5000
Hi!
I have this drive:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
THX!
How is the drive connected to PC?
If using an adapter the problem could be the adapter.
Just use the SDFtool Flasher instead.
ergeeg
Post by ergeeg » Tue Nov 17, 2020 1:22 am
Yes, I am using a Sata to Sata USB adapter. I loaded the SDFtool tool, but nothing happens. When I hit start nothing happens.
